| how to toubleshoot cruise control | |
Rivieraz Enthusiast
Name : tommy z Age : 56 Location : the Burgh Joined : 2019-01-08 Post Count : 227 Merit : 1
| Subject: how to toubleshoot cruise control Wed Jul 08, 2020 10:57 am | |
| driving over the weekend noticed my cruise control doesn't work I had the car over a year now its the 1st time I wanted to use it. but anyway no lights come on when I try to use it( cruise control light). I checked the fuse on the driverside everytrhing is fine. any suggestions?thanks for reading! | |
| Subject: Re: how to toubleshoot cruise control Wed Jul 08, 2020 8:27 pm | |
| - Rivieraz wrote:
- driving over the weekend noticed my cruise control doesn't work I had the car over a year now its the 1st time I wanted to use it. but anyway no lights come on when I try to use it( cruise control light). I checked the fuse on the driverside everytrhing is fine. any suggestions?thanks for reading!
...did you get a service manual set yet? There is trouble shooting in there. That said, generally need to check the brake switch, cruise servo, the column switch. My wild guess is you'll need to replace the control unit with one from a junkyard (there are a lot of them around). | |
| Subject: Re: how to toubleshoot cruise control Sun Aug 09, 2020 7:44 pm | |
| - albertj wrote:
...did you get a service manual set yet? There is trouble shooting in there. That said, generally need to check the brake switch, cruise servo, the column switch. My wild guess is you'll need to replace the control unit with one from a junkyard (there are a lot of them around). My cruise stopped working. I have an extra control unit. Albert, have you done this? How does it come off the firewall. You have to get to the back side to unbolt it? _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: how to toubleshoot cruise control Sun Aug 09, 2020 10:16 pm | |
| - LARRY70GS wrote:
- albertj wrote:
...did you get a service manual set yet? There is trouble shooting in there. That said, generally need to check the brake switch, cruise servo, the column switch. My wild guess is you'll need to replace the control unit with one from a junkyard (there are a lot of them around). My cruise stopped working. I have an extra control unit. Albert, have you done this? How does it come off the firewall. You have to get to the back side to unbolt it? I have not done this and I don't expect my CC servo to ever break, it's electronic. That said, GM does not have much variation at all in hard parts like that (brake light switches, cruise control modules, etc.) so my guess is you should find a few torx, hex head, or Phillips head body panel sheet metal screws around the outside of the unit holding it on, probably thru ears on the metal base or some such. The place for super careful work actually would be the plastic throttle connectors. They are tricky. Study the ones on the cables to the replacement control unit *very* carefully. You will probably need a "pick" to get them off and even them they are old and likely will be brittle so be careful.
Rivieraz Enthusiast
| Subject: Re: how to toubleshoot cruise control Sun Aug 09, 2020 11:54 pm | |
| thanks everyone,i do have the sevice manuals,for me im learning as I go sometime the manuals are a little hard to read for me but anyway, I have some time this week to tackle the C.C. going through the manuals 2night. also I have a set of blue 1995 FSM manuals for the price of postage if needed.
| Subject: Re: how to toubleshoot cruise control Mon Aug 10, 2020 10:15 am | |
| - Rivieraz wrote:
- thanks everyone,i do have the sevice manuals,for me im learning as I go sometime the manuals are a little hard to read for me but anyway, I have some time this week to tackle the C.C. going through the manuals 2night. also I have a set of blue manuals for the price of postage if needed.
For the Riv, the factory manuals are pretty much an ownership requirement at this point. One of the problems with the manuals is that they either assume you have an experienced handyman's or trained mechanic's know - how, and they sometimes skip stuff. For instance, for replacing the front control arms they factory manual does not tell you that you have to smack the ball joint while using the factory tool in order to get the assembly out. The only point of using the tool, however, is that the way the ball joint is in, if you use a pickle fork you will damage the ball joint and boot because of lack of clearance for working. Another is the serpentine belt replacement on the 2000 Cavalier/Sunfire, for instance. The manual shows a multi-step procedure involving a special tool -- however, the real tool is a broomstick (yes, a broomstick). If you have a broomstick and you know just where to lever it (once someone shows you you can't possibly un-see it) it actually takes longer to read the factory manual instructions than it does to change the belt. Point is the manuals are definitely useful but the normal cautions you already know are definitely applicable: (1) don't check your brains at the door, so to speak - make sure what you see in the manual comports with common mechanical sense and (2) don't be shy about asking someone who's actually done the more complicated jobs, as long as they truly have a clue (some mechanics do, some don't). | |
Rivieraz Enthusiast
| Subject: Re: how to toubleshoot cruise control Mon Aug 10, 2020 12:06 pm | |
| thanks albertj | |
Rivieraz Enthusiast
| Subject: Re: how to toubleshoot cruise control Tue Aug 11, 2020 11:46 am | |
| messed with c.c. but didn't get to work yet,i had a friend use his power probe to test 1st with ignition off then on he said that it was getting power(not sure what voltage or ohms he read but said it was fine) and when I removed the vacuum line behind the servo It gave a good strong hisss,no noticeable dry rot or cracks in hoses.also albertj when you say it might be the control unit do you mean cruise control servo? 2marrow im gonna peek at the column for the brake switch | |
Rivieraz Enthusiast
Lmck3 Amateur
Name : Lance Mckinley Location : ft lauderdale Joined : 2013-10-03 Post Count : 47 Merit : 8
| Subject: Re: how to toubleshoot cruise control Tue Aug 11, 2020 12:50 pm | |
| note: this is repetitive.
the cruise on my 1995 riv failed. a pull-a-part cruise unit fixed it. next time i was there i bought another ($35) and installed it in the parking lot. it worked so now i had the pull-a-part unit which was formerly screwed to the firewall bracket as as a spare. it lived in the trunk until i sold the car.
the cruise on my 1997 riv failed. the extra cruise unit from the 1995 riv fixed it. next time i was trolling the junkyard i bought another cruise module (again, $35) and installed it in the parking lot. it worked fine so now i had the one which was formerly screwed to the firewall bracket as as a spare which still lives in the trunk.
the cruise on my [back-up road-driver] 1997 buick century failed. a pull-a-part cruise unit fixed it. [it is a slightly different part than the riv cruise unit] next time i was at the junkyard i bought another (cost $35) and installed it on the century in the parking lot. it worked so now i had the one which was formerly screwed to the firewall bracket as as a known working spare which still lives in the trunk of the elderly century.
as an aside, the bracket on which the cruise module is mounted has elongated slots for the bolts which ease removal. save the extra rubber mounting grommets.
also: the throttle cable is pulled by a fabric-like ribbon located inside the cruise unit. it's necc to disconnect the cruise cable at the throttle body so as to get sufficient slack to disengage the pull-cable.
the rock auto website lists what cars use the same cruise unit as our 8gen rivieras.
| Subject: Re: how to toubleshoot cruise control Wed Aug 12, 2020 1:24 am | |
| - Rivieraz wrote:
- messed with c.c. but didn't get to work yet,i had a friend use his power probe to test 1st with ignition off then on he said that it was getting power(not sure what voltage or ohms he read but said it was fine) and when I removed the vacuum line behind the servo It gave a good strong hisss,no noticeable dry rot or cracks in hoses.also albertj when you say it might be the control unit do you mean cruise control servo? 2marrow im gonna peek at the column for the brake switch
My unit is an electronic servo. If yours is a vac servo, since it seems to be working I'd check the brake switches with a meter. One controls the lights and the other is for cruise. Lights are easy... do the light up? The other one, you can check it with a meter. | |
Rivieraz Enthusiast
| Subject: Re: how to toubleshoot cruise control Wed Aug 12, 2020 9:43 am | |
| ordered brake switch from rock auto, it came to 10 dollars and change. | |
| Subject: Re: how to toubleshoot cruise control Wed Aug 12, 2020 10:50 am | |
| - Rivieraz wrote:
- ordered brake switch from rock auto, it came to 10 dollars and change.
Was your obviously broken? I remember when mine quit, it was seriously annoying. I had stopped to get gas at the Marathon on Greentree Hill and when I finished, restarted the car, the idiot light on the instrument cluster stayed on and the gong started ringing. It took a while to figure out how to rig it so I could drive and it was a long drive back to NY without cruise. | |
Rivieraz Enthusiast
denim Junkie
| Subject: Re: how to toubleshoot cruise control Fri Apr 09, 2021 8:14 pm | |
| - albertj wrote:
- I have not done this and I don't expect my CC servo to ever break, it's electronic.
Hi Albert, I grabbed this quote from your Aug. 2020 conversation with Larry about cruise control issues and am wondering about the electronic replacement you use for the servo unit. I should have prefaced this with he fact that I have a non-functioning CC in my '98 Riv. It's the next thing on the list to fix, and I want to gather the parts I may need, even if I haven't yet diagnosed the problem. Please tell me about the unit, and where I might find. I'd like to do this fix once and for always, eh? TY, Sean | |
denim Junkie
| Subject: Re: how to toubleshoot cruise control Sat Apr 10, 2021 6:55 pm | |
| Yeah, I also found this quote, later: - albertj wrote:
- The 96 and later had electronic servo cruise, the 95 had a vacuum servo.
Since I have a '98, my question is moot. Thanks anyway | |
| Subject: Re: how to toubleshoot cruise control Mon Apr 12, 2021 4:23 pm | |
| - denim wrote:
- Yeah,
Thanks anyway
It is worth the time to diagnose the problem. The brake switch is actually several switches in one housing. GM has been using a brake light switch of generally this style since Methusela was a toddler. When they went to an electronic CC servo they replaced the vacuum side of the brake light switch with a reed switch, but the general shape and the brake light side of the switch is still the same. It's a clever gadget, and if you put it in per the instructions, it self-adjusts (such adjustment is needed only once). My guess is your headache is the brake switch or maybe the servo but no kidding do the diagnosis. And if you smell a rat, maybe it's the one that chewed on your wires... | |
denim Junkie
| Subject: Re: how to toubleshoot cruise control Mon Apr 12, 2021 7:02 pm | |
| I'm having a friend, with a more advanced scanner, help soon, so I can follow the manual. Particularly the Fault Isolation Test. There is no power whatsoever now. Zip. Checked fuse. Replaced, no change. Also, curiously, my steering wheel has a bit of front-to-back movement. Hoping that's not built in so I can hand the wheel to Moe when he asks to take the wheel. Maybe someone was messing with it. Further investigation needed. | |
| Subject: Re: how to toubleshoot cruise control Mon Apr 12, 2021 7:09 pm | |
| - denim wrote:
Also, curiously, my steering wheel has a bit of front-to-back movement. Hoping that's not built in so I can hand the wheel to Moe when he asks to take the wheel. Maybe someone was messing with it. Further investigation needed. That's a VERY COMMON problem with the Riviera. The Column tilt mechanism, pivots on two bushings/pins. The pins work themselves out over time and the whole column rocks back and forth. There is actually an entire thread dedicated to it. Surprised you never saw it, you have been here awhile. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: how to toubleshoot cruise control Mon Apr 12, 2021 7:13 pm | |
denim Junkie
| Subject: Re: how to toubleshoot cruise control Mon Apr 12, 2021 8:41 pm | |
| Thanks much, Larry. I may have come across this thread myself if the issue was on the short list of problems, most of which have been solved by now. I looked briefly and saw a lot of grrring about the problem, along with the PITA acronym, so I'm sure it will be a valuable read. If it comes down to it, do you know if a '95 steering column can replace a '98 column? My older Riv, which has a great engine/tranny combo, and will be sold for such this summer, could be a donor if so. This is assuming I can't fix the existing hardware. Anyway, I'll let you know how it works out. | |
| Subject: Re: how to toubleshoot cruise control | |
