 Restoration Pics
98inWPB
Restoration Pics - Page 3 Empty
PostSubject: Re: Restoration Pics   Restoration Pics - Page 3 EmptyFri Jan 31, 2020 7:50 am
I really struggle with the wheel/tire issue, and customization in general.  16's and big wheel wells are very out of fashion, but the Riv rides so well on the stock suspension and tire package.  I don't do a lot of corner carving.  Handling is more cool than ride quality but I get more use out of ride quality.
Now that there are so few Rivs out there, I lean more towards keeping it stock and having another car for performance.
Totally sympathize, I play on both sides of this issue with many projects, aside from resurrecting the thing from under trees using parts of 12 cars, the Riv is one of those where I have mostly left it stock, the interior/body 100% stock, engine, a few bolt on items, suspension (so far) stock. Rims that came on it ,not my taste nor am I into aftermarket.  Impala wheels went on, same size, ran that for a decade, time for a change, I do carve corners as well as use this thing for cushy highway trips...the parts car has another set of the same unloved gray original wheels, ugh, not only that,  Im low on delicate hubcaps.
I would consider a set of original chrome/alloy wheels if they were in good shape but that does not help with my surplus, freeish, race rubber.
Saying all that, where do I find a list of CD player error codes? I have 2 units with different errors and a stack of 96-2002 chevy truck radios I might be able to scab for internal parts.
What is the go to for antenna replacement? Is the plastic internal pusher still available somewhere?
98inWPB
PostSubject: Re: Restoration Pics   Restoration Pics - Page 3 EmptyFri Jan 31, 2020 8:29 am
Fuel pump installed, not impressed with the aftermarket making me cut the harness but its too late for that. The last unit was AC Delco, and did not give the life hoped for, it is what it is, I have a warranty, the used unit, and AAA if this one quits.
Restoration Pics - Page 3 49461568543_a45d59cb48
Best trunk lock out of 3 choices, I still wonder where the original gold one went off to, pretty sure that and the gold grille were beyond use but memory fails.
Restoration Pics - Page 3 49462280152_1bd38e77a5
I stopped taking this off the parts car to admire 15 years of never being cleaned
Restoration Pics - Page 3 49462048271_f3b7e5f6fa
Fortunately there was no real lasting damage
Restoration Pics - Page 3 49461576538_c35e33e5fd
Could use some new clips but these should hold for a while
Restoration Pics - Page 3 49462047616_01b898f7c7
Restoration Pics - Page 3 49462278937_045b1acecb
The outgoing interior will store better if cleaned, everything is dusty and smudged from touching, off to the car wash again for a 3 woman crew to get it right.
Restoration Pics - Page 3 49462046661_4df92f03dd
98inWPB
PostSubject: Re: Restoration Pics   Restoration Pics - Page 3 EmptyFri Jan 31, 2020 2:45 pm
Well that came fast
Restoration Pics - Page 3 49469334621_8a94c7108b_k
Merit : 153
PostSubject: Re: Restoration Pics   Restoration Pics - Page 3 EmptyFri Jan 31, 2020 5:20 pm
Yep. Looks like a good match, what do you think?
PostSubject: Re: Restoration Pics   Restoration Pics - Page 3 EmptyFri Jan 31, 2020 6:17 pm
Ohhh yeah..... It is a good match
98inWPB
PostSubject: Re: Restoration Pics   Restoration Pics - Page 3 EmptyFri Jan 31, 2020 8:15 pm
It will do nicely
Anyone here have a non sunroof car? I have a dome light question.
PostSubject: Re: Restoration Pics   Restoration Pics - Page 3 EmptySun Feb 02, 2020 7:48 am
You asked about a replacement antenna.??
I may have a good used OEM antenna assembly if that's what your looking for.
I will have to check in my 2 storage units and have some parts boxed up in the cellar as well.
If your interested and not in a huge rush I can look for it for you. As I said, I may have one. My memory says I do. But my memory has failed me before. So I will need to look.
Let me know. Best to email me at IRRICKW at COMCAST dot NET
Rick
98inWPB
PostSubject: Re: Restoration Pics   Restoration Pics - Page 3 EmptySun Feb 02, 2020 9:16 am
Rick
Not in a terrible rush, this issue has come and been fixed several times over the years, haven't had one working in quite some time, I think the parts car just needs the mast nylon rope but with the high failure rate, for the right price, I would likely be interested in a working unit and sit on the other one.
Honestly, the last week looking at it with a perfectly painted piece of tape under the hole, has me feeling like we missed a opportunity to weld up the antenna and go with a hidden or shark fin type.
98inWPB
PostSubject: Re: Restoration Pics   Restoration Pics - Page 3 EmptySun Feb 02, 2020 10:53 am
Next round of pics, a major suspension issue: Aluminum control arm casting flaw.
Without going through the entire long story, in a unfamiliar, poorly lit area, at midnight, 150 miles from home, on a Sunday, after a long weekend, trough fault of my own,  I completely hopped a lightly curbed median @ <15mph ,first the left front, then right front, left rear, finishing off with the right rear... The RR suspension broke. I have no towing coverage at the time. No alcohol was involved.
This was the last straw and almost the lowest point that pushed this car towards restoration
I was hoping my buddy could find some pics of a year ago when this first happened, it clearly shows a casting flaw connected to a clean snap and explains why it broke even though the energy was mostly dissipated by the time this wheel hit. I see the buddy again this weekend on the Rivs first road trip since rescue, will remind him to look.
Ironically and luckily this buddy is a mechanical engineer, who at the time, was employed to stress test aircraft wings to the point of failure, fortunately he had a small workshop and materials on hand, we patched it and I was on the road in 90 minutes.
EDIT:* Added 1st picture after posting*
Restoration Pics - Page 3 49481208187_ac590c4ca0_c
Restoration Pics - Page 3 49457190057_eaa84d834e
Restoration Pics - Page 3 49456954486_2f8ea9391d
Restoration Pics - Page 3 49456959676_1b95de1643
Both cars inside on lifts to drop the rear subframe and swap lower control arms,
Restoration Pics - Page 3 49457187292_ca629005cb
Restoration Pics - Page 3 49456484863_b9065e40f3
Exhaust is in the way, kinda fortunate as I was planning to swap systems to get rid of my rattling cat and fix the LR muffler that has been slightly bent and bothering me ever since a bulldozer scooted the thing around 2 days before ownership started 14 years ago
Restoration Pics - Page 3 49456483178_e724c5b349
Damage while trying to drive the car a back to my buddy's place with the doughnut spare (regular tire was undamaged but leaning with that much camber while broken)
Restoration Pics - Page 3 49456483713_63af3f8561
Parts car has been sitting too long frown
Restoration Pics - Page 3 49457229942_b4a9121f48
Restoration Pics - Page 3 49456525638_109003300a
Score
Restoration Pics - Page 3 49456483698_95d068e534
Factory rotor clips still on both cars
Restoration Pics - Page 3 49457187272_6bc8546ef1
Oh Joy, something new and for later, subframe bushings are bad
Restoration Pics - Page 3 49456954461_a6e4f0ea36
PostSubject: Re: Restoration Pics   Restoration Pics - Page 3 EmptySun Feb 02, 2020 2:38 pm
PM sent.
PostSubject: Re: Restoration Pics   Restoration Pics - Page 3 EmptySun Feb 02, 2020 3:34 pm
Ed see if you can go for the hidden type antenna. I think the factory mast antenna outdates the car IMO. The shark fin is way too ugly and not period correct. Get a hidden one and just stick it inside somewhere they are magnetic type. I'm thinking of doing this myself. Never liked the look of the car with the mast antenna.
98inWPB
PostSubject: Re: Restoration Pics   Restoration Pics - Page 3 EmptySun Feb 02, 2020 3:55 pm
stan wrote:
Ed see if you can go for the hidden type antenna. I think the factory mast antenna outdates the car IMO. The shark fin is way too ungy and not period correct. Get a hidden one and just stick it inside somewhere they are magnetic type. I'm thinking of doing this myself. Never liked the look of the car with the mast antenna.
Paint is done, in hindsight I missed opportunity to get rid of its hole, already PMing to get a working OEM unit.
Aside from the rims and leaving off all exterior badges, the exterior will remain stock as buick intended, antenna and all.
PostSubject: Re: Restoration Pics   Restoration Pics - Page 3 EmptySun Feb 02, 2020 4:24 pm
No,Ed I meant to say. Just disconnect the antenna and plug it in in the hidden one (magnetic one) . That`s all. This is how you keep the original factory look of the car, and get better radio reception. All of this you can do in 5 seconds.
98inWPB
PostSubject: Re: Restoration Pics   Restoration Pics - Page 3 EmptySun Feb 02, 2020 6:14 pm
The thought crossed my mind, I will look.
PostSubject: Re: Restoration Pics   Restoration Pics - Page 3 EmptySun Feb 02, 2020 7:11 pm
Just leave the factory antenna in unplugged , and plug the new one in. Stick it inside the trunk somewhere under the covers, it's magnetic. That's all. It'll take 5 seconds of your time hahaha. See if you like the idea
98inWPB
PostSubject: Re: Restoration Pics   Restoration Pics - Page 3 EmptySun Feb 02, 2020 10:07 pm
Have a model #? I will do it when the next unit goes.
98inWPB
PostSubject: Re: Restoration Pics   Restoration Pics - Page 3 EmptySun Feb 02, 2020 10:25 pm
Was successful in getting pics of the broken arm, I took the pic with and without flash to try and capture as much detail as possible with a cell phone mid repair @ 1am. The flaw was top where a mold (pour/injection?)point was, looks like the alloy was bubbly/spongy loosing some I beam strenth. Kind of looks like a wet spot but there was no moisture, just a color and texture change.
Restoration Pics - Page 3 49480753687_d7296faf7e_c
Restoration Pics - Page 3 49480535856_bf5bf87bfb_c
Restoration Pics - Page 3 49481208202_f23596a22c_c
Merit : 93
PostSubject: Re: Restoration Pics   Restoration Pics - Page 3 EmptyMon Feb 03, 2020 12:19 am
Yeah, but every other part does too.  The 8th gen has reached the point where it's most valuable as a time machine.  If you put new stuff on it, it won't be able to take you back anymore.
98inWPB
PostSubject: Re: Restoration Pics   Restoration Pics - Page 3 EmptyWed Feb 05, 2020 3:12 am
Today was interior work, Passenger seat out, headliner out, RR panel off, package tray and speaker tray out.
Restoration Pics - Page 3 49489574563_b0727376ab_c
Restoration Pics - Page 3 49490285902_28f90f888f_c
Interior sound deadening tar needs a bit of touch up.....Florida
Restoration Pics - Page 3 49490073891_b05be9322e_c
Restoration Pics - Page 3 49490284357_978667dda4_c
Package tray carpet red where the sun didn't shine
Restoration Pics - Page 3 49489575688_17e97fd7e4_c
Hidden dent from tree repair #1
Restoration Pics - Page 3 49489575383_6287cf5a43_c
Rear Interior out offers opportunity, off to the car wash to find persistent leak, found bad glue spot on back window...
Headliner done
Restoration Pics - Page 3 49490076211_976246e237_c
Restoration Pics - Page 3 49490647682_a43598dda0_c
Parts car consulted for rear tray/speakers/carpet, what is TOR. short for?
Restoration Pics - Page 3 49489576383_b7f86b1b9c_c
In hindsight a little premature as it is going back through the car wash tomorrow to verify leaks are plugged
Restoration Pics - Page 3 49490284602_815773077d_c
Restoration Pics - Page 3 49490284417_da944f7300_c
Merit : 153
PostSubject: Re: Restoration Pics   Restoration Pics - Page 3 EmptyWed Feb 05, 2020 8:57 am
"Tor." Stands for Toreador Red. An allusion to bullfighting. It is a blood red unlike the earlier wine red.
98inWPB
PostSubject: Re: Restoration Pics   Restoration Pics - Page 3 EmptyWed Feb 05, 2020 9:12 am
Thank you!
98inWPB
PostSubject: Re: Restoration Pics   Restoration Pics - Page 3 EmptyThu Feb 06, 2020 5:33 am
Back to the car wash, rear package tray pulled again I find another forgotten tell of history, apparently bit of extra window sealer fixed it.
Restoration Pics - Page 3 49494986412_60af89f057_c
Restoration Pics - Page 3 49495622543_08bb0d3616_c
There the leak is, looks like the 1/4 window needs pulled, yes this should have been addressed before paint but it did not, I was convinced the water on the floor had been coming from a different spot and the decision to get this restoration going was a bit abrupt. #majorscrewup
Restoration Pics - Page 3 49494767291_1199347162_c
Just so happens I have a windshield guy over today for a unrelated job
Restoration Pics - Page 3 49496116206_f35390e90e_c
Regardless of precautions, the window removal did not go well, paint chipped, with my painter friend long gone I am back to being a 1 man band with way too many instruments to play. Undecided how this will get touched up, regrettably need shove this to a later date.
Restoration Pics - Page 3 49496114551_037c4c1ebf_c
Window back in but interior still partially stripped, no time to fuss around any longer, first road trip in a year scheduled tomorrow noon, onto the next nag, cruise control inop. Being the cruise module is easier to swap then diagnose the entire system, and literally its the last minutes of the workday, I get lucky and the swap fixes it.
Restoration Pics - Page 3 49496116416_300b847f68_c
Worried about the used radiator scabbed from parts car, with this trip in mind the whole time, I had been driving quite a bit to be sure, fingers crossed, no leaks found, fluids topped off, I will be back next week to continue.
Merit : 153
PostSubject: Re: Restoration Pics   Restoration Pics - Page 3 EmptyThu Feb 06, 2020 8:22 am
Only rad failure I had was at about 165K miles, the drivers side tank developed a hairline crack that only leaked at pressure -- and when it leaked it pissed straight onto the ground. I posted something about that years ago.
I was told by a GM tech that the OE radiators were intended to be rebuildable, but parts prices for whole replacement units decreased so much they quit doing it (years ago).
As long as that rad was not full of crap (the odd walnut shell dust does not count) I would spend 0 time thinking about it.
98inWPB
PostSubject: Re: Restoration Pics   Restoration Pics - Page 3 EmptyThu Feb 06, 2020 9:56 am
First rad in this car started intermittently dripping on the drivers side around 1500 miles ago (91,000 miles), cracked up high, prob the same place they all do, it would behave for weeks, drip randomly then again stop, I could go on a road trip and have it drip gassing up to come home after a weekend of dryness only to leak like all hell after letting it sit parked 3 weeks.
Merit : 153
PostSubject: Re: Restoration Pics   Restoration Pics - Page 3 EmptyThu Feb 06, 2020 10:52 am
I am not sure which radiator I'd choose to replace the one in the Riv now.
Restoration Pics
» couple pics of 1 of my mod tractors
» Actual showroom pics of the 2011 John Deere XUV 825i
» old TORQUE pics
» Old metal detector from the 1960's found... (PICS)
» Aetna Mountain 2-12-2011 a few pics
