| Brake Booster Replacement? | |
TampaRivGuy Rookie
Name : TampaRivGuy Joined : 2019-02-19 Post Count : 14 Merit : 0
| Subject: Brake Booster Replacement? Tue Feb 19, 2019 12:23 pm | |
| Hi Guys, its my first post here. My Master Cylinder and booster are bad, so my car won't idle because of the massive vacuum leak.
I cant see the bottom left bolt on the brake booster because the steering shaft is in the way
Does anyone have experience in replacing?
Thanks
Andrew | |
TampaRivGuy Rookie
| Subject: Re: Brake Booster Replacement? Tue Feb 19, 2019 1:00 pm | |
| Subject: Re: Brake Booster Replacement? Tue Feb 19, 2019 3:08 pm | |
| You might have to unbolt the column at the instrument panel to move it away enough. My 1998 FSM doesn't mention that. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
TampaRivGuy Rookie
| Subject: Re: Brake Booster Replacement? Tue Feb 19, 2019 5:10 pm | |
| - LARRY70GS wrote:
- You might have to unbolt the column at the instrument panel to move it away enough. My 1998 FSM doesn't mention that.
Before I cut the boot to pieces, is there enough left to right play to move it that much? | |
| Subject: Re: Brake Booster Replacement? Tue Feb 19, 2019 5:40 pm | |
| - TampaRivGuy wrote:
Before I cut the boot to pieces, is there enough left to right play to move it that much? Not sure, I've never attempted this. Up to you. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
TampaRivGuy Rookie
| Subject: Re: Brake Booster Replacement? Tue Feb 19, 2019 6:33 pm | |
| I split the boot and got it, should I do a write-up after this? | |
| Subject: Re: Brake Booster Replacement? Tue Feb 19, 2019 7:00 pm | |
| Sure, it can't hurt. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: Brake Booster Replacement? Wed Feb 20, 2019 12:52 am | |
Not sure, I've never attempted this. Up to you. ...does the boot slide or compress? | |
TampaRivGuy Rookie
| Subject: Re: Brake Booster Replacement? Wed Feb 20, 2019 6:49 am | |
| Neither, it has 6 ribs of spring steel, it took a dremel and patience | |
| Subject: Re: Brake Booster Replacement? | |
