 HVAC auto turns on by itself.
carguy8888
HVAC auto turns on by itself. Empty
PostSubject: HVAC auto turns on by itself.   HVAC auto turns on by itself. EmptyWed Mar 04, 2020 11:05 pm
The last week or so it has been exceptionally nice by me, I used the sunroof & had the climate control off. When I would restart the car the Auto climate control would turn on by itself. Is this normal?
Merit : 93
PostSubject: Re: HVAC auto turns on by itself.   HVAC auto turns on by itself. EmptyThu Mar 05, 2020 3:44 am
I think so . . .
PostSubject: Re: HVAC auto turns on by itself.   HVAC auto turns on by itself. EmptyThu Mar 05, 2020 11:46 am
No, not unless you touch one of the HVAC controls OR the TEMP control on the steering wheel.
Merit : 155
PostSubject: Re: HVAC auto turns on by itself.   HVAC auto turns on by itself. EmptyThu Mar 05, 2020 12:06 pm
When you turn the climate control off, you have to push the off button *twice* if anyone has touched the passenger temperature controls. Otherwise, it does not turn off.
So, if you're having problems really shutting the thing down, consider pulling the fuse and let it reset itself when you power it back up and definitely check the passenger control for problems.
carguy8888
PostSubject: Re: HVAC auto turns on by itself.   HVAC auto turns on by itself. EmptyThu Mar 05, 2020 6:05 pm
Thank you guys. It's probably as simple as I didn't realize that I'm probably hitting the buttons on the steering wheel. I'll be conscious of that and it will probably take care of the situation.
» My battery barely turns the starter. Could it be a bad a connection?
» Bon Jovi turns it up a gear at the Stadium of Light.
» 4WD Gearboxes.....Auto V`s Manual
» Cleaning your gold,
» Hydrogen boosters on vehicles. Get better mileage.
