| Tailight bulbs | |
carguy8888 Junkie
Name : Brian Cohen Joined : 2019-01-07 Post Count : 805 Merit : 8
| Subject: Tailight bulbs Tue Mar 29, 2022 9:30 am | |
| I would like to replace all of the bulbs in my tail light when I change it. Are they all 3157 and how many are there please? Nothing came up in a search. Ty. | |
| Subject: Re: Tailight bulbs Tue Mar 29, 2022 10:02 am | |
| My 98 FSM lists them as 3057. I believe there are 6 all together, 4 Tail/Stop/Signal, 2 back up, and there are also 2 or more 194 bulbs. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: Tailight bulbs Thu Mar 31, 2022 8:46 am | |
| - LARRY70GS wrote:
- My 98 FSM lists them as 3057. I believe there are 6 all together, 4 Tail/Stop/Signal, 2 back up, and there are also 2 or more 194 bulbs.
Yes, six 3057 and 2 194. If you use 3157 bulbs you might want to change the 194 to 168. Fun "fact" - If you have a tail light bulb burn out and can't get a replacement immediately, just swap it with one of the back-up bulbs. The back-up bulbs use the bright filament only. Usually with a taillight, the dimmer filament burns out first. If you are going to install LEDs, I'd recommend you get the glass LEDs available via Amazon. I used these: https://www.amazon.com/AMAZENAR-2-Pack-Extremely-AK-3014-Replacement/dp/B01NA9KJ8F/ - If you get 4 of them you'll need a ballast resistor too. If you get two of them, just put them in the inboard sockets and leave conventional bulbs in the outboard sockets, and you won't have a flasher problem. | |
carguy8888 Junkie
| Subject: Re: Tailight bulbs Thu Mar 31, 2022 9:52 am | |
| Is the 194 alations plate bulb? I am only going to use LED's for the reverse lights. So it's 4 3157s A194 or 168 and a pair of reverse bulbs. I have to put this on the back burner for a bit and do elbows at is do elbow, lim gasket & Valve cover gaskets while I'm there. Yay. | |
| Subject: Re: Tailight bulbs Thu Mar 31, 2022 10:00 am | |
| - carguy8888 wrote:
- Is the 194 alations plate bulb?
Huh? _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
carguy8888 Junkie
| Subject: Re: Tailight bulbs Thu Mar 31, 2022 10:02 am | |
| Stupid auto correct. The license plate bulb. | |
| Subject: Re: Tailight bulbs Thu Mar 31, 2022 10:12 am | |
| - carguy8888 wrote:
- Stupid auto correct. The license plate bulb.
Yes, 194 or 168. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
carguy8888 Junkie
| Subject: Re: Tailight bulbs Thu Mar 31, 2022 10:18 am | |
| Subject: Re: Tailight bulbs | |
| Tailight bulbs | |
