 replacing exhaust manifold - request for input
Merit : 137
PostSubject: replacing exhaust manifold - request for input   Sun Mar 03, 2019 11:05 pm
My front exhaust manifold cracked (after 36x,xxx miles) and I'm replacing it.  I pulled a used manifold (did not think Dave's was still for sale), got OEM (Felpro) metal sandwich gaskets from RockAuto and have replacement bolts on the way from ZZP (they are not here yet).
Got the junkyard manifold because I'd read that the 'new' replacements were not so good.
I'd like to know what you suggest I must do / should do to the replacement,  before R&R the manifold.   No comment too small or unwelcome - apart from pulling the old one without destroying it, I pretty much need to be told what I must do/should do from here forward.
I was thinking to clean it, myself, or take to a machine shop as well as have the shop check for flatness to .020" or so and plane it if needed.
I also was thinking I might:
- paint it (black or silver)
- port it (although I do not plan to port the block)
Constraints - I should to do stuff to it this week, and R&R it this coming Saturday morning.
Comments?  Thanks in advance.
Merit : 111
PostSubject: Re: replacing exhaust manifold - request for input   Mon Mar 04, 2019 12:38 pm
Albert, if that happened to me, I'd replace it with this,
https://zzperformance.com/products/stainless-power-log
That front exhaust manifold is the most restrictive part of the Riv exhaust.
Merit : 179
PostSubject: Re: replacing exhaust manifold - request for input   Mon Mar 04, 2019 1:51 pm
Not much you really can do to it prep-wise unless you let it sit. I'd spray the crossover studs with penetrating spray and let them soak for a couple days. The manifold job itself is easy. I think by sending it to a machine shop, you may be going a little overboard. Unless that junkyard manifold was sitting on something funny for years, it should be straight....especially if it was bolted to an engine. Even then, that's what the gaskets are for. If it were meant to be a perfect, machined surface there would be no gasket.
I like Larrys idea about the P-log....
Merit : 111
PostSubject: Re: replacing exhaust manifold - request for input   Mon Mar 04, 2019 2:06 pm
Looks like that P-Log is currently unavailable. My friend Steve (71stagegs) just installed one. Maybe he will comment.
Merit : 137
PostSubject: Re: replacing exhaust manifold - request for input   Mon Mar 04, 2019 2:57 pm
I emailed ZZP about availability of new or used P-log. We'll see. Would be good to have comment from Steve.
Merit : 111
PostSubject: Re: replacing exhaust manifold - request for input   Mon Mar 04, 2019 3:24 pm
I just talked to Steve, he said he will be on later to comment.
Merit : 137
PostSubject: Re: replacing exhaust manifold - request for input   Mon Mar 04, 2019 3:32 pm
I removed the replacement manifold from the NA 3800 Series II engine on an '01 Park Ave (not ultra) at the nearby pick-n-pull. I could not decipher the windshield scrawl (usually they mark if the engine/transmission/what not are good/bad and the mileage overall) on the car. Engine still had the *original* numbered wires but they were so welded to the plugs, I broke a couple plugs trying to get the wires off. And you could read the cyl numbers printed on the coils. Dipstick oil looked good, though.
I sprayed Deep Creep on the crossover and manifold bolts and had *no* trouble getting them loose on the donor car. I mean, *zero* issues. Gasket was the GM OE metal sandwich.
I had trouble getting the bolts away from #2 port because I didn't know where the heatshield bolts were (have to loosen heatshield by the ig module first) and I had a little difficulty getting the ig module off (ground plate corrosion - need to move it, the cable blocks the wrench somewhat). The dipstick was a pain too, I think my problem there was it was cold and I was stiffening. It would have been easier to pull off the manifold from the Series III SC grand prix, in hindsight. There is a heat shield on it but nothing of consequence in the way except those dogbones on the radiator support.
I told my dad about the manifold pull and he talked about getting a new one, "they crumble when they come off" I told him yeah maybe if you're ham handed doing the pull. They do a pretty good job casting them in Warren and all you have to do is back the bolts out in about the reverse order you would torque them down, the manifold is not on that tight to begin with, so after 3-4 rounds of a 1/4 turn backing off each one in a spiral from outer to inner, you're home free. As for my manifold cracking - they eventually all do I am told, if you run them long enough. Mine accumulated 20 years of use (363000 miles give or take) before developing a crack.
I won't send the manifold to a machine shop for flatness but will check it with a straightedge (don't have a gauge). I am not sure porting this manifold will buy me much, except that I can say I did it. I *just might* take it to a machine shop for cleaning however it seems to me that a can of brake or carb cleaner and an alumium roasting pan ought to do the job.
Fun & games. 4 days to go. Saturday's supposed to be OK (above 40F).
Merit : 137
PostSubject: Re: replacing exhaust manifold - request for input   Mon Mar 04, 2019 3:46 pm
...thank you Larry & Scott for your input so far!
71stagegs
71stagegs
PostSubject: Re: replacing exhaust manifold - request for input   Mon Mar 04, 2019 7:16 pm
Hey Albertj If that manifold doesn't work out u can have my old manifold Ill put it in the mail.I put the ZZP Plog on and could hear and feel the difference.That said a week before I put 3"DP and hi flow cat on so maybe they work together. When u took off the manifold were u shocked at the bad design a 1/3 of the port is not fully open then 3 cylinders exit through that small tube must have been the same guy that designed the steering column.Im sure u know already I used 6 point socket on all bolts and put some heat on the crossover pipe bolts good luck.Dipstick is a PITA . Steve
Merit : 137
PostSubject: Re: replacing exhaust manifold - request for input   Tue Mar 05, 2019 1:39 am
Thanks!  From an earlier adventure I already have a larger downpipe.  Still have the Factory crossover.  And yes the front exhaust Manifold is a study in backpressure, not sure why they did that.   Maybe noise?
I have the crossover bolts complete, did not buy replacements from ZZP.  I have the manifold bolts new from ZZP.   I am not expecting trouble getting the old one off.  When I pulled the JY manifold I used 6 point sockets and 'Deep creep,' worked great.
ZZP E-sales has P-logs, ha ha: https://www.ebay.com/itm/ZZPerformance-1997-08-Front-Powerlog-Stainless-Exhaust-Manifold-Header-3-8L-3800/173782973285?hash=item287645bb65:g:ligAAOSwKrhVZJP-
Ryan  got back to me from ZZP saying they will have more P-logs soon...
Again, thanks for your offer and comments. I will give the dust a few hours to settle.
One last thing - is the P-Log drone-y or noisy when cruising on highway?  That's  a problem foe me if so.
71stagegs
71stagegs
PostSubject: Re: replacing exhaust manifold - request for input   Tue Mar 05, 2019 11:17 am
Hey Albertj I didn't notice anything change in motor noise. its a good up grade good luck.Did you ever put the rear sway bar on that's another good up grade.
Merit : 111
PostSubject: Re: replacing exhaust manifold - request for input   Tue Mar 05, 2019 11:37 am
That's about a thousand dollars more than they sell them for lmao Is anybody that desperate or stupid?
Merit : 137
PostSubject: Re: replacing exhaust manifold - request for input   Tue Mar 05, 2019 6:04 pm
I don't know how ZZP's eBay sales re managed. Ryan's talking 3 weeks from now, until they receive more P-logs. One would think the eBay ask would be $116.99 or so.
What I'll do:
- clean the manifold I got off that Park Ave at the JY;
- maybe port it (a nearly pointless exercise, operative word however is "nearly");
- maybe paint it if it got clean enough;
- try not to break it on the install (if so I will accept 71stagegs' generous offer - I appreciate it)
- R&R a P-log later - as many as ZZP have sold, a used one may appear...
I think I should get the cleanup done tonight.
Finally -- I **REALLY** appreciate the input. I want the Powerlog but I'm not apparently going to obtain one at fair price in time for this repair, and that's OK.
71stagegs
71stagegs
PostSubject: Re: replacing exhaust manifold - request for input   Tue Mar 05, 2019 8:05 pm
albertj forgot to tell u if you have any body and paint supply stores near u pick up some 80 green long board sand paper put it on a long board make a few passes that will clean up the surface well for the new gasket.
Merit : 137
PostSubject: Re: replacing exhaust manifold - request for input   Wed Mar 06, 2019 10:14 am
Thank you I will do that.
Was just going to use 3M Utility Cloth I think I have sitting around, I think it's 100 or 120. Did not know I could use 80, it'll save me some time.
Merit : 137
PostSubject: Re: replacing exhaust manifold - request for input   Sat Mar 09, 2019 11:21 pm
I ported the JY manifold today.  Used a Dremel with a carbide bit to do the rough cut then a drill with fairly large bullet-tip stone to finish.   It was interesting how quickly the Dremel cut.
One thing was a little weird.  On the ZZP site I think part of the reason for buying a P-log is the ID of the manifold is too small at the crossover.  I did not see that on the JY manifold.  And porting it was not difficult -- basically at the inlets there is flash more or less on the inside of the ports to remove.  I mean, you could call it flash, but it is material that makes the mounting surface a uniform width.  It is not difficult to bevel it so that the openings are the same as at the gasket, and not that much material has to be removed.
I then sanded the mounting flange flat using a piece of 3M sandpaper taped to a short (16") length of 2x4. Did not have 80 around, so I used 100.
Now I have a stupid issue... need to get an in-lb torque stick, mine is ft-lbs and won't read at the light torque for the manifold... figures...
Ever onward.   Thanks again everyone for your help!
Merit : 137
PostSubject: Re: replacing exhaust manifold - request for input   Tue Mar 12, 2019 6:48 pm
The (ported) manifold is on. No issues. Less than 2 hours effort.
So much for this adventure.
Thanks again everyone.
Merit : 179
PostSubject: Re: replacing exhaust manifold - request for input   Wed Mar 13, 2019 9:37 am
Easy-peasy thumbsup
Merit : 137
PostSubject: Re: replacing exhaust manifold - request for input   Wed Mar 13, 2019 11:25 am
Epilogue: My 'butt dyno' says the porting effect is that the engine seems to wind out (accelerates) more rapidly. Truth -- knowing that leak is fixed would be enough to make my 'butt dyno' happy... I'll know this weekend if there might be a gas mileage effect in highway cruising. I seriously doubt it, though, but I am not sure how long the old EM had been leaking and I did not log a scan so I don't know if or how far it threw the O2 sensor off and maybe made the engine computer maladapt.
» anybody have a factory exhaust manifold?
» New Custom Briggs Opposed Twin Exhaust?
» Custom dual exhaust on a Twin 16 Briggs & Stratton and some old build pics
» Movember Gift- Support & Sponsorship Request Letter 2010
» Looking for HMF exhaust
