Name : Marvin Joined : 2020-11-12Post Count : 4 Merit : 0
Subject: Trans random shifting Sat Dec 05, 2020 7:22 pm
Transmission shifts back and forth from overdrive to lower gear at 55mph to 60 mph. At 70mph runs fine. What could cause this.
carguy8888 Junkie
Name : Brian Cohen Joined : 2019-01-07Post Count : 805 Merit : 8
Subject: Re: Trans random shifting Sat Dec 05, 2020 10:06 pm
I don't see what year the car is?
Name : Location : Finger Lakes of New York State Joined : 2007-05-31Post Count : 8604 Merit : 180
Subject: Re: Trans random shifting Sat Dec 05, 2020 11:50 pm
My guess is you have a '96. Is your Service Engine Soon light on? If so, what is the code?
The 4T60E transmission can do this (enter/exit overdrive frequently) when certain parts (and/or the fluid) are worn.
Do a search on this site for discussion about this problem, see also https://www.cadillacforums.com/threads/4t60-e-losing-overdrive.160172/ and https://buickforums.com/forums/threads/possible-solution-for-4t60e-transmission-issues.33373/
...for perspective.
One real solution is to rebuild the transmission using the Sonnax and TransGo improvement kits, but when you look at the other posts about this on this site you will see other, less expensive strategies. Sometimes even just a drain and fill of transmission fluid, to get the viscosity back where it should be. Other times, something else. Have a look at this subject on these pages, as well as the links I posted.
Marvin Potter Special
Subject: Trans shifting random Sun Dec 06, 2020 6:32 am
It’s a 95. Has new trans synthetic fluid and filter. It had 2 codes. One for cruise control. CC servo switch. The other code was egr which I replaced and made engine run smoother but little effect on trans problem. I just recently bought the car. I suspect CC problem is in multifunction switch.
Subject: Re: Trans random shifting Sun Dec 06, 2020 2:54 pm
What is the actual cruise control code?
Reason I ask -- hunch is your brake switch may be worn out. The 4T60E is electronic and will go into or out of lockup depending on the state of the brake light switch(es). A flaky switch can cause the "transmission" problem you cite.
Brake switch malfunction will also cause problems with the CC.
Brake switches are cheap, and it would not be a waste (given the age of the car) to just replace it.
It could be that simple.
Subject: Re: Trans random shifting Sun Dec 06, 2020 5:35 pm
Actual code was P0565
Subject: Re: Trans random shifting Sun Dec 06, 2020 9:38 pm
Isn't that a 'cruise control on malfunction' code?
That could be the turn signal switch (unlikely), the brake switch (age/mileage/flooding/accident), but in any event a malfunction in that switch will make the electronic transmission control erratic. Could be something else. My wild guess is the brake switch. I forget exactly when mine went but I remember what an absolute pain in the butt it was when it malfunctioned - in a way that it still *kinda* worked.
Fix all your codes then troubleshoot your transmission if it is still acting up.
Marvin Potter likes this post
Subject: Re: Trans random shifting Mon Dec 07, 2020 12:03 am
