 Traction Control Bing
Merit : 93
Traction Control Bing Empty
PostSubject: Traction Control Bing   Traction Control Bing EmptyFri Feb 14, 2020 1:06 pm
It seems like I'm getting the Bing Bing Bing and flashing warning light way too easy. Even if I turn traction control off. Is it possible a sensor is going out? I don't have any codes.
Merit : 154
PostSubject: Re: Traction Control Bing   Traction Control Bing EmptyFri Feb 14, 2020 2:01 pm
...sounds like you are looking for a scanner capable of reading the ABS codes. Or a Tech II which will enable you to run the ABS self-test.
PostSubject: Re: Traction Control Bing   Traction Control Bing EmptyFri Feb 14, 2020 2:59 pm
THAT's interesting... I have a connector or pump that is getting tired, and sometimes when I hit the 12 MPH 'pre-charge' point for the pump I will get both ABS & TRAC lights, but no flashing & no chime... ?
Merit : 93
PostSubject: Re: Traction Control Bing   Traction Control Bing EmptySat Feb 15, 2020 2:08 am
Can HP Tuners/DHP Power Tuner do it?
» I'm back with a new FJ!
» Micron Radio Control
» Improving Traction on a Murray Wide Body
» control lines
» air traffic control !
