Name : Dawson Honacher Joined : 2022-01-16Post Count : 4 Merit : 0
Subject: Newbs Sun Jan 16, 2022 7:47 am
Howdy new to The forum got myself a 96 Riviera minor work to it fwi 3.4 pulley 180 thermostat silicone hoses adjustable on the fly airride sts sway bar w/aftermarket endlinks currently porting a second supercharger to swap on along with ported intake manifold got a dhp compatible box from avt on the way Tuesday and yeah what's up guys
Subject: Re: Newbs Thu Jan 20, 2022 6:00 pm
Welcome! Sounds like you've got big plans!
RIVIerror Special
Subject: Re: Newbs Thu Jan 20, 2022 10:40 pm
Thank you and yes I try to aim for the moon as anything reasonable would be to easy so I went to the junkyard today pulled a pcm from a 97 plugged in and now it'll let me edit and upload when In doubt send good news 0kr now the tuning begins mwuahhahahahahaha
Spacecowboy067 Enthusiast
Name : Luis Joined : 2021-06-12Post Count : 105 Merit : 4
Subject: Re: Newbs Sat Jan 22, 2022 4:47 am
That reminds me I need an STS bar haha But also, what bushings and links did you use?
Subject: Re: Newbs Sat Jan 22, 2022 7:53 am
See if AA still has his Riviera Performance end links available - Link
RIVIerror Special
Subject: Re: Newbs Sat Jan 22, 2022 8:09 am
I got a set of "energy suspension" poly end links from advanced they are simple/stout I'm sure there is better stuff out there but I got em for like 20 bucks a bolt a sleeve some bushings and washers they fit well so far( being sent sideways through a few turns)
Subject: Re: Newbs Sat Jan 22, 2022 6:56 pm
Ah I guess I meant the mounts for the sway bar. I've got new poly links and bolts (I think the old ones I had were original, those bolts were very, very think lmao)
Subject: Re: Newbs Sat Jan 22, 2022 9:28 pm
Are you referring to the strut tower brace, or anti-sway bar?
Subject: Re: Newbs Sat Jan 22, 2022 9:58 pm
Sway bar, I keep hearing we can use ones from STSs but not sure what year and if it'll fit in our factory bushings or not, etc
And I usually have too much shit in my trunk to fit a strut brace back there lol
Subject: Re: Newbs Sat Jan 22, 2022 11:22 pm
It's on the forum somewhere, but I'd assume not.
Why not upgrade to the Addco bars?
Subject: Re: Newbs Sat Jan 22, 2022 11:32 pm
Idk, what's the difference?
Subject: Re: Newbs Sat Jan 22, 2022 11:45 pm
The Addco bars are thicker and I think solid instead of hollow. If you get the Addco front bar you'll also need to upgrade the front brackets to the UMI 0047 - Link. The force the Addco bar makes will bend the stock brackets and tear them out.
BTW here's a link to AA's Riviera Performance end link thread - Link
Spacecowboy067 likes this post
Subject: Re: Newbs Sun Jan 23, 2022 2:38 am
Hell yeah they looks helpful, especially with the Lucerne/Seville compatibility. Also would you have a link to where a guy can get an Addco bar? Or I suppose I could check ol' eBay
Name : Larry Age : 67 Location : Oakland Gardens, NY Joined : 2007-01-23Post Count : 2187 Merit : 149
You may have a problem getting them due to supply chain problems.
dAriel49 Amateur
Name : Jarred Joined : 2018-10-02Post Count : 45 Merit : 0
