 Do I need the fuel pump venturi port?
3 posters
Spacecowboy067
Spacecowboy067
Do I need the fuel pump venturi port?  Empty
PostSubject: Do I need the fuel pump venturi port?    Do I need the fuel pump venturi port?  EmptyMon Mar 07, 2022 4:43 pm
Like the title says, I'm installing a Walbro 255 and don't know what this little black hose is? I don't see it hooked up in any of the pictures of fuel pump jobs for 3800s,  but the new pump has a slot for the brass venturi fitting that connects to the hose except the fitting from the OEM pump doesn't fit on the walbro. Any advice? I have a hole cut out of the bottom of the canister for extra reach just in case.Do I need the fuel pump venturi port?  Screen10
Do I need the fuel pump venturi port?  Screen11
Merit : 149
PostSubject: Re: Do I need the fuel pump venturi port?    Do I need the fuel pump venturi port?  EmptyMon Mar 07, 2022 7:11 pm
PostSubject: Re: Do I need the fuel pump venturi port?    Do I need the fuel pump venturi port?  EmptyMon Mar 07, 2022 11:58 pm
IIRC the Walbro doesn't come with a venturi port. You have to buy one that has been modified to add the port. I can't recall if I got mine through Intense, ZZP, or W Body store - but at any rate all they did was drill a hole in the top of the pump and weakly glue or screw in the venturi nipple. The nipple broke off as soon as I tried to mount that black line. The black line wants to come in at an angle, so I used the JB Weld for repairing gas tanks to glue the nipple back on at an angle. It came loose again, but didn't totally come off, and I've been running it like that for a couple years with no problems. Other than that the pump won't hold pressure in the line when off, but that seems to be an inherent problem with the pump, not the mod. Turtleman switched to an even higher flowing pump that does hold pressure in the line, but I can't recall the brand off the top of my head. If it comes with a stout, properly manufactured venturi nipple I'd recommend it over the Walbro in a heartbeat.
One other thing, if you haven't mounted the white accordian line yet you are going to be hating life real soon. You really need three or four hands for that job, and a +10 resistance to heat. You only have about one second between the moment that plastic becomes malleable enough to slip over its nipple and the moment it melts away, so you might want to have spare lines handy when you do this job.
Spacecowboy067 likes this post
Spacecowboy067
Spacecowboy067
PostSubject: Re: Do I need the fuel pump venturi port?    Do I need the fuel pump venturi port?  EmptyTue Mar 08, 2022 7:19 am
Well I guess we'll see how it goes. As of all night it's running pretty well. Just sealed off the venturi nip with a grommet and cut the bottom of the canister so the filter could reach all the way. Replaced the fuel sender too. Now it finally reads accurately, so far. If it ends up failing somehow, guess I'll look for one with a better venturi built in, this walbro is just the one I happened to have at the moment and figured it couldn't be worse than my failing OEM pump haha
And I did indeed have four hands for the hose! Made it really easy other than the shitty heating
» fuel line leak. need to disable fuel pump. Fuse or relay?
» 96 fuel pump ID
» FAQ: Fuel Pump - General Questions, Compatibility & Troubleshooting
» 97 PAU the same fuel pump as a Riv?
» write up - R&R fuel pump.
