 key is stuck
Bruick
key is stuck Empty
PostSubject: key is stuck   key is stuck EmptyMon Jan 07, 2019 4:50 pm
i have a 97 buick riviera that the last couple of times the key gets stuck in off position, not allowing me to remove key or to turn to lock position, is there a shift interlock in the console shifter, or how can i fix this issue? Any help from the knowledge out there? Thanks fellas.
nickwon
key is stuck Empty
PostSubject: Re: key is stuck   key is stuck EmptyWed Jan 09, 2019 1:39 am
Maybe it is time to replace the ignition switch.
key is stuck Empty
PostSubject: Re: key is stuck   key is stuck EmptyWed Jan 09, 2019 8:35 am
If your key is getting stuck, it's more than likely that the Ignition Cylinder is going bad. The tumblers are wearing out and causing it to stick. You could always try spraying some liquid dielectric grease in the key hole (don't drench it) and see if the tumblers free up. If they don't, it's time to replace the cylinder.
Merit : 152
key is stuck Empty
PostSubject: Re: key is stuck   key is stuck EmptyWed Jan 09, 2019 8:01 pm
I'm on my third lock cylinder, second ignition switch.
key is stuck Empty
key is stuck
» Funny day,,found a yamaha blaster stuck in the mud
» How to get rims and hubs off stuck axles.
» stuck in high gear.
» King Quad Stuck in 4x4
» Stuck Pulley
