 Shrinking rear window molding.
Go to page : Previous  1, 2
Shrinking rear window molding. - Page 2 Empty
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. - Page 2 EmptyThu Mar 21, 2019 9:55 pm
have you tried pouring water down the back windshield and surrounding areas with the trunk open so you can watch for holes?
carguy8888
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. - Page 2 EmptyThu Mar 21, 2019 10:00 pm
We did it with the trunk closed and a guy in the trunk.
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. - Page 2 EmptyThu Mar 21, 2019 10:17 pm
What were the results? Was the person in the trunk able to identify where the leak was coming from?
carguy8888
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. - Page 2 EmptyThu Mar 21, 2019 10:25 pm
Yes behind that black plastic piece but I guess there's still an issue.
carguy8888
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. - Page 2 EmptyFri Mar 29, 2019 6:42 pm
Here is an update. I just got back from the body shop and he lifted up the trunk and it does not look like the trunk hinges we're leaking at all but he did reseal the holes. He also lifted up that rubber gasket that goes from the trunk almost to the back doors, scraped out all the seam sealer and put new. I was really hoping I was going to see a hole or some smoking gun to say ahh that's it but I hope this works.
If this doesn't work the only thing we can think of is its getting underneath the gasket of the rear window. Does this ever happen? I got in the trunk with a flashlight and there are no big stain marks or trail of with water is entering.
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. - Page 2 EmptySat Mar 30, 2019 11:07 am
No. It's the seam under/around the hinge that you've already been told about. If water was getting in through the window seal, you'd have water inside the cabin. Many, many Rivs have had this problem. there is no hole, there is no "AHA", it's the seam, or water getting in through the bolt holes. Take the hinge off, clean the area underneath, put a bead of sealer down, and reinstall the hinge.
Merit : 153
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. - Page 2 EmptySat Mar 30, 2019 12:29 pm
u
..the insight here is the water can twist and turn a bit as it drips down. It will not be apparent until you actually remove the hinge, only then you'll see the silt the water left behind as it wandered down.
The other things that come to mind are (a) you'll have to remove the trunk liner to see the water (b) because the seam catches and holds the water it's sometimes the case that you flood the area with water and see no drips right then, then later when the water finally wends its way through stuff is wet and you're saying "What?? What??"
Finally, if you *did* take off the trunk lid and hinges it would be a lot easier to check the seams all around including under the window.
Albert
carguy8888
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. - Page 2 EmptySat Mar 30, 2019 4:58 pm
My guy did take off the trunk hinges and seal the holes. I guess I was just looking for a rust Mark or something to say oh that's it but maybe I got it. Good to know that I don't have to deal with the window because it will leak inside the car. All of the max are still out and I guess time will tell or I will have to get in the car again and try and see if I can find a trail but I did look pretty good. thank you both for great help, sometimes things don't translate in type the same as when you speak them.
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. - Page 2 EmptySun Mar 31, 2019 7:59 am
I had the same problem.  The big leak was around the trunk hinges and I also had to replace the dried up seam sealer in the joint next to the hinges.
http://rivperformance.editboard.com/t6869p100-faq-wet-carpet-interior-leak-problems
carguy8888
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. - Page 2 EmptySun Mar 31, 2019 11:47 am
My car is out in the rain now so I guess we'll see what happens lol.
Merit : 153
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. - Page 2 EmptyMon Apr 01, 2019 9:49 am
It's not an easy problem.
carguy8888
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. - Page 2 EmptyMon Apr 01, 2019 11:00 pm
I may be close? During the latest rainy day the spots were dry below the hinges but there was still water in the spare tire well. My handy buddy & I went to a gas station with a self serve car wash. He must have been facing the other way when I was blasting the back of the car with the pressurized water. He found water entering through the rear body panel above the tail lights hidden in the corner just below the trunk lid. He cleaned it and put some por 15 on it, one night this week we will seal it with silicone and hopefully it is good so I can concentrate on something else lol. Thank you everybody for the help and I will update once I know something.
Merit : 153
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. - Page 2 EmptyTue Apr 02, 2019 8:18 am
...sounds like multiple points of entry. Good troubleshooting so far. You may not be done.
carguy8888
PostSubject: Re: Shrinking rear window molding.   Shrinking rear window molding. - Page 2 EmptyThu Apr 11, 2019 11:06 pm
Thank you, I think I got it. I blasted it again at the car wash wit the pressure hose and it stayed dry so I put humpty dumpty back together.
» rzr rear window
» Jagged X rear Window
» Mod to open the rear window with the key fob or door unlock button
» Rear Window Prop
» Friday ride ?
