 Catalytic converters
4 posters
Angeles98
Catalytic converters Empty
PostSubject: Catalytic converters   Catalytic converters EmptySat May 02, 2020 11:47 pm
Soo my cat converter was clogged up and got to the point where is made a loud pop one day and guessing it gave it. Car sounds raspy as hell due to exhaust leak and wondering what type of replacement option would be best. Should I go stock replacement or something better? 1998 Riviera
Merit : 149
PostSubject: Re: Catalytic converters   Catalytic converters EmptySun May 03, 2020 8:56 am
I used the Walker 15817,
https://www.rockauto.com/en/catalog/buick,1998,riviera,3.8l+v6+supercharged,1303322,exhaust+&+emission,catalytic+converter,5808
It may depend on where you live. RA may not ship a converter to certain states due to differing emissions regulations.
PostSubject: Re: Catalytic converters   Catalytic converters EmptyThu May 07, 2020 5:46 am
I used a high flow Flowmaster unit but I had installed headers and other parts for a freer flowing exhaust and a PCM tune, and smaller SC pulley.
For a stock engine in a State where they still do smog checks then get a Walker made as an exact replacement.
Put a new O2 sensor in it while your replacing parts.
Merit : 180
PostSubject: Re: Catalytic converters   Catalytic converters EmptyFri May 08, 2020 1:45 pm
While you are at it, it would not be a waste of time to figure out how your converter got clogged in the first place. Could be...
- oil additives with a lot of zinc or other phosphates can plate the converter over time if you are burning oil for whatever reason. Use good oil and leave the mechanic-in-a-can on the shelf.
- running rich due to lack or mis-maintenance or a funky tune.
Reason I say this -- in almost 400,000 miles on my '98 Riv I've never plugged a converter. Something is wrong, you might want to spend a couple minutes eliminating any obvious causes...
» Gas in the catalytic converter....why?
» Catalytic converter
» catalytic converter delete?
» Catalytic Converter replacement
» o2 sensor trouble w/ high flow catalytic converter
