 Question about wood
4 posters
knoxbroadcaster
knoxbroadcaster
Question about wood Empty
PostSubject: Question about wood   Question about wood EmptyThu Aug 20, 2020 5:34 pm
What years in the last generation of Riviera had full wood on dash like the picture?Question about wood 00s0s_10
PostSubject: Re: Question about wood   Question about wood EmptyFri Aug 21, 2020 12:00 am
It's not a factory option, and it's not real wood.  It's an aftermarket kit that you install yourself.  Basically a bunch of stickers with a thick layer of epoxy coating.  I have one in my car.  It took me three months to install, although I'm sure I set the record on that one.  I used a BD Trims kit - they sent me piece after piece that was damaged or incorrectly manufactured.  Also, I pulled every interior panel that was getting "wood" added, and painted around the edges to match my wood color (black paint to match black African Zebra Wood).  It was a painstaking process and I nearly screwed it up in a couple places.  You have to be careful not to get bubbles under the wood trim.  I got a couple under the passenger side dash piece but was able to, extremely carefully, drill through the dash panel from behind and let the air out of the bubble.  I also didn't quite get a piece aligned right on the driver's side door - the triangular piece that has the vents in it.  It's very difficult to get that piece to align right.  You only get one chance with these things.  The glue sticks forever if you've prepped the dash surface right.
I've been very happy with my kit though.  My car's interior was an ocean of the same grey plastic.  It looks much better with the black wood kit.  I also installed a Wheel Skins leather steering wheel cover with black sections to match the dash kit.
knoxbroadcaster
knoxbroadcaster
PostSubject: Re: Question about wood   Question about wood EmptyFri Aug 21, 2020 12:35 am
Thank you
Merit : 180
PostSubject: Re: Question about wood   Question about wood EmptySat Aug 22, 2020 5:03 pm
There were some aftermarket kits of real wood, but I think they are NLA.
The OE shifter surround *was* real wood, IIRC it was made by Yamaha. People pasted the aftermarket kits over the OE shifter surround.
Some dealers installed a kit, simulated rosewood usually I think.
Merit : 149
PostSubject: Re: Question about wood   Question about wood EmptySat Aug 22, 2020 8:00 pm
The Sherwood kit I have is real Rosewood.  Bought it 10 years ago though.
https://2img.net/h/i172.photobucket.com/albums/w20/SLD1624/DashKit1.jpg
https://2img.net/h/i172.photobucket.com/albums/w20/SLD1624/DashKit5.jpg
https://2img.net/h/i172.photobucket.com/albums/w20/SLD1624/DashKit8.jpg
https://2img.net/h/i172.photobucket.com/albums/w20/SLD1624/DashKit7.jpg
https://rivperformance.editboard.com/t6425p175-write-up-bd-trims-and-sherwood-dash-kit-installation?highlight=dash+kits
albertj likes this post
Question about wood
» Write-Up: BD Trims and Sherwood Dash Kit Installation
» caddy wood grain wheel
» Post pics of your wood dash kit here.
» Write-Up: Center Console Removal
» Cracked Wood Trim on Shifter & Dash
