 Shaking at high speeds.
carguy8888
Shaking at high speeds. Empty
PostSubject: Shaking at high speeds.   Shaking at high speeds. EmptyMon Jun 10, 2019 12:24 pm
I feel some shaking coming from the back of the car when on the highway. I just installed new tires and the shake was there both before and after. I watched the wheels get balanced and asked the tech to check if any rims were bent. He said the numbers would not be this good if any rims were bent. anything in particular on the rear suspension I should look at in particular? Maybe the bushings are original and 20 years old on a really rusted bottom.
Merit : 148
PostSubject: Re: Shaking at high speeds.   Shaking at high speeds. EmptyMon Jun 10, 2019 1:47 pm
You have to get it in the air and shake/spin/twist parts to find the cause.
I replaced all my rear end bushings (at about 175K miles I think) just because. Not sure I needed to - they don't take a flogging on this car like they do on say a GM minivan or an Audi.
carguy8888
PostSubject: Re: Shaking at high speeds.   Shaking at high speeds. EmptyMon Jun 10, 2019 1:56 pm
That's exactly what I'm going to do, I was just curious if they were any usual suspects.
Merit : 148
PostSubject: Re: Shaking at high speeds.   Shaking at high speeds. EmptyMon Jun 10, 2019 3:13 pm
I am not aware of any for the rears, except for wheel balance, bad shocks, bushings.
carguy8888
PostSubject: Re: Shaking at high speeds.   Shaking at high speeds. EmptyMon Jun 10, 2019 3:36 pm
I guess I should hope for bushings or maybe a u joint?
Merit : 148
PostSubject: Re: Shaking at high speeds.   Shaking at high speeds. EmptyMon Jun 10, 2019 5:25 pm
No.
You're throwing darts talking about u-joints, there are *none*.
Again - you have to get it in the air and shake/spin/twist parts to find the cause. You may find perusing the FAQs and how-to's useful. FOr instance it coul be a wheel bearing BUT the ABS sensors are integrated into the bearings and they usually act up well, well before the bearing is that shot. And if you don't get crap rear wheel bearings to begin with, they will last well over 100,000 miles.
Also, the factory manual has a pretty good section on fixing NVH (noise, vibration, harshness) problems although it often uses a funky tester (which you don't need all that much if you actually read the section). Point is, if you don't have the factory manual for your car yet, get a set.
carguy8888
PostSubject: Re: Shaking at high speeds.   Shaking at high speeds. EmptyMon Jun 10, 2019 6:15 pm
I do have my owners manual but I absolutely will get it on a lift.
DeepFrozen
PostSubject: Re: Shaking at high speeds.   Shaking at high speeds. EmptyTue Jun 11, 2019 4:34 am
carguy8888 wrote:
... He said the numbers would not be this good if any rims were bent.
That's not quite true. Technically, any solid object can be balanced - a brick, for example.
In practical terms it means that even perfectly balanced wheel can cause vibrations.
Merit : 148
PostSubject: Re: Shaking at high speeds.   Shaking at high speeds. EmptyTue Jun 11, 2019 5:05 pm
+1 that. The Riv likes tires that are actually round... my Continental was much more tolerant of tires than the Riviera is. Hands down.
Here's some light reading for everyone - one shop's opinion:
https://www.souzastireservice.com/tires-101/shakes-and-wobbles.aspx
carguy8888
PostSubject: Re: Shaking at high speeds.   Shaking at high speeds. EmptyTue Jun 11, 2019 10:38 pm
It certainly could need to be rebalanced, I'm going to try and stop by my shop tomorrow after work and see if they can throw it on the lift.
carguy8888
PostSubject: Re: Shaking at high speeds.   Shaking at high speeds. EmptyWed Jun 12, 2019 9:41 pm
My trusted really good mechanic went through the whole car and found nothing wrong, glad he was honest. I guess I'll try rebalancing the wheels.
nickwon
PostSubject: Re: Shaking at high speeds.   Shaking at high speeds. EmptyTue Sep 10, 2019 3:58 am
Did the re-balancing solve your problem?
carguy8888
PostSubject: Re: Shaking at high speeds.   Shaking at high speeds. EmptyTue Sep 10, 2019 9:56 am
On the second round oh, another mechanic found my right rear wheel is a little bent.
Merit : 148
PostSubject: Re: Shaking at high speeds.   Shaking at high speeds. EmptyTue Sep 10, 2019 10:00 am
The repair manual, not the owner manual.
Merit : 111
PostSubject: Re: Shaking at high speeds.   Shaking at high speeds. EmptySat Sep 14, 2019 4:15 am
Would you like to buy a set of Factory Service Manuals for a 99 Riv in like new condition for half of what I paid for them.?
I bought them for a previous member of this forum and after I bought them for him he disappeared.
Anyway, Very Good condition for $25.00 plus shipping. Books are cheap to ship via USPS.
Let me know.
Rick
carguy8888
PostSubject: Re: Shaking at high speeds.   Shaking at high speeds. EmptySat Sep 14, 2019 10:35 pm
That sucks, fortunately I'm smart enough to know I'm not handy LOL. I live in New York City so there's nowhere for me to do it anyway. Thank you very much for the offer.
PostSubject: Re: Shaking at high speeds.   Shaking at high speeds. EmptySat Sep 14, 2019 11:34 pm
Mine does the same thing but only between 65 and 70 mph. Nothing below or above that speed.
Merit : 148
PostSubject: Re: Shaking at high speeds.   Shaking at high speeds. EmptyMon Sep 16, 2019 8:51 am
At that price, what you do is buy the manuals then leave them in the trunk when your car is in for service -- there is enough esoteric about the Riv that the mechanic will be able to do a better job if you have them than if you don't because the syndicated data sources skimp on details, although they are better than they used to be.
Merit : 148
PostSubject: Re: Shaking at high speeds.   Shaking at high speeds. EmptyMon Sep 16, 2019 8:57 am
My car is in the shop today for exactly that problem, we narrowed it down to the CV joints (most likely inners) on the left front axle. (I also suspect the inner tie rods but those supposedly are good. Rack is seeping though). My left axle is *original* Saginaw with 370,000+ miles on it. The vibration is a PITA. When you apply brakes the vibration goes away (so it's not wheel/brake). Checked round and runout, both quite good. No evidence of belt or carcass issues on tires. Alignment good.
carguy8888
PostSubject: Re: Shaking at high speeds.   Shaking at high speeds. EmptyMon Sep 16, 2019 9:54 pm
Those miles, that is amazing.
Merit : 148
PostSubject: Re: Shaking at high speeds.   Shaking at high speeds. EmptyMon Sep 16, 2019 11:31 pm
Car's back, shaking's gone. Road Trip time.
Merit : 111
PostSubject: Re: Shaking at high speeds.   Shaking at high speeds. EmptyTue Sep 17, 2019 3:55 am
Your only shaking at High Speeds, Dang, I've been shaking at all speeds lately. happy
Well Albert, don't leave us hanging. Was it the CV joint and axle assembly as you suspected.
I have to agree with carguy8888, it is amazing the number of miles you have on your car. It's a testament to your personnal preventive maintenance program.
If I had continued with the income I was used to getting, I'd still have my Riv, but I fell behind on the rust and rot issues then the paint was gone to the point that I would have needed a complete paint job.
There was a period of time that I not only was able to do the PM items but I would bring it to my body shop just about every year for some kind of sanding, priming and painting with PPG paint. They weren't cheap but they were good, actually excellent. Never saw a flaw in their work.
I know you have mentioned that you have a body shop that you bring your car to periodically to keep up with the appearance and you always keep up with the mechanical issues.
So, I guess it's no surprise that your Riv is still going strong after 300K miles.
Merit : 148
PostSubject: Re: Shaking at high speeds.   Shaking at high speeds. EmptyTue Sep 17, 2019 12:55 pm
The axle contributed some; tires contributed some but it was really subtle; also probably contributing was a stupid problem with the steering rack (slightly loose mount bolt).
Merit : 111
PostSubject: Re: Shaking at high speeds.   Shaking at high speeds. EmptyWed Sep 18, 2019 6:43 pm
Well, after giving this some more thought I would be writing GM a letter and complaining that my front axle only lasted 370,000 miles on my 20 year old Riviera and what are you going to do about it before I get the legal dept involved. smile
carguy8888
PostSubject: Re: Shaking at high speeds.   Shaking at high speeds. EmptyWed Sep 18, 2019 8:39 pm
Nice lol.
» Pickering High School Ball Team On THE SCORE
» Interesting post on NERR High shool vs Prep school
» Stonnington Gift Media Release - High Class Field Set
» high hook technique
» Pickering High Trojans
