Name : tommy z Age : 56 Location : the Burgh Joined : 2019-01-08Post Count : 227 Merit : 1
Subject: not sure plz help Sun Aug 15, 2021 1:44 am
as i turned the key on the riv 2day the engine tried to start(usually starts right up as soon as i turn the key) but would not, but when i turned the key back , i heard the starter rotate 1 time i believe after reading some its the screech everyone is talkin about(not sure if thats the right term)....now i have power but the engine wont even try to turn over no compression not even the starter. thanks for reading . also starter was rebuilt 3 months ago also i know its not the battery
Last edited by Rivieraz on Sun Aug 15, 2021 2:04 am; edited 3 times in total (Reason for editing : info)
Name : Location : Finger Lakes of New York State Joined : 2007-05-31Post Count : 8606 Merit : 180
Subject: Re: not sure plz help Sun Aug 15, 2021 8:19 am
Why do you know it is not the battery?
Why was the starter rebuilt (instead of replaced)?
How did you measure compression?
Starter screech usually is a starter solenoid that isn't engaging the gears firmly enough for starting the engine, or stripped/chipped starter/flywheel gears.
What can you tell us?
Rivieraz Enthusiast
Subject: Re: not sure plz help Sun Aug 15, 2021 10:46 pm
let me re type here, i was a bit drunk when i wrote my last comment .3month ago driving on rt 51 i stopped to get gas and when i started the car it made that screech sound but my car still started up, so i pulled into eds generator & starter garage it been there as long as i have been alive he took out my starter rebuilt it on the spot . the car has been running fine ever since . this time when it made the screeching sound i turned the ignition off, now when i start it the engine wont even try to turn over(sorry thats what i meant by no compression)my neighbor checked the battery with a circuit tester and said the battery was fine. i'm getting the car towed tomarrow morning @ 6:30 am
Rivieraz Enthusiast
Subject: Re: not sure plz help Mon Aug 16, 2021 11:44 am
ok my mechanic got the beast running by wiring in a push button starter switch under the driver side kick panel, now i turn the key on and hit the button in the beast starts right up, he mounted it right where the light goes in on the driver side kick panel. thanks for reading. all comments welcome! have a gr8 day ppl!!
Subject: Re: not sure plz help Mon Aug 16, 2021 2:07 pm
I have no idea.
Rivieraz Enthusiast
Subject: Re: not sure plz help Mon Aug 16, 2021 3:12 pm
first he hit the starter with a hammer then jump started the starter with a screwdriver, then tested all the fuses and relays with a circuit tester all were fine, then he unplugged the neutral safety switch used the circuit tester there(found a problem with power with one of the wirers)i left the garage for an hour when i came back he had everything hooked up
Subject: Re: not sure plz help Mon Aug 16, 2021 4:35 pm
I'm glad he got it going but it just sounds strange.
Rivieraz Enthusiast
Subject: Re: not sure plz help Mon Aug 16, 2021 4:55 pm
when i see him again i'll have him explain it a bit better then i will post it
carguy8888 Junkie
Name : Brian Cohen Joined : 2019-01-07Post Count : 805 Merit : 8
Subject: Re: not sure plz help Mon Aug 16, 2021 5:59 pm
Glad to hear.
Rivieraz Enthusiast
Subject: Re: not sure plz help Mon Aug 23, 2021 10:48 am
the starter was replaced 2day ..... so now i have kill switch/starter button. so now i turn the key to start then push the button.
Subject: Re: not sure plz help Mon Aug 23, 2021 1:56 pm
Did he bypass the neutral safety switch?
Rivieraz Enthusiast
Subject: Re: not sure plz help Mon Aug 23, 2021 7:49 pm
he said no,the mech said,its the same as the newer cars with the push button start .he spliced one wire under the driver side kick panel and added the starter button.so i turn the key until power comes on then push the button to start
Subject: Re: not sure plz help Mon Aug 23, 2021 8:40 pm
My gut feel is he bypassed the start contacts in the ignition switch. I think yr headache comes when something else in the switch breaks, which it probably will soon. You might want to source a new switch at JEGS or RockAuto. I think the reason he woulda done this is the ig switches may not be readily available in parts stores. I am on my third. Had one fail and replaced it. When they went on close out I bought another and stored it. When the replace,Ent acted up I replaced it again. The one that’s in now, I don’t expect it to fail anytime soon. It is not doing any of the stupid stuff the first couple of switches did...
Alberto
Rivieraz Enthusiast
Subject: Re: not sure plz help Mon Aug 23, 2021 10:42 pm
albertj you are talking about a starter ignition switch or the lock cylinder or both?and one other thing before he replaced the starter he was able to get the car started by hitting the old one with a hammer.
Subject: Re: not sure plz help Tue Aug 24, 2021 3:24 pm
I'm talking about the starter ignition switch, but the lock cylinder has the contacts for the PassKey II system. If the contacts in the lock cylinder get dirty, when you try to start the car the PassKey will time out. After a (kinda long) delay you can start the car.
If your security system is locking out the starter, the time delay is just enough to make it seem like hitting the starter works to get things going.
The first thing to try to fix that, is clean the contacts in the lock cylinder by dipping a qtip in dry gas or contact cleaner, then sticking it in the lock cylinder to clean the silver pads that are just inside the escutcheon. If that does not work, then change out the cylinder for a new one. If you have already installed a PassKey bypass resistor, then the problem simply is the connection at the bypass resistor needs to be inspected and fixed.
Rivieraz Enthusiast
Subject: Re: not sure plz help Tue Aug 24, 2021 5:32 pm
other than locking the starter out would it lock out anything else? my remote door locks worked stereo worked.it wouldnt start last friday until he hit it with a hammer on monday before he put the brand new starter in
Subject: Re: not sure plz help Tue Aug 24, 2021 10:47 pm
No, it won’t lock out anything else.
Since I wasn’t there, I maybe shoulda just smiled and shut up... My context is that my starter failed about the same way, and it was the pass key II issue. My dad insisted it was the starter lol. Replacements are cheap and easy to install, so I did the replacement and the problem didn’t change (wophich no doubt is why your guy installed the button). Dad argued I got a bad starter but instead I read the fine manual and figured it out.
Rivieraz Enthusiast
Subject: Re: not sure plz help Wed Aug 25, 2021 9:48 am
thank you albertj your knowledge/wisdom is always welcome!!!!!!!
Rivieraz Enthusiast
Subject: Re: not sure plz help Wed Aug 25, 2021 2:14 pm
the starter ignition switches run from 67.00 to 300.00(oreilly auto parts)is one better than the other?
Name : Larry Age : 67 Location : Oakland Gardens, NY Joined : 2007-01-23Post Count : 2187 Merit : 149
Subject: Re: not sure plz help Wed Aug 25, 2021 2:44 pm
Rivieraz Enthusiast
Subject: Re: not sure plz help Wed Aug 25, 2021 3:19 pm
thank you Larry70GS
Subject: Re: not sure plz help Wed Aug 25, 2021 4:48 pm
I'd go with the AC Delco (GM's parts company) if possible.
Rivieraz likes this post
Rivieraz Enthusiast
Subject: Re: not sure plz help Wed Aug 25, 2021 10:34 pm
Subject: Re: not sure plz help Thu Aug 26, 2021 11:32 am
Yes, it's also the cheapest one in the list, which is good. $$ might not track quality for these.
Rivieraz Enthusiast
Subject: Re: not sure plz help Fri Sep 17, 2021 11:24 pm
i took the car to another mech, put everything back together , with a new starter to diagnose.......funny thing now its running fine(its been 3 days)
