 project shocks n strutts help
Go to page : Previous  1, 2
Rivieraz
Rivieraz
project shocks n strutts help - Page 2 Empty
PostSubject: Re: project shocks n strutts help   project shocks n strutts help - Page 2 EmptySat Jul 13, 2019 11:51 pm
will Gabriel quick struts work on my 95 riv, because all I can find them for is 98 and newer. do all the shock fit the same from 95 to 99 … ps are unity shocks any good
Merit : 147
PostSubject: Re: project shocks n strutts help   project shocks n strutts help - Page 2 EmptySun Jul 14, 2019 11:03 am
The control arms differ between 95 and 98. And 97 ( a one-off). So AFAIK the 95 struts wont fit a 98 without other work.
I've no idea whether Unity struts are any good, nor any idea who actually makes them. Looking at the company web site, none of the personnel are involved with manufacturing. They have component assembly and packing. https://unityap.com/
diggerled
diggerled
Name : dan ledbetter
PostSubject: Re: project shocks n strutts help   project shocks n strutts help - Page 2 EmptySun Jul 14, 2019 12:39 pm
Huh.  Maybe you should drop Rock Auto a line anyway and let them know what happened.
I did make an attempt. They rejected my advise and complaint. As an online only store, they have no phone number. I used the "report a problem" link. My order has now been flagged as "not returnable" leaving no other avenue to draw attention. I could write a letter and mail it but I suspect there is no one employed there to read paper mail.
PostSubject: Re: project shocks n strutts help   project shocks n strutts help - Page 2 EmptySun Jul 14, 2019 2:43 pm
Well, "A" for effort then. I'm glad you found a fix.
Rivieraz
Rivieraz
PostSubject: Re: project shocks n strutts help   project shocks n strutts help - Page 2 EmptyMon Jul 15, 2019 7:46 pm
Rivieraz wrote:
MONROE MA822 shocks MONROE AK29 air hose kit ACDELCO 19210500 rear lower shock mount ACDELCO 901046 rear mount ACDELCO 45G0000 stabilizer MONROE 71822 strut MONROE 902930 front mount hopefully I have all parts covered ?any suggestions are welcome.... all for my 95 Riviera 429.00 in parts and Monroe wanted 2000 for parts and labor
after futher inspection my air pump the nipple for the hose is worn off the compressor so for now I ran the ak29 air kit to my stock shocks and they still hold air it has  been 3 days and still 20 lbs of pressure... can the nipple be replaced???
Merit : 147
PostSubject: Re: project shocks n strutts help   project shocks n strutts help - Page 2 EmptyWed Jul 17, 2019 12:17 pm
RockAuto, LLC business office:
6418 Normandy Lane
Madison, WI 53719
(608) 661-1376
...This was not hard to find.
PostSubject: Re: project shocks n strutts help   project shocks n strutts help - Page 2 EmptySat Jul 20, 2019 2:57 pm
No, the outlet nipple can't be replaced per say. It is cast aluminum as is the whole housing for the pump.
It would be easier and cheaper to just get a pump from a Pick and Pull junk yard or elsewhere, that you know works.
I had a problem with the air compressor on mine when I bought the car and it was all related to corroded cast aluminum.
I replaced the pump and never had to touch it again. Other than changing the intake filter on it a couple of times. Just preventive maintenance. When I did that I would spray the pump down with anti-corrosion fluid.
Specifically ACF-50. Had a few cans from one of my previous jobs.
ACF = Anti Corrosion Fluid.
It's used in aircraft and many other applications. Available on the web. I think Amazon might even sell it. Before each winter here in the Northeast, where they use way to much salt on the roads in the winter, I would have the undercarriage cleaned then bring it to a friend that had a lift and spray the whole underbody of the car.
He moved away several years ago so my car ended up rotting from the bottom up.
Rivieraz
Rivieraz
PostSubject: Re: project shocks n strutts help   project shocks n strutts help - Page 2 EmptySun Jul 21, 2019 1:06 am
thankyou! very helpful i'm in the north east.
» Project Peenemünde!
» Project 45 For Sale
» Cheap go kart project
» Rhino Sport Shocks
» Fox Podium Shocks up-grade
