| hard brake pedal and can`t start engine. | |
Name : Larry Age : 67 Location : Oakland Gardens, NY Joined : 2007-01-23 Post Count : 2187 Merit : 149
| Subject: Re: hard brake pedal and can`t start engine. Fri May 27, 2022 10:33 am | |
| Expensive, but the best flaring tool out there. Does everything with ease,
https://www.amazon.com/MASTERCOOL-72475-PRC-Universal-Hydraulic-Flaring/dp/B01NCYKQSN _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: hard brake pedal and can`t start engine. Sat May 28, 2022 12:39 am | |
| Been working since the last Wednesday. I've got nothing new to report yet. First thing on the list is to replace the battery. My brother says "you'll have no problem firing it once you change the battery " after that I have e to deal with the brake fluid leak.
Thanx everybody. | |
| Subject: Re: hard brake pedal and can`t start engine. Sat May 28, 2022 11:25 am | |
| - LARRY70GS wrote:
- Expensive, but the best flaring tool out there. Does everything with ease,
https://www.amazon.com/MASTERCOOL-72475-PRC-Universal-Hydraulic-Flaring/dp/B01NCYKQSN Now that's one hell of a flaring tool! | |
| Subject: Re: hard brake pedal and can`t start engine. Tue May 31, 2022 8:27 pm | |
| Hi everyone. Home now. Got the battery out. Turned out to be Duralast Gold. Receipt was stuck on it. 5 years warranty 5 years still effective . Bought on 02/ 08 / 2018. Will try to get a new replacement in a few days....haha. | |
| Subject: Re: hard brake pedal and can`t start engine. Tue May 31, 2022 8:29 pm | |
| Subject: Re: hard brake pedal and can`t start engine. Fri Jun 03, 2022 9:59 pm | |
| Little update. Replaced the battery , but still couldn't turn the engine. Only cranking sound nothing else. Have to take it to the shop .
| Subject: Re: hard brake pedal and can`t start engine. Fri Jun 03, 2022 11:12 pm | |
| So, you heard the starter motor engage, but the starter motor couldn't turn the engine over? | |
| Subject: Re: hard brake pedal and can`t start engine. Sat Jun 04, 2022 1:33 am | |
| No I didn't. Only cranking clicks and nothing else. Could be the starter | |
| Subject: Re: hard brake pedal and can`t start engine. Sat Jun 04, 2022 10:46 am | |
| YouTube has a bunch of videos about jumping the starter motor - Link | |
| Subject: Re: hard brake pedal and can`t start engine. Sat Jun 04, 2022 1:42 pm | |
| Thanx Jack the R . Will see if I can do it. I don't have a lift, but will ask friends for a code scanner.
Thanks again | |
| Subject: Re: hard brake pedal and can`t start engine. Sat Jun 04, 2022 5:42 pm | |
| You don't need a lift to jump the starter motor. I can't remember if I had the front jacked up or not when I was fooling around down there, but I don't think i did. | |
| Subject: Re: hard brake pedal and can`t start engine. Sat Jun 04, 2022 11:39 pm | |
| So I need to put the screwdriver on the positive and touch negative (ground). Right? Thanks Jack the R | |
| Subject: Re: hard brake pedal and can`t start engine. Sun Jun 05, 2022 2:14 am | |
| Maybe Albert J can say. I linked to the videos because I don't know how I jumped the starter - but it was easy to do accidentally. | |
| Subject: Re: hard brake pedal and can`t start engine. Sun Jun 05, 2022 2:53 am | |
| Ok I see. Will talk to my brother next week Thank you Jack the R.
| Subject: Re: hard brake pedal and can`t start engine. Mon Jun 06, 2022 10:16 am | |
| - Jack the R wrote:
- Maybe Albert J can say. I linked to the videos because I don't know how I jumped the starter - but it was easy to do accidentally.
You probably jumped it by touching a screwdriver (or wrench) to the positive wire feeding the starter and the switched wire feeding the solenoid, simultaneously... They both appear on the starter solenoid, side by side. | |
| Subject: Re: hard brake pedal and can`t start engine. Mon Jun 06, 2022 10:36 am | |
| Well there you go, Stan. Have at it! | |
| Subject: Re: hard brake pedal and can`t start engine. Mon Jun 13, 2022 2:47 pm | |
| Tomorrow I'm getting the car towed to the shop. It was originally set for today but the truck guy couldn't come over today. We had to reschedule. Still nervous about it... Will keep you guys informed. Hope it ain't seazed engine. Too bad I've got nothing new to report but....hopefully soon. Thanx
| Subject: Re: hard brake pedal and can`t start engine. Mon Jun 13, 2022 6:39 pm | |
| Who knows, maybe it will just be a small thing | |
| Subject: Re: hard brake pedal and can`t start engine. Mon Jun 13, 2022 7:16 pm | |
| - Jack the R wrote:
- Who knows, maybe it will just be a small thing
Hope that too. This is what my brother's been telling me since I first found out about the problem. Will know more tomorrow. Thanx... Jack the R. | |
| Subject: Re: hard brake pedal and can`t start engine. Mon Jun 13, 2022 10:36 pm | |
| Starters do wear out. However, I still have the original starter for my Riv, and it works. I replaced it to satisfy my dad that the starter was not the problem, some years ago, when I was having difficulties with starting the car. It turned out to be a problem with the anti-theft stuff, which I repaired by replacing the ignition switch and keyway. | |
| Subject: Re: hard brake pedal and can`t start engine. Wed Jun 15, 2022 7:10 pm | |
| Hi everybody! Got the car back from the shop. Had a bad fuel pump and brake lines ( partially ) changed. Took 24 hours for him to fix it. Now it starts and runs like a champ. Everything was done for $850 . Thanx again friends. | |
| Subject: Re: hard brake pedal and can`t start engine. Wed Jun 15, 2022 9:57 pm | |
| - stan wrote:
- Hi everybody!
Got the car back from the shop. Had a bad fuel pump and brake lines ( partially ) changed. Took 24 hours for him to fix it. Now it starts and runs like a champ. Everything was done for $850 . Thanx again friends. I'm impressed. Albertj | |
| Subject: Re: hard brake pedal and can`t start engine. Wed Jun 15, 2022 11:22 pm | |
| The pump comes with 12 months warranty period. Mechanic said 10 months free replacement, parts and labor. Totally free. | |
| Subject: Re: hard brake pedal and can`t start engine. Thu Jun 16, 2022 3:53 am | |
| Just the brake lines? I don't see how that could make the pedal solid when the master cylinder was empty, but if it works now than it works. | |
| Subject: Re: hard brake pedal and can`t start engine. Thu Jun 16, 2022 4:36 am | |
| - Jack the R wrote:
- Just the brake lines? I don't see how that could make the pedal solid when the master cylinder was empty, but if it works now than it works.
He said, i have a brake leak. Had to replace the parts of the lines that are rusted out. I saw them laid on the floor 4 of them , between 4 or 5 feet long each of them. The rest of the lines he said didn`t need to be replaced ( yet ) . Now i have a new battery in, soft pedal and a new fuel pump. Drove the car back home, the mother turned ,fired the ran quiet .Even the handset worked . | |
| Subject: Re: hard brake pedal and can`t start engine. | |
