 Will 15" rims fit my 98
snerkman
snerkman
Will 15" rims fit my 98 Empty
PostSubject: Will 15" rims fit my 98   Will 15" rims fit my 98 EmptyMon Nov 25, 2019 8:38 am
I have a set of 15" steelies from my old Deville. Bolt pattern, bore and offset will work but I don't know about brake clearance. Was thinking of throwing a set of winter tires on them. I have a bad back so thought I'd ask before making the effort of taking a wheel off to check.
Merit : 111
PostSubject: Re: Will 15" rims fit my 98   Will 15" rims fit my 98 EmptyMon Nov 25, 2019 1:47 pm
Hard to say. The easiest thing to do is to bolt the wheel on before mounting tires on them. Stock 1995-99 Buick wheels are 16 X 7" with +42mm offset, so back spacing is about 5.65". What do the Deville wheels measure?
snerkman
snerkman
PostSubject: Re: Will 15" rims fit my 98   Will 15" rims fit my 98 EmptyMon Nov 25, 2019 9:09 pm
That would be the easiest thing to do if I had a healthy back. I asked to see if somebody already knows.
Merit : 111
PostSubject: Re: Will 15" rims fit my 98   Will 15" rims fit my 98 EmptyTue Nov 26, 2019 2:49 pm
Yeah, I understand, but it's pretty unlikely that anyone here has even attempted this.  They usually go for bigger 17 or 18" wheels.  Maybe get a friend or relative to assist you? Where do you live?
» Polaris tires and rims
» How to get rims and hubs off stuck axles.
» 2009 RZR LE black stock rims/tires
» Factory Rims WTB
» ATV rims for a Rhino?
