 rattling noise
nickwon
rattling noise Empty
PostSubject: rattling noise   rattling noise EmptySun Jan 13, 2019 9:11 pm
Got new falken tires last week. Now, I'm hearing a rattling noise in the rear tires when driving. I checked the lug nuts and they are tight. Any ideas?
PostSubject: Re: rattling noise   rattling noise EmptyMon Jan 14, 2019 8:49 am
Somebody drop a weight or something inside the tire and leave it? scratch
Did someone bump a backing plate and now it's contacting the rotor? Rear backing plates, especially on older cars, can make some pretty funny noises.
Merit : 111
PostSubject: Re: rattling noise   rattling noise EmptyMon Jan 14, 2019 2:32 pm
Take the tire off and shake it if you think something is inside the tire. Take it back to the shop that installed the tires.
Merit : 152
PostSubject: Re: rattling noise   rattling noise EmptyTue Jan 15, 2019 1:06 am
Sounds like a coincidence. A lose weight would quit rattling above a certain speed.
Check the bolts at the bottoms of the shocks.
Check the brake hoses, the e-brake cable, and the ABS wiring to the rear hubs to see if something became loose.
nickwon
PostSubject: Re: rattling noise   rattling noise EmptySun Jan 20, 2019 9:23 pm
Sorry for the late reply. I went to a repair shop and the mechanic told me that the bottom shock bolts are the ones causing the noise. Thanks guys for the help.
Merit : 152
PostSubject: Re: rattling noise   rattling noise EmptyWed Jan 23, 2019 8:59 pm
Boom. pirate You're welcome, of course.
rattling noise
» Unstable ground signal noise around ant nests
» Rough noise
» front end noise on 2008 RZR
» Cabin noise. Rhino vs RZR
» Rhino Rear Brake AWFUL Noise -- Normal??
