carguy8888 Junkie
Name : Brian Cohen Joined : 2019-01-07 Post Count : 805 Merit : 8
| Subject: Horn issues Sat Jul 29, 2023 1:49 pm | |
| Horn is suddenly not blowing when I hit the buttons. No clicking or sound at all and the fuses are good in the box on the driver side dash. They will blow if direct power is applied to the horn. Is there a relay I can check or is the problem in the airbag? If so do any other more popular cars share the same airbag I can swap over. If I have no choice I will add a button to activate it. Ty. Brian | |
| Subject: Re: Horn issues Sun Jul 30, 2023 11:54 pm | |
| you can probably take it apart and custom cut yourself a membrane switch | |
carguy8888 Junkie
| Subject: Re: Horn issues Mon Jul 31, 2023 6:41 am | |
| Thank you Albert, it was not a pressure problem in the wheel. I was not getting any power which turned out to be a blown fuse. Thankfully it was an easy fix. | |
| Subject: Re: Horn issues Mon Jul 31, 2023 10:52 am | |
| - carguy8888 wrote:
- Thank you Albert, it was not a pressure problem in the wheel. I was not getting any power which turned out to be a blown fuse. Thankfully it was an easy fix.
You had written that you checked the fuses - this is interesting - what actually happened? | |
| Subject: Re: Horn issues Mon Jul 31, 2023 5:59 pm | |
| - albertj wrote:
You had written that you checked the fuses - this is interesting - what actually happened? He checked all the fuses that he knew about. I texted him a page from the Service Manual showing the location of the Horn Fuse and Relay. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
carguy8888 Junkie
| Subject: Re: Horn issues Wed Aug 02, 2023 7:17 am | |
| Albert, A guy checked the fuses on the driver side of the dash and looked at the box in the engine compartment quickly,I guess he didn't check them. Thanks Larry, that diagram helped. It's also on the inside of the fuse box in the engine bay now I found out. 20 amp fuse was popped and I was able to change it without asking anyone or taking apart my steering column. No idea how it happened but crisis averted. | |
