 Question?
Rivieraz
Rivieraz
Question? Empty
PostSubject: Question?   Question? EmptySat Feb 15, 2020 12:18 am
what is the difference in vin 1 and vin k? also my check engine light came on for about 3 hours ,the car drove fine , but the light went out, does the computer keep data even after the computer resets itself and goes out
Merit : 93
Question? Empty
PostSubject: Re: Question?   Question? EmptySat Feb 15, 2020 2:05 am
I think K is supercharged, and 1 is naturally aspirated. Which do you have?
Rivieraz
Rivieraz
Question? Empty
PostSubject: Re: Question?   Question? EmptySat Feb 15, 2020 12:55 pm
s/c vin 1
Merit : 113
Question? Empty
PostSubject: Re: Question?   Question? EmptySat Feb 15, 2020 4:37 pm
1 is the L67 Supercharged engine and K is the L36 NA V-6.
Yes, the computer keeps the fault codes.
Rivieraz
Rivieraz
Question? Empty
PostSubject: Re: Question?   Question? EmptySun Feb 16, 2020 12:35 am
thanks LARRY I have a actron cp9690 scanner  and a red devil river ALDL SET UP ( but haven't used )the actron scanner didn't read any codes, do I need a tech scanner to read past faulty codes? or do I need a better scanner?
Merit : 113
Question? Empty
PostSubject: Re: Question?   Question? EmptySun Feb 16, 2020 11:13 am
The problem is the OBD 1 system, it's no where near as sophisticated as the 1996 and up OBD 2 system.  A better scan tool might help, but I doubt you will find one today.  Any OBD 2 tool would read pending codes on an OBD 2 system. Once the light is out, it may not be possible to read the code.
Question? Empty
Question?
» Pulley Question
» grip strength advice..ask david horne any question on grip training....
» Level Adjust Question
» Boston Qualifying Question
» Boston 2013 Qualifying Question
