 Motor died today.
Go to page : Previous  1, 2
Motor died today. - Page 2 Empty
PostSubject: Re: Motor died today.   Motor died today. - Page 2 EmptyThu Mar 28, 2019 8:36 am
Does the bolt need to come off?  Why would the plug receptacle need to come off the firewall?
I'm sure this plug has never been pulled.
The bolt stays with the connector that you are removing.....the female side.
If it's possible, you can spray some WD40 between the 2 connector bodies and let it soak overnight. This might loosen the pair enough to get movement. Once it starts moving, you'll be able to get it apart.
No, WD40 won't hurt the connections. It's actually an excellent terminal cleaner.
EDIT: Shit....that big ass connector doesn't have a 7mm in the center of it clamping the 2 together?
I just looked at the pic closer.
Merit : 111
PostSubject: Re: Motor died today.   Motor died today. - Page 2 EmptyThu Mar 28, 2019 11:55 am
Yes it does.  You aren't going crazy Scott. lol  Look at my second picture, you can see the threaded part of the bolt on the front section.
https://2img.net/h/i172.photobucket.com/albums/w20/SLD1624/Connector2R.jpg
PostSubject: Re: Motor died today.   Motor died today. - Page 2 EmptyThu Mar 28, 2019 1:48 pm
Well I wonder if that was my problem all along!
PostSubject: Re: Motor died today.   Motor died today. - Page 2 EmptyThu Mar 28, 2019 4:31 pm
Phew! I feel better now. lol
Jack, does the connector back itself out to an extent when you're unbolting it (it should), or does the bolt just seem to turn?
PostSubject: Re: Motor died today.   Motor died today. - Page 2 EmptyThu Mar 28, 2019 7:54 pm
If you're talking about the one hiding in the black plastic tunnel, I was going to ask what size and type of driver it takes, because I can't see what's in there. I tried a phillips, but that didn't seem to engage.
PostSubject: Re: Motor died today.   Motor died today. - Page 2 EmptyFri Mar 29, 2019 10:47 am
It should be a 7mm
PostSubject: Re: Motor died today.   Motor died today. - Page 2 EmptySun Apr 14, 2019 8:36 pm
I ordered some electonics cleaner and sprayed the connections down good. The plug came out super easy once I removed the hidden 7mm bolt. Now I can rule out this problem. Would a bad crankshaft position sensor also cause a miss?
Motor died today.
» Jimmy Ellis - Former WBA Heavyweight champion died today at 74 !!
» Whitney Houston Died today
» For all the American Troops that died in the chopper crash today...
» Turnigny 1230 motor
» Small outrunner motor
