 Traction Control
MichaelB
Traction Control Empty
PostSubject: Traction Control   Traction Control EmptySun Dec 23, 2018 4:42 pm
Anybody experienced the traction control will not stay on ? I turn it on and it automatically turns its self off after driving about a quarter of a mile and can't be turned back on until the car is shut off and restarted Thanks Michael
PostSubject: Re: Traction Control   Traction Control EmptySun Dec 23, 2018 6:28 pm
What year is your Riv.??
Do you need a set of Factory Service Manuals to help you diagnose the problem.??
If so, I have a complete set for 1998 and another set for 1999. Both in excellent condition.
Very cheap.
MichaelB
PostSubject: Re: Traction Control   Traction Control EmptySun Dec 23, 2018 6:44 pm
Guess I should have included that mine is a 95 Thanks
PostSubject: Re: Traction Control   Traction Control EmptyMon Dec 24, 2018 3:42 pm
Check all the wiring at each wheel sensors.
MichaelB
I will thanks
Merit : 154
PostSubject: Re: Traction Control   Traction Control EmptyMon Dec 31, 2018 11:05 am
+1 to what Larry wrote, and the problem may be a wheel sensor itself. If you have a scanner that does logging and is ABS capable you can let it read the wheel sensors while you drive.
Traction Control
» I'm back with a new FJ!
» Micron Radio Control
» Improving Traction on a Murray Wide Body
» control lines
» air traffic control !
