 Low coolant light intermittent
9ty7rivi
PostSubject: Low coolant light intermittent   Fri Jul 13, 2018 4:03 pm
I don't know if this has been asked or addressed as I looked through and didn't see anything similar. Just wondering if anyone has ran into this issue before regarding the low coolant light coming on every so often? Before I do any preliminary tests. Thanks for any advice!
Merit : 135
PostSubject: Re: Low coolant light intermittent   Fri Jul 13, 2018 4:25 pm
Umm, the preliminary "test" is to look in the coolant reservoir and to open the radiator cap and see if the coolant is indeed low... Do that? What'd you find?
9ty7rivi
PostSubject: Re: Low coolant light intermittent   Fri Jul 13, 2018 5:19 pm
I apologize for not stating that I've done the obvious and looked into the radiator, and also checked my overflow reservoir everything looked good visually.
9ty7rivi
PostSubject: Re: Low coolant light intermittent   Fri Jul 13, 2018 5:21 pm
I should have also stated that by saying "preliminary" testi was referring to troubleshooting steps(electronic) and for my service manual procedures. I was just wondering if anyone else has encountered this issue.
stydel311
PostSubject: Re: Low coolant light intermittent   Fri Jul 13, 2018 9:19 pm
Mine used to do that. Replaced the sensor on the radiator, about halfway down on the passenger side.
9ty7rivi
PostSubject: Re: Low coolant light intermittent   Sat Jul 14, 2018 2:56 am
Thanks a lot!
Lmck3
PostSubject: Re: Low coolant light intermittent   Sat Jul 14, 2018 1:47 pm
my 95 riv had the same problem.
in hindsight it appears related to the common "intake-manifold-gaskets-fail" problem.
my low coolant alert was occasional & intermittant.
because the sensor cost more than $75,
i removed and cleaned the sensor.
[don't precisely recall what was used to clean, probably hot water/dish soap]
problem solved.
i concluded that the cause was contamination of the sensor caused by oil
that got into the coolant before the intake gaskets were changed.
9ty7rivi
PostSubject: Re: Low coolant light intermittent   Sat Jul 14, 2018 7:33 pm
Thanks for the input I will be looking into trying that out.
Merit : 135
PostSubject: Re: Low coolant light intermittent   Mon Jul 16, 2018 12:23 pm
Thanks for posting you'd done the obvious.
My experience is that the factory coolant sensor just dies after some time/mileage.  IIRC I got a Delphi, that was years ago & I don't see any on rockauto.com now.   The Standard they show ought to be OK.  To cheap out you could pull one at a pick n pull.  I don't know what makes them fail; I do know they can get crud buildup on them.
9ty7rivi
PostSubject: Re: Low coolant light intermittent   Wed Jul 18, 2018 12:41 pm
Not a problem. Thanks for any and all input given. I take it where I can. I haven't had it come up since my last post. I figured after I ran it hard(not WOT) 1/2 throttle get it a little upset and force some coolant flow it would come up and nothing, yet.
» First Light - BBC2, Tuesday the 14th, 9:00pm
» xentech hid light kit
» backup light
» Epic Infinity Light wind kite
» Mirror Light Conversion to Amber LED
