 Shrinking rear window molding.
carguy8888
Shrinking rear window molding. Empty
PostSubject: Shrinking rear window molding.   Shrinking rear window molding. EmptyFri Mar 01, 2019 7:02 pm
My car sat outside for a long time and has a couple of euge gaps after the rear window molding shrunk. Is this a common problem with these cars. I'm pretty sure water is leaking into my trunk through here.
Shrinking rear window molding. 20190301_181442_HDR
Merit : 152
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. EmptyFri Mar 01, 2019 8:42 pm
Yes the moulding shrinks over time. You can slow down the shrink with moulding dressing (silicone) but it will still shrink, mine have shrunk too just not as much. The trunk leak would not really come from there, the window is sealed under the glass with urethane. The leak rather would come from the weird body panel fit at the trunk hinges.
Caulking/bridging that moulding gap won' hurt but it will not fix your trunk leak.
carguy8888
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. EmptyFri Mar 01, 2019 9:09 pm
I just had a body guy replace the seam sealer on the quarters two weeks ago. Thanks for the heads up that its not the glass. This leak is a pain in the ass.
Merit : 152
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. EmptySat Mar 02, 2019 5:52 pm
Seam sealer won't be enough, especially if Body Guy missed the seam that runs along the top of the rear fenders, and if the trunk hingle landingsare not cleaned and welded or epoxied. .  Look at the area upwards from the trunk floor and you'll see the areas of interest, most likely they will have mild corrosion at the edges.
carguy8888
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. EmptySat Mar 02, 2019 7:42 pm
Yes, it was cracked by the hinges. I can take some pics tomorrow. My plan was to get in the trunk and video where I think it is coming in. Everything is out of the trunk including the mat and the spare tire.
Merit : 152
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. EmptySat Mar 02, 2019 9:10 pm
There is a seam along the top of the rear fender just above the plane of the gutter around the trunk opening. Be sure to check that.
Most likely stopping the water involves removing the trunk and repairing the area where the hinges are secured, as well as getting at those seams. On my car I had the trunk removed and had new metal welded in to hold the trunk hinges.
One almost wonders if the Riv was intended to be a fiberglass or polymer shell. And one wonders about a Riv factory convertible.
carguy8888
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. EmptySat Mar 02, 2019 9:37 pm
I'll post pictures tomorrow of what we did.
carguy8888
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. EmptySat Mar 02, 2019 9:39 pm
I'll snap some pictures tomorrow when I take the car out and you guys can see what we did. Thanks for the good advice of this board I would have thought it was the rear window but the exterior molding isjust cosmetic apparently.
Merit : 152
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. EmptySun Mar 03, 2019 10:05 pm
Right.  You do want the rear moulding contiguous because you do not want water/silt/salt accumulating in the cavity, but there's just no communication to the trunk cavity from there.
Consider making sure it is cleaned out (blow out with air after a wash) then fill the gap with black silicone and shape it with a wet Popsicle stick...
carguy8888
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. EmptySun Mar 03, 2019 10:07 pm
Damn, you just reminded me I forgot to take the picture LOL. But apparently I have some more work to do.
nickwon
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. EmptyTue Mar 19, 2019 10:13 pm
I use 303 protectant. I like this product since it offers UV protection.
Merit : 152
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. EmptyTue Mar 19, 2019 10:57 pm
I use 303 also and it is **great** stuff. Moulding still shrinks.
carguy8888
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. EmptyThu Mar 21, 2019 6:53 pm
I had the gap filled behind the black plastic corner piece. It is still leaking alot on both sides. There was a hole just behind the plastic piece but I guess there are more holes somewhere behind it. We did pull up the black strip as well but we missed something. I am glad I did not put the carpet back in yet.  scratch
Shrinking rear window molding. 3f37bf28-215e-423b-83a0-a5fc905c7efb-original
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. EmptyThu Mar 21, 2019 7:04 pm
Just to be clear, the weatherstripping around the rear window( your part that looks like it shrunk, does not keep water out of the trunk. Where you see the hinge in your picture, water is able to get in there normally, it is not air tight. I dont know if you removed it, if it is not attached properly or if it is missing, but you shouldnt be able to see that flat white lip in the bottom right corner of your picture. There is supposed to be a weatherstripping on there that keeps the water out.
carguy8888
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. EmptyThu Mar 21, 2019 7:09 pm
Oh, I missing a piece? Can you post a pic so I know what I am missing?
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. EmptyThu Mar 21, 2019 7:12 pm
Shrinking rear window molding. 047A253B-5FF7-4315-B316-E0F2BD99E890_zpsnvr9ifwb
carguy8888
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. EmptyThu Mar 21, 2019 7:15 pm
Holy s%$!. That really helps.
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. EmptyThu Mar 21, 2019 7:16 pm
Ill say! That would cause quite the leak!
carguy8888
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. EmptyThu Mar 21, 2019 7:25 pm
I have quite the leak lol. Is it the rear glass or part of the trunk weatherstrip?
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. EmptyThu Mar 21, 2019 7:45 pm
Its the trunk weatherstripping. Its one piece and just wraps around the metal ledge. Seats against the decklid when the trunk is closed
carguy8888
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. EmptyThu Mar 21, 2019 8:01 pm
I see the piece that is missing super thank you. GM exploded views only show the oval gasket going around the trunk, not the one I am missing. A stupid question, without that gasket would the water not go just into the channel not in the car? I am going to hunt down this gasket.
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. EmptyThu Mar 21, 2019 8:18 pm
Some water will always get into the channel, where the hinges are. There arent any flat spots though so it should run right out by the taillight. Thats why most taillights get those two spots where the chrome starts pitting. The rubber weather strip you’re looking for, keeps that water from splashing into the trunk, if that answers your question?
Your best bet is to find a riv at a pick and pull and grab one. I would imagine it would still be there on any Riv you find. Probably a couple $ max, if they even charge you for it.
carguy8888
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. EmptyThu Mar 21, 2019 8:57 pm
The suspense was killing me so I went out to take another look to see what I was missing. Here is a better picture and I do have a trunk weatherstrip. Do you still think I'm missing something?
Shrinking rear window molding. 20190321_205333
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. EmptyThu Mar 21, 2019 9:37 pm
Nope, that big rubber weatherstripping is what I was thinking was missing. Are you sure its on properly? If you look in the picture I posted, the weatherstripping covers the entire flat lip of the trunk. It looks like you can see about an inch of that lip in your picture. I dont think thats normal.
carguy8888
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. EmptyThu Mar 21, 2019 9:46 pm
It is, I felt wetness when I stuck my hand behind the black filler piece but we filled it last week. There must be another area that is open. Sucks.
» rzr rear window
» Jagged X rear Window
» Mod to open the rear window with the key fob or door unlock button
» Rear Window Prop
» Friday ride ?
