| Write-Up: Seafoam to restore lost horsepower | |
+43NelsonBC12 ewolfe0050 ghpcnm albertj Nez moldymac sburch23 EatDirtFartDust Rickw Jason Shintsu TonySmooth89 Karma 1wickedninja Supercharged ibmoses SuperRiv07 manofmany captshiner Chicken deekster_caddy T Riley robotennis61 99Rivman BillBoost37 palermocorey90 SC95Riv allfalldown 1998 Riv ricoshay mayfair4life187 gosloriv SpaceBar SoCal Riv TType_Riviera RhinoFLA racinfan pwmin NO 4 EVR Mr.Riviera AA 98riv jax95riv 47 posters |
ghpcnm Aficionado
Jason Aficionado
| Subject: Re: Write-Up: Seafoam to restore lost horsepower Fri Nov 11, 2011 9:46 pm | |
| I've had good success with liquid GM Top Engine Cleaner (similar to SeaFoam) and Motorvac. I have personally seen surprising, tangible results from the motorvac treatment. There are many examples on this forum, and I've read about it solving "unsolvable" drivability issues on other forums. | |
| Subject: Re: Write-Up: Seafoam to restore lost horsepower Fri Nov 11, 2011 9:56 pm | |
| I used to add a quart of Gunk engine flush,every 4 oil changes. I obeyed the cans warnings and followed them. The first few times i used it,the oil came out very black.even had some chunks of crap.I was using full syn at the time. gradually the oil came out cleaner and cleaner until I was satisfied the engine was as clean as she was gonna get between(3000 mile) changes. I thought the engine ran cooler over time too. I liked it. compared to the shop flush its not too expensive. my old car ran great too | |
ewolfe0050 Aficionado
| Subject: Re: Write-Up: Seafoam to restore lost horsepower Sat Nov 12, 2011 11:30 am | |
| I've always had luck with this... empty engine oil and refill 1qt transmission fluid, and 4+qts cheap thin oil (straight 30) or a 30w blend if you run full synthetic. The transmission fluid is a detergent and cleans and breaks up carbon and sludge. The thin oil allows for more circulation. After 500mi of regular driving, empty and put in a synthetic blend. (for my Riv I changed to full synthetic 1500 mi after but left the blend in the Bronco) | |
NelsonBC12 Rookie
Name : Zach Age : 30 Location : St. Petersburg, FL Joined : 2012-04-01 Post Count : 13 Merit : 0
| Subject: Re: Write-Up: Seafoam to restore lost horsepower Sun Apr 08, 2012 7:23 pm | |
| Im attempting the top clean right now as we speak. Im looking for the break booster line but im not sure which one to pull as the one I think is it seems to be giving me a struggle. Is this the line that I need to pull out? And do I pull from the hose, or the plug that goes into the vacuum? EDIT: Idk why it made it crooked, sorry. | |
| Subject: Re: Write-Up: Seafoam to restore lost horsepower Sun Apr 08, 2012 7:36 pm | |
| yes that is the brake booster line. pull from the hose, not the plug. the plug has a barbed end. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Write-Up: Seafoam to restore lost horsepower Sun Apr 08, 2012 8:05 pm | |
| yeah.dont add sea foam into the booster itself.lol.I did that !haha | |
NelsonBC12 Rookie
| Subject: Re: Write-Up: Seafoam to restore lost horsepower Mon Apr 09, 2012 6:51 pm | |
| Thanks guys, but i just had to muscle it a little bit. It worked perfectly. I probably could have put more in. But I think it did what it was suppose to do already.
Im planning on doing it next month again. Also, adding some to the crank case after I add some to the tank. It's time for an oil change soon, so it's perfect!
Thanks for your help guys! I almost ripped my head off before, but now i know its quite simple! | |
rivparadise Fanatic
Name : Samuel Age : 51 Location : Niagara Co. Joined : 2007-06-10 Post Count : 381 Merit : 11
| Subject: Re: Write-Up: Seafoam to restore lost horsepower Wed Apr 11, 2012 11:16 pm | |
| This was after 160,000. Only synthetic since day one and Lucas Upper Cylinder Lubricant every other tank full! | |
| Subject: Re: Write-Up: Seafoam to restore lost horsepower Wed Apr 11, 2012 11:27 pm | |
| that is one clean engine. makes me feel like a real slob | |
Tajis Amateur
Name : Tajis Age : 38 Joined : 2012-08-24 Post Count : 28 Merit : 3
| Subject: Re: Write-Up: Seafoam to restore lost horsepower Sat Oct 27, 2012 12:05 pm | |
| I just ran Seafoam through my Riv. So far I'm noticing a smoother idle and 'maybe' a little more responsiveness.
Incidentally, if you want to make sure no one comes within 500 feet of your rear bumper... this will do the trick! LOL I think the other drivers thought my car was about to explode or something. | |
JayP71 Special
Name : Jason Location : Eastern TN Joined : 2013-12-11 Post Count : 8 Merit : 0
| Subject: Re: Write-Up: Seafoam to restore lost horsepower Fri Dec 13, 2013 5:32 am | |
| Two things that I'm too lazy to read 10 pages to find out if anyone else has mentioned.
1. You may get a 'check engine' light during this procedure (my Caddy always would). This is normal and it will go away shortly.
2. If you want to do this through the PVC (running through the brake booster is easier and faster). I always used a nipple from a baby bottle on top of the Seafoam can. Makes it easier not to flood the engine with too much Seafoam. | |
bmcd9179 Fanatic
Name : Bryson Age : 28 Location : Utah Joined : 2013-09-21 Post Count : 288 Merit : 1
| Subject: Re: Write-Up: Seafoam to restore lost horsepower Fri Jan 17, 2014 6:27 pm | |
| High guys I recently just sea phoamed my car and not a lot of smoke came out, could my cat be clogged up, I mean a good amount of smoke came out but not thick and once I floored it no more, runs a lot better tho!!! | |
| Subject: Re: Write-Up: Seafoam to restore lost horsepower | |
