Radio & window power staying on after door is open
4 posters
Author
Message
redbaron Amateur
Name : Joseph Contardi Location : North East PA Joined : 2021-05-21Post Count : 38 Merit : 2
Subject: Radio & window power staying on after door is open Fri Jan 19, 2024 9:01 pm
Pulled accessory relay. Coil pulls in when reinstalled. Is this a body control module issue?
Subject: Re: Radio & window power staying on after door is open Sun Jan 21, 2024 12:28 am
Same behavior with both doors - probably BCM
With one door? Probably door latch
redbaron Amateur
Subject: Re: Radio & window power staying on after door is open Sun Jan 21, 2024 6:15 pm
Thank you much Al,
Yes, both doors.
I ordered a bcm from ebay last night.
Joe
Subject: Re: Radio & window power staying on after door is open Mon Jan 22, 2024 8:42 pm
redbaron wrote:
Thank you much Al,
Yes, both doors.
Joe
WHile you are waiting, check the wiring.
Did the BCM ever get wet that you know of?
redbaron Amateur
Subject: Re: Radio & window power staying on after door is open Tue Jan 23, 2024 7:34 pm
No ,but this car was parked for 2-3 months just prior to this issue.
Subject: Re: Radio & window power staying on after door is open Tue Jan 23, 2024 11:51 pm
While waiting for that BCM, check those door latches. You'll want the wiring diagram out of the service manual, which you should buy a copy for yourself, they are almost always on eBay for a reasonable price.
Why bother with the door switches??
The microswitches may both have issues due to sitting and age.
redbaron Amateur
Subject: Re: Radio & window power staying on after door is open Wed Jan 24, 2024 8:05 pm
Thanks Albert, Will do.
Joe
Name : Larry Age : 67 Location : Oakland Gardens, NY Joined : 2007-01-23Post Count : 2184 Merit : 149
Subject: Re: Radio & window power staying on after door is open Thu Jan 25, 2024 9:54 am
What you are referring to is called Retained Accessory Power, and the FSM has a trouble diagnosis chart. That is the easiest way to figure out what is going on without pulling your hair out.
albertj and Eldo like this post
Subject: Re: Radio & window power staying on after door is open Sat Jan 27, 2024 11:21 pm
Larry is 125% right on this one, I should have asked. Do you have a copy of the FSM?
ADDvanced Amateur
Name : ADDvanced Joined : 2024-03-18Post Count : 49 Merit : 4
Subject: Re: Radio & window power staying on after door is open Fri Mar 22, 2024 4:03 pm
Anybody have a part number for the door switch? The radio turns off if I open and close the pass side door, but not the driver's side door, so I'm assuming the switch is bad.
Subject: Re: Radio & window power staying on after door is open Fri Mar 22, 2024 5:18 pm
I believe it is built into the latch.
ADDvanced likes this post
