| Write-Up: Installing FWI Filter, Heat Shield, Air Scoop | |
+31llamalor2112 denim ibmoses #1BearsFan deekster_caddy xxsupergman25xx IBx1 texasfan010 Rickw EASHER lyonsperformance SuperRiv07 robotennis61 98riv albertj 1998rivman Joey98riv RhinoFLA TType_Riviera T Riley Jack the R 97rivman turtleman Jason racinfan mcgusto82 NO 4 EVR SpaceBar Mr.Riviera dreww AA 35 posters |
1998rivman Amateur
| Subject: Re: Write-Up: Installing FWI Filter, Heat Shield, Air Scoop Tue Feb 12, 2008 12:52 pm | |
- and for some reason, the A/C does not work when the sensor is disconnected.
The automatic climate control needs the outside temperature in conjunction with the inside temp. to keep the interior at the desired settings. Otherwise, it doesn't know how to set the blend doors. | |
| Subject: Re: Write-Up: Installing FWI Filter, Heat Shield, Air Scoop Tue Feb 12, 2008 6:02 pm | |
| MIght be able to use plastic fittings for residential hot water to house the IAT and give it a thermal break from the metal pipe.
| Subject: Re: Write-Up: Installing FWI Filter, Heat Shield, Air Scoop Tue Feb 12, 2008 6:37 pm | |
| That's a good idea if you notice IAT temps change very slowly. I've seen some guys at the GTO boards, they just lay the IAT sensor next to the air filter in the CAI. But my IAT changes very quickly, and the intake tube feels pretty cool near the filter, even when driving for an hour or two. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
RhinoFLA Aficionado
| Subject: Re: Write-Up: Installing FWI Filter, Heat Shield, Air Scoop Tue Feb 12, 2008 7:24 pm | |
| I'm not sure if mine is broken or what. I don't have any check engine codes, and I don't have mine plugged in because I didn't want to make a hole in my intake tubing and not be guaranteed that it would totally reseal if I did, so I let mine dangle down.. I might have to buy the pigtail and maybe let it hang down into my fenderwell or something.. | |
98riv Moderator
| Subject: Re: Write-Up: Installing FWI Filter, Heat Shield, Air Scoop Tue Feb 12, 2008 10:31 pm | |
- That's a good idea if you notice IAT temps change very slowly. I've seen some guys at the GTO boards, they just lay the IAT sensor next to the air filter in the CAI. But my IAT changes very quickly, and the intake tube feels pretty cool near the filter, even when driving for an hour or two.
That is what I had for a while when I first built my CAI. Then I realized it would be a better idea to install it in the tube like the stock system was. An easy way to mount the AIT sensor is to get a plastic coupling and drill a hole in it. Then just stick the sensor into it and the plastic should form around the sensor. You can put some foil tape around it to make sure it doesn't fall off. _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
| Subject: Re: Write-Up: Installing FWI Filter, Heat Shield, Air Scoop Tue Feb 12, 2008 10:52 pm | |
| - Quote :
- I don't have mine plugged in because I didn't want to make a hole in my intake tubing and not be guaranteed that it would totally reseal if I did, so I let mine dangle down..
It probably won't throw a code, but the IAT circuit is open, reporting 0 ohms, so the PCM thinks it is very cold, probably -40ºF or whatever the minimum temp is. The PCM is either going to know this is an error, or it will likely run ultra rich until the O2 sensor corrects things. Too rich can make the car a lot slower than normal. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
Joey98riv Amateur
Name : Joey Age : 37 Location : Wyoming Joined : 2008-02-07 Post Count : 30 Merit : 0
| Subject: Re: Write-Up: Installing FWI Filter, Heat Shield, Air Scoop Wed Feb 13, 2008 1:52 am | |
| I didn't notice a difference but it was nearly 20 below when I was driving at night. =D | |
RhinoFLA Aficionado
| Subject: Re: Write-Up: Installing FWI Filter, Heat Shield, Air Scoop Wed Feb 13, 2008 7:04 pm | |
| So would the pigtail into the fenderwell be a viable option? Or do I need to tap a hole in my intake? I would have tapped it but the material isn't flat, so it would be really hard to fit the sensor in there and be able to reseal it. | |
| Subject: Re: Write-Up: Installing FWI Filter, Heat Shield, Air Scoop Wed Feb 13, 2008 9:56 pm | |
| I think inside the filter or tube would be ideal. In the fenderwell would be okay. Try to keep the sensor as close to the filter as possible for accurate reading. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
T Riley Guru
| Subject: Re: Write-Up: Installing FWI Filter, Heat Shield, Air Scoop Wed Feb 13, 2008 10:07 pm | |
| Friday or monday i will be removing the throttle body and THOUROUGHLY cleaning it and then if i feel like it i will be doing a LITTLE porting job and then shine it to a mirror finish........ and then ditch the 3 inch pvc and upgrade to 4 inch pvc BY the way what do i need to take off the MAF out of the throttle body..... i is a torx outside thing but thers a wierd ball in the middle of it.. Also how hard is it to reconnect the throttle cables and disconnect>> | |
| Subject: Re: Write-Up: Installing FWI Filter, Heat Shield, Air Scoop Wed Feb 13, 2008 10:28 pm | |
| The fasteners for the MAF are "Temper Proof Star" type. You can find a set of bits at most auto parts stores for $5.
Good luck with the TB cleaning. I've always cleaned mine with the accelerator while driving. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
T Riley Guru
| Subject: Re: Write-Up: Installing FWI Filter, Heat Shield, Air Scoop Wed Feb 13, 2008 10:40 pm | |
98riv Moderator
| Subject: Re: Write-Up: Installing FWI Filter, Heat Shield, Air Scoop Wed Feb 13, 2008 10:48 pm | |
| Subject: Re: Write-Up: Installing FWI Filter, Heat Shield, Air Scoop Wed Feb 13, 2008 10:58 pm | |
| The screen evens the air flow for more accurate MAF read. Leave it in there. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Write-Up: Installing FWI Filter, Heat Shield, Air Scoop Tue May 27, 2008 6:10 pm | |
| Aargh, I can no longer find this intake kit - But I did find instructions for making your own - Link | |
| Subject: Re: Write-Up: Installing FWI Filter, Heat Shield, Air Scoop Wed May 28, 2008 6:22 am | |
| Subject: Re: Write-Up: Installing FWI Filter, Heat Shield, Air Scoop Wed May 28, 2008 1:14 pm | |
| Thanks - be nice if they were about $60 less. Bit pricey for experimenting. | |
| Subject: Re: Write-Up: Installing FWI Filter, Heat Shield, Air Scoop Thu May 29, 2008 6:52 am | |
SuperRiv07 Addict
Name : Nick Age : 39 Location : Brookfield, And If everything goes right A Nice big house in Bolingbrook with a big GARAGE Joined : 2008-07-20 Post Count : 706 Merit : 0
| Subject: Re: Write-Up: Installing FWI Filter, Heat Shield, Air Scoop Mon Sep 01, 2008 11:28 pm | |
| man you guys got me thinking and im lovin the ideas im definitly tryin alot of them out especially the ram air idea will let you know how it goes | |
lyonsperformance Enthusiast
Name : Michael Age : 40 Location : Buffalo N.Y. Joined : 2008-08-02 Post Count : 178 Merit : 0
| Subject: Re: Write-Up: Installing FWI Filter, Heat Shield, Air Scoop Wed Sep 03, 2008 3:56 pm | |
| I have a FWI i built using parts from Spectre Performance, and i was thinking of going this route to lower intake temps, but it seems a little to pricey for what it is and it isnt at all attractive. but who cares if your car runs better and or faster with it! http://www.jegs.com/i/Thermo%20Tec/893/14500/10002/-1 heres the view from the TB and the view into the FW | |
| Subject: Re: Write-Up: Installing FWI Filter, Heat Shield, Air Scoop Wed Sep 03, 2008 4:11 pm | |
| - Quote :
- man you guys got me thinking and im lovin the ideas im definitly tryin alot of them out especially the ram air idea will let you know how it goes
Keep in mind, it's not really 'ram air'. Think of it as better cold air intake. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
dreww Junkie
| Subject: Re: Write-Up: Installing FWI Filter, Heat Shield, Air Scoop Thu Sep 04, 2008 10:09 am | |
| i really believe this set up is the way to go because its completely modular, im sure there is a more flow efficient way, to route it because the 90* that turns the straight into the FW, is a little bit restrictive, but all in all ive seen excellent results. Plus the chrome looks awesome undernea the hood, it really stands out. | |
| Subject: Re: Write-Up: Installing FWI Filter, Heat Shield, Air Scoop Thu Sep 04, 2008 10:14 am | |
| Ive been looking around for anyway to run a ram air style set-up for this intake, but i keep drawing blanks and impractical ideas! this is the burden we face, while trying to balance performance and appearence! | |
EASHER Member
Name : ERIK M. ASHER Age : 55 Location : BLOUNTSTOWN, FL Joined : 2008-10-24 Post Count : 85 Merit : 0
| Subject: Re: Write-Up: Installing FWI Filter, Heat Shield, Air Scoop Thu Oct 30, 2008 8:24 am | |
| Has anyone used the APC Stainless Steel mesh cone air filter? It looks like a very low maintenance, low restriction filter for use in FWI applications | |
| Subject: Re: Write-Up: Installing FWI Filter, Heat Shield, Air Scoop | |
