 Cant find electronic leveling compressor
156slim
156slim
Cant find electronic leveling compressor  Empty
PostSubject: Cant find electronic leveling compressor    Cant find electronic leveling compressor  EmptySat Aug 04, 2018 3:21 pm
I recently bought a 96. The shocks are bad so I decided to replace them. I figured while doing that I may as well go over the ELC. Come to think of it, I've never heard the compressor cone on before. Relay is good and in place. Follow the air lines from the shocks and find them unplugged. But I cant figure out where they were ever plugged into. Can someone point me to where the compressor should be?
Merit : 111
PostSubject: Re: Cant find electronic leveling compressor    Cant find electronic leveling compressor  EmptySat Aug 04, 2018 3:42 pm
Right behind the passenger rear wheel.
156slim
156slim
PostSubject: Re: Cant find electronic leveling compressor    Cant find electronic leveling compressor  EmptySat Aug 04, 2018 4:03 pm
Not there. The lines from the shocks are fastened to the frame and run forward till they get to an unplugged connector in front of the passenger rear wheel. But like I say cant find anything it was connected to or anywhere a compressor was mounted. ELC standard on these wasn't it?
156slim
156slim
PostSubject: Re: Cant find electronic leveling compressor    Cant find electronic leveling compressor  EmptySat Aug 04, 2018 4:32 pm
Oh, wait! I found where the compressor used to be mounted. Dang it. You were right about the location tho.
pbrktrt
PostSubject: Re: Cant find electronic leveling compressor    Cant find electronic leveling compressor  EmptySun Aug 05, 2018 2:51 pm
NAPA 990007 cures that.
156slim
156slim
PostSubject: Re: Cant find electronic leveling compressor    Cant find electronic leveling compressor  EmptySun Aug 05, 2018 10:25 pm
Now if I can just find the electrical wires that used to go to it.
Merit : 152
PostSubject: Re: Cant find electronic leveling compressor    Cant find electronic leveling compressor  EmptyMon Aug 13, 2018 9:27 am
You might want to pull that section of the harness from another GM car with same leveler setup - there were several. Lesabre, Park Ave, Bonneville, Deville and Seville come to mind for the '98 Riv. Find one in a pick & pull and have a look under the rear, approximately same location as on the Riviera.
PostSubject: Re: Cant find electronic leveling compressor    Cant find electronic leveling compressor  EmptySun Aug 26, 2018 8:40 pm
I may have a used compressor for you. If you haven't already found one.
I'll have to look in my storage unit.
Give me a day or 2. I'm going to be pulling all my Riviera parts out and put them up for sale soon.
Rick
» X-Terra Detector find at Hill End the other day...
» Hoping to find enough gold to survive. your input is most welcome
» RDC Leveling kit Modified!
» Inverters & sensitive electronic equipment.
» Find me Mizuno Ronin 2's Size 12
