| | EGR bracket replacement | |
| | Author | Message |
Rp23g7 Rookie
Name : steve brogren Joined : 2021-05-12 Post Count : 14 Merit : 0
| Subject: EGR bracket replacement Tue May 18, 2021 8:19 pm | |
| just looking at some items i my need when i replace my EGR Valve.
Amazon has this EGR Bracket, the part that mounts to the engine and the egr valve mounts to, ACDelco 12567867 GM Original Equipment EGR Valve Adapter
not that i need it yet, but i know bad things happen when you try to remove stuff thats 26 yrs old and has 230,000 miles on it.
the Delco site lists it as a part for 2000 and up Buicks, but how different can it be? anyone have a correct one laying around or have the 1996 part number? | |
| | | LARRY70GS Aficionado
| Subject: Re: EGR bracket replacement Wed May 19, 2021 8:27 am | |
| Is that even applicable to our Rivieras? You have that on your engine? It's some kind of adapter, or spacer.
https://www.rockauto.com/en/parts/acdelco,12567867,egr+valve+spacer+plate,4973
https://www.rockauto.com/en/moreinfo.php?pk=3405549&jsn=3 _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| | | Rp23g7 Rookie
| Subject: Re: EGR bracket replacement Wed May 19, 2021 2:57 pm | |
| Yeah it's what the Egr valve is mounted on | |
| | | albertj Master
| Subject: Re: EGR bracket replacement Wed May 19, 2021 3:38 pm | |
| I seriously doubt that the EGR bracket/mount is going to be the cause of any excitement. I mean, if it bothers you consider using some Kroil or Deep Creep on the bolts before removal. The stainless tube, however, may be a cause for concern. They seem to still be available. Some people have reported they crack. I have never had a problem with mine.
And whatever you do, buy a good EGR valve (a Delphi if you can get one) and a gasket with screen (Standard VG214 I think). The screen tends to stop carbon chunks from clogging the valve; I think what actually happens is it gets hot and lights off (burns) stuff in the exhaust that hasn't burned yet. I had a Standard and a BWD valve - each only lasted a couple years. The replacement Delphi, it has lasted the longest of any of the EGR valves I've had. | |
| | | Rp23g7 Rookie
| Subject: Re: EGR bracket replacement Sun May 23, 2021 10:18 am | |
| Replaced EGR with a Delco, and the PCV valve and gutted the airbox, throttle response improved, never seen a PCV valve like that before, P1406 and P0171 didnt come back after driving 40 miles. I didnt think i had a vacuum leak, the car ran and idled to good to have a vacuum leak. | |
| | | albertj Master
| Subject: Re: EGR bracket replacement Mon May 24, 2021 5:31 pm | |
| - Rp23g7 wrote:
- Replaced EGR with a Delco, and the PCV valve and gutted the airbox, throttle response improved, never seen a PCV valve like that before, P1406 and P0171 didnt come back after driving 40 miles. I didnt think i had a vacuum leak, the car ran and idled to good to have a vacuum leak.
Yeah... some EGRs weaken over time (they are electric) and some stick. Gutting the airbox increases noise without increasing measurable airflow (honest). On a stock n/a 3800, the first restriction elimination you're going to make bank on is achieved by (gently) porting the lower intake manifold. You can then also improve performance by porting the front exhaust manifold while you are at it. After that your concern should be intake valve lift (fix with rockers, and/or a cam and valvesprings). After that should be TB bore (fix with a bigger-bore TB, the Northstar's from similar year is a choice and adapters are available from ZZP) and perhaps a smaller SC pulley (such as the 3.6" that's standard on the old SC3800 Series 1) and tuning to take advantage of those changes - that is, TB, SC pulley, and tuning all three at once. After all that the intake hole and muffler in the front of the airbox may become a restriction... A lot of folks claim gutting the airbox is an initial move. I have reason to suspect that they are replacing dirty air filters when they do that. Going from a dirty air filter to clean will give you a performance bump. Going to an air filter with more pleats (more surface area with same flow per square inch) will as well. | |
| | | Sponsored content
| Subject: Re: EGR bracket replacement | |
Similar topics | |
