 65 Riv GS engine production code stamp
2 posters
skypilot
65 Riv GS engine production code stamp Empty
PostSubject: 65 Riv GS engine production code stamp   65 Riv GS engine production code stamp EmptyFri Nov 30, 2018 9:21 am
I am about to purchase my first 65 Riviera GS. The engine production code is stamped L X167. The L is over 2 inches from the X. Does anyone know if this is normal or fake stamping.
Jack
Merit : 149
PostSubject: Re: 65 Riv GS engine production code stamp   65 Riv GS engine production code stamp EmptyFri Nov 30, 2018 1:31 pm
I would say that is most likely normal. I know the 67-76 350 and 400/430/455 engine codes were like that. The letters were stamped separately, not together. LX is a 425 CID. More info below.
https://www.teambuick.com/reference/nailhead_425_identification.php
This is a 1971 Buick 350 with code TD
http://www.v8buick.com/index.php?attachments/7-30-2018-10-10-39-am-jpg.398326/
See how far apart they are? Sometimes, the letter(s) are partially obscured by the head or gasket.
Join over at www.v8buick.com Lots of great info and knowledge over there.
skypilot
PostSubject: Re: 65 Riv GS engine production code stamp   65 Riv GS engine production code stamp EmptyFri Nov 30, 2018 4:06 pm
The
Most confusing is the L is over two inches away from the X167. The L is not a clear crisp stamp like the others. It would be helpful if I could include a photo. Also on this 65 are the 2 carbs with a metal sticker on each throat that reads Carter Competition. Look on the side of the carb and raised factory letters read WEBER, so its not an original Carter carb.
I also need to measure the exhaust pipe dia. to help determine if its was original GS. It does have the Gran Sport emblems in the right ( early production ) location and on the glove box.
Merit : 149
PostSubject: Re: 65 Riv GS engine production code stamp   65 Riv GS engine production code stamp EmptyFri Nov 30, 2018 4:40 pm
Go over to www.v8buick.com and join. The guys over there in the Nailhead Forum can answer your questions better than I.
» Knocking Sound?
» General Auto Manufacturers Production Figures
» where is engine coolant heater/engine block heater
» New code, what is it? Please help if possible!!!!
» FAQ: Mass Air Flow (MAF) Sensor Issues?
Riv Performance ::   General Tech :: Engine Bay-
