 Power trunk failure
Power trunk failure Empty
PostSubject: Power trunk failure   Power trunk failure EmptySat Jul 28, 2007 1:36 am
Tonight my power trunk release failed on me. Neither the remote nor the door switch will open it. I'll dig into the service manual when I find some time, but wondered if anyone else has experienced a failure in both, and what problems you found, how fixed? I'm figuring maybe a fuse, or wiring at the trunk latch is bad. Anyone have a good idea on this?
(don't worry, I did remember my key also works... dunce )
comanche221
PostSubject: Re: Power trunk failure   Power trunk failure EmptySat Jul 28, 2007 10:33 am
on your fob hit trunk when standing near, do u hear it----if so take it off , ur plastic arm broke, in the center where it broke,drill a small hole for a 3/4 sheetrock screw, leave 1/2 of it sticking out, wiggle it back in there and test........
comanche221
PostSubject: Re: Power trunk failure   Power trunk failure EmptySat Jul 28, 2007 10:35 am
on the trunk release....
PostSubject: Re: Power trunk failure   Power trunk failure EmptySat Jul 28, 2007 5:21 pm
Nope, don't hear anything when I hit the release. Didn't notice anything that appeared to be broken.
Merit : 135
PostSubject: Re: Power trunk failure   Power trunk failure EmptySat Jul 28, 2007 7:37 pm
Mine hasn't worked since I got the riv. If I short the terminals at the relay (underneath back seat) It opens no problem. I've tested all the switches and such on the circuit. all good. I have a feeling it might have been disabled when the remote start system was installed before I got the car of a connection went bad with it somewhere. I suppose none of this really applies to you but thats another place you can test it at - the relay
PostSubject: Re: Power trunk failure   Power trunk failure EmptySat Jul 28, 2007 10:32 pm
Check the switch in the glove compartment. This probably is not your problem since the fob doesn't work either.
PostSubject: Re: Power trunk failure   Power trunk failure EmptySun Jul 29, 2007 12:53 am
Correct.
comanche221
PostSubject: Re: Power trunk failure   Power trunk failure EmptySun Jul 29, 2007 1:21 am
Trying to help,thats what was wrong with my trunk, it took 5 min' to fix .
PostSubject: Re: Power trunk failure   Power trunk failure EmptySun Jul 29, 2007 11:06 am
I appreciate any suggestions, thanks! I may not find time to dig into this real soon, but was hoping for someone with easy to test ideas. wink
PostSubject: Re: Power trunk failure   Power trunk failure EmptyThu Feb 07, 2008 9:55 pm
Put a screw in it?
I know this is a old post but was wondering how to rig one of these with a screw?
Bert
Power trunk failure
» Power Mods ????
» power chips or modules
» Power Plays
» Repairing power lead
» Duro Power-Grips ,25x8x12,25x10x12 $125.00
