| | Alternator Voltage | |
| | Author | Message |
BuickRivieraGeorgia Amateur
Name : Riviera Joined : 2021-03-24 Post Count : 33 Merit : 0
| Subject: Alternator Voltage Wed Mar 24, 2021 9:12 am | |
| Hi all
I have registered here again after many years. My car is located in Tbilisi, Georgia and I just got back and want to revive my favourite car in the world! My issue is the red battery light on the left and I am guessing it is the alternator- since the battery keeps dying. Obviously, I cannot buy a new one in this country... But there is a guy that can rebuild it, but I am not sure I trust his knowledge of the proper voltage for a 95 supercharged one. What would be the correct voltage to rebuild it for? And also, I read it here that it could be a thermistor issue as well, is that also the case for a 95? And if so, how to deal with it?
PS Alternator is my first guess, but if there any other common issues - would love to hear it
Thanks! | |
| | | LARRY70GS Aficionado
| Subject: Re: Alternator Voltage Wed Mar 24, 2021 11:59 am | |
| The alternator is internally regulated. It is a 12 volt alternator that will charge the battery between 14 and 14.6 volts depending on load and temperature. Any rebuilder can refurbish the alternator. They replace common parts. The output voltage will vary according to need. It isn't something a rebuilder adjusts. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: Alternator Voltage Wed Mar 24, 2021 1:20 pm | |
| - LARRY70GS wrote:
- The alternator is internally regulated. It is a 12 volt alternator that will charge the battery between 14 and 14.6 volts depending on load and temperature. Any rebuilder can refurbish the alternator. They replace common parts. The output voltage will vary according to need. It isn't something a rebuilder adjusts.
I see, so it should put out 12 volts, but then the thermistor makes it give out 14-14.6 Thanks for your reply! | |
| Subject: Re: Alternator Voltage Wed Mar 24, 2021 1:21 pm | |
Thanks for your reply! The internal regulator and thermistor determine output voltage according to need. In order to charge a 12 volt battery, the charging voltage has to be at least 13.8 volts. This is true of any 12 volt system alternator. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: Alternator Voltage Wed Mar 24, 2021 2:06 pm | |
Thanks for your reply! The internal regulator and thermistor determine output voltage according to need. In order to charge a 12 volt battery, the charging voltage has to be at least 13.8 volts. This is true of any 12 volt system alternator. So, is the 1995 Riviera alternator supposed to put out 13.8 or 14.0 or 14.6? | |
| Subject: Re: Alternator Voltage Wed Mar 24, 2021 2:16 pm | |
Thanks for your reply! The internal regulator and thermistor determine output voltage according to need. In order to charge a 12 volt battery, the charging voltage has to be at least 13.8 volts. This is true of any 12 volt system alternator. So, is the 1995 Riviera alternator supposed to put out 13.8 or 14.0 or 14.6? It's variable. No alternator puts out ONE voltage. The voltage will vary according to needs. There is no need for worry or concern about voltage. I am sure your guy can rebuild your alternator and it will be fine. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| | | Hometown Hero Junkie
| Subject: Re: Alternator Voltage Fri Jul 16, 2021 3:41 pm | |
| So I am encountering a strange issue. Two replacement alternators, both reman. I determined it to be voltage regulator but I just replaced the alt with a new one yesterday and the problem persists. Battery is brand new, brand new capacitor for audio system, literally checked everything I can think of... Ground issue? Thoughts/advice pleas.
| | | albertj Master
| Subject: Re: Alternator Voltage Tue Jul 20, 2021 3:47 pm | |
| - Hometown Hero wrote:
- So I am encountering a strange issue. Two replacement alternators, both reman. I determined it to be voltage regulator but I just replaced the alt with a new one yesterday and the problem persists. Battery is brand new, brand new capacitor for audio system, literally checked everything I can think of... Ground issue? Thoughts/advice pleas.
I need more detail. What is the problem? For instance, my battery will not charge; my lights change brightness with RPM, my starter turns slowly, or whatever. I am sorry but I can not tell from what you wrote, any recommendations. Some years ago I had a problem on a Lincoln I owned, the lights would waver (brightena nd dim) at cruise speed and the transmission lockup would engage/disengage in sync. Turned out the reman alternator was not built properly at the factory. I replaced it with an OE Ford junkyard unit. Then I tore it down and found the voltage regulator was not grounded properly. That story is elsewhere on this site. I fixed it, still have it, but the junkyard unit kept running and running, I never did reinstall the reman unit. | |
| | | Sponsored content
| Subject: Re: Alternator Voltage | |
Similar topics | |
