Name : Mek Age : 26 Location : Dallas, Texas Joined : 2020-11-24Post Count : 167 Merit : 2
Subject: what IS that ???? Wed Nov 25, 2020 4:20 pm
today i went under my car to finally get some new rubber hangers on the exhaust cause all 4 the old ones had completely tore off and the pipes were just hanging. as soon as i got it, i had tied up the exhaust with some type of long fastener flat belt type thing i had found and it held up. lol with that been said, i noticed a line under the passenger side was broken. i looked at where it might go and it looks like some box under there, it has a little nipple where the tiny rubber hose would go, but i dont know what it could be lol i need help. it’s directly beside where the exhaust hanger goes. heres some pics any ideas?
i tried to take close ups so yall can see the broken hose
Rivieraz Enthusiast
Name : tommy z Age : 56 Location : the Burgh Joined : 2019-01-08Post Count : 227 Merit : 1
Subject: Re: what IS that ???? Wed Nov 25, 2020 11:21 pm
hello i am guessing its your air pump for your auto leveling system, i,m sure albertj will have your answer, good luck
bbyshrk Enthusiast
Subject: Re: what IS that ???? Thu Nov 26, 2020 12:35 am
i think you’re right, i just looked on google images and sure looks like the culprit, thanks im boutta look online for the replacement hose. this the first air suspension car ive owned, hope everything works
Subject: Re: what IS that ???? Thu Nov 26, 2020 3:36 am
Yeah Mekk, it's the air pump. Just a hose. Asked my brother and that's what he said too.
bbyshrk likes this post
bbyshrk Enthusiast
Subject: Re: what IS that ???? Thu Nov 26, 2020 10:18 am
thanks for confirming, the hose should be easy enough to replace for now. ill probably end up converting the air suspension to coilovers in the future
Subject: Re: what IS that ???? Thu Nov 26, 2020 1:40 pm
Mekk,....or even you can check this eBay Riv for parts ( for cheap ). It's even your color.
Subject: Re: what IS that ???? Thu Nov 26, 2020 2:24 pm
woww! thank you stan, not all heroes wear capes! i quickly messaged the seller on ebay about the parts i need, im excited about that dashboard in there. im just waiting for a response now you’re awesome!
Subject: Re: what IS that ???? Thu Nov 26, 2020 2:53 pm
Sure Mekk ,no problem. God bless you for resurrecting another one . Try not to spray paint anything. Replace only with original factory parts (especially interior) if you can.
Happy Thanksgiving.
bbyshrk Enthusiast
Subject: Re: what IS that ???? Thu Nov 26, 2020 3:33 pm
Happy Thanksgiving.
yes sir! im doing my best to keep it all factory on the interior, only a couple upgrades will be made in there (like a new head unit that will connect to my phone, and maybe a better steering wheel) thank you again, and happy thanksgiving to you too!
Subject: Re: what IS that ???? Fri Nov 27, 2020 3:17 pm
Check if it is actually working.
I would not bother changing to coilovers because the air shocks are not much $$ and are readily available.
bbyshrk Enthusiast
Subject: Re: what IS that ???? Sat Nov 28, 2020 1:20 am
will do! ive never really heard the pump running but whats crazy is i didnt notice any suspension issues while i was driving the car. im sure the parts for the pump aren’t that expensive or hard to find.. i just rather have the car sit lower, the stock height and the air suspension just isnt really my cup of tea.
Name : Larry Age : 67 Location : Oakland Gardens, NY Joined : 2007-01-23Post Count : 2184 Merit : 149
Subject: Re: what IS that ???? Sat Nov 28, 2020 8:00 am
If everything is working correctly, the pump will run from 3-5 seconds as a check, EVERY TIME you cycle the ignition on AFTER a 17-35 second delay. You can simply turn the ignition on without starting the engine. Then walk around to the right side rear wheel and wait for 35 seconds. The pump should briefly run for 3-5 seconds. If the system isn't working, and obviously, yours isn't, the back of the car will be low. This makes the tire camber excessively negative, and you can see it. The tops of the rear tires will tilt in. There are no other symptoms, so you wouldn't otherwise notice.
bbyshrk Enthusiast
Subject: Re: what IS that ???? Sat Nov 28, 2020 11:02 pm
yeah my cars never done that lol. that sounds cool as hell though. ive never even seen a never car do that unless it was on airbags
