 Engine ping in Series II
PostSubject: Engine ping in Series II   Sun Jul 29, 2007 1:57 pm
My parents have a 97 Pontiac with a NA Series II. It's always had this engine ping for lack of a better word. I've tried higher grade fuel but that hasn't helped? Can I adjust something to make it quit if I find someone with a tuner?
PostSubject: Re: Engine ping in Series II   Sun Jul 29, 2007 8:59 pm
The plugs I pulled out of it were AC 41-921.
PostSubject: Re: Engine ping in Series II   Sun Jul 29, 2007 9:10 pm
maybe something in it is broke, there are alot of other things that can make a knock noise. does it only do it at idle or at all rpm? does the ping stay steady or does it change with the valve motion?
PostSubject: Re: Engine ping in Series II   Sun Jul 29, 2007 9:14 pm
I would say it steady. Noticable at highway speeds. My mom discribes it as "keys jingling". lol
PostSubject: Re: Engine ping in Series II   Sun Jul 29, 2007 9:45 pm
bad coupler? just a guess, b/c i really cant tell you much without actualy hearing it or knowing more about the noise. sorry.
PostSubject: Re: Engine ping in Series II   Sun Jul 29, 2007 10:04 pm
It's not supercharged.
I think my parents are going to give me the car. I thought about using the engine and tranny in da riv. I'd just need a supercharger for it. But I'd like to get the "ping thing" worked out before I'd consider it for an engine swap.
PostSubject: Re: Engine ping in Series II   Sun Jul 29, 2007 10:42 pm
my bad lol i didnt reread the N/A part
if you plan on doing a swap you may be better off selling the GP and buying a L67 to drop in. they go for pretty cheap.
can you feel the ping or just heap it? could it be an exhaust tick/leak?
PostSubject: Re: Engine ping in Series II   Sun Jul 29, 2007 10:49 pm
I can't feel it, just hear it. It doesn't seem to affect performance, more annoying than anything. I thought maybe I could adjust something to fix it since it is a series II. Then I thought maybe a cooler range plug, but I don't know if that make a difference since it's not SC. dunce
PostSubject: Re: Engine ping in Series II   Mon Jul 30, 2007 8:59 am
I'd get it scanned to see if it's reading as KR. If it is a true knock issue, would be a good idea to do a fuel system and top engine clean. Otherwise, the noise could be the belt, lifters, a rocker, or something worse. Maybe the old screwdriver to the ear trick would help locate the source?
