| FAQ: Dexcool / Coolant / Antifreeze Types | |
+36Ironclad-454 Ship BKRIV Eldo Chicken Jack the R manofmany Rickw maggot albertj deekster_caddy ibmoses 98RIV7777 98riv Buapo T Riley steve1173 robotennis61 97Ultra xxsupergman25xx BillBoost37 TType_Riviera palermocorey90 turtleman rivieraman Jason 97rivman 1998 Riv arttu80 NO 4 EVR racinfan Brad95Riv 96riv AA Mr.Riviera ¤DoughBoy¤ 40 posters |
Jason Aficionado
| Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Fri Aug 10, 2007 5:43 pm | |
| I just run tap water when I need to top it up. You can just flush the old orange (dexcool) stuff out and replace it with regular green antifreeze in the proportion you prefer. Just make sure to change it every 2 years. | |
rivieraman Special
| Subject: dexcool cost Fri Sep 21, 2007 12:42 pm | |
| $11.95 I work at autozone I know | |
| Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Fri Sep 21, 2007 2:53 pm | |
| Just use the color that's supposed to be in there. If it's the old green stuff (i would expect to see this in a 95 if anything) use whatever brand the store has. As long as you mix it right or buy the premixed, it doesn't matter.
More likely, it's the pink/orange dexcool fluid though so I would just get the Prestone Dexcool that every place i've seen has.
If you have a 95 (green coolant?) or you suspect that maybe someone put the wrong fluid in at some point, get it flushed. If you can't flush it soon, Use the "mixes with all" fluid that Peak and Prestone makes. The properties of these fluids is very similar to that of dexcool but can be safely used on systems that have the old green glyco fluid in them still. bottom line is get it flushed if there are any areas of question.
Also, the Redline water wetter does work well for what it is. If you're doing a flush or changing your coolant, throwing a bottle of that into the mix won't hurt our system. | |
palermocorey90 Expert
| Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Wed Oct 17, 2007 5:39 pm | |
| i bought dexcool prestone stuff premixed 50/50 for 11.95 as stated before | |
| Subject: dexcool antifreeze in a series 1 Wed Nov 28, 2007 7:31 pm | |
| can i run dexcool in my my riv its a series 1, im pretty sure its called dex cool | |
TType_Riviera Fanatic
| Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Wed Nov 28, 2007 8:45 pm | |
| did it come factory??...pretty sure it didnt.....otherwise run th green stuff.. | |
| Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Wed Nov 28, 2007 8:58 pm | |
| damn i already bought it, 6 gallons of that stuff, it didnt come factory. i prolly should have checked before i bought it | |
| Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Wed Nov 28, 2007 9:01 pm | |
| its usually not a good idea to mix them.... | |
Jason Aficionado
| Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Wed Nov 28, 2007 9:54 pm | |
| you can't mix them. I would just return the dexcool to the parts store and buy the regular green stuff. | |
| Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Wed Nov 28, 2007 10:14 pm | |
| or flush the system ,get new hoses, and run the dex cool _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Thu Nov 29, 2007 10:22 am | |
| - Mr.Riviera wrote:
- or flush the system ,get new hoses, and run the dex cool
i already did that, thats why i wasnt sure if i could use it | |
BillBoost37 Junkie
| Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Thu Nov 29, 2007 10:26 am | |
| GM changed a lot of things to make the Dex work properly. Used in the wrong system it can be corrosive. Most of these changes were invisible to us since it was implemented pretty much with the new S2 motors.
I agree with returning it and getting the green or anycolor versions.
6 gallons seems like a lot to me. Concentrated my car takes about 1-2 gallons at most. In the 50/50 mix say 4 gallons. While your cars are bigger and might use a bit more....6 seems like a lot. | |
¤DoughBoy¤ Enthusiast
Name : D.J. Age : 36 Location : Gary Indiana Joined : 2007-02-10 Post Count : 219 Merit : 0
| Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Thu Jan 17, 2008 5:43 am | |
| I don't want to sound dumb....but what exactly is the green stuff.....can I get a name.... | |
| Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Thu Jan 17, 2008 5:51 am | |
| and if u mix the two it can be corrosive as in eating away at the hoses or what? worst than that? | |
xxsupergman25xx Aficionado
Name : Scotty Age : 37 Location : Pittsburgh, PA Joined : 2007-03-03 Post Count : 1251 Merit : 13
| Subject: Coolant Tue Feb 26, 2008 7:29 pm | |
| what kinda coolant goes in the 95 s/c riv......when i got it it was pink dex cool...then it recently went in the shop and its now lime green...i was told the wrong coolant was put in it all the time...what coolant do u guys have in? | |
| Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Tue Feb 26, 2008 8:03 pm | |
| 95s us the normal green, 96-99 use the pink stuff | |
96riv Fanatic
| Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Sun Mar 02, 2008 7:39 pm | |
| I use water and RMI 25, no need for antifreeze in the Desert. | |
97Ultra Special
| Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Mon Mar 03, 2008 11:59 am | |
| Most of the new Dex-Cool compatible coolants are green, not red. Same stuff, just a different dye added. So it may well have been the correct coolant, since you can't go by the color anymore. | |
| Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Mon Mar 03, 2008 3:17 pm | |
| whats "RMI" 96riv? im in vegas and the winters are mild here. arent you afraid of corrosion? i heard running straight water can lead to problems? | |
96riv Fanatic
| Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Mon Mar 03, 2008 7:23 pm | |
| Most of the Turbo Buick owners in AZ use this product. It helps to clean and protect your cooling system
http://arizonagn.net/how_to.htm | |
| Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Mon Mar 03, 2008 9:39 pm | |
| heres the good stuff.... Evans waterless coolant
http://www.evanscooling.com/main25.htm | |
| Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Tue Mar 04, 2008 12:14 am | |
| Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Tue Mar 04, 2008 7:42 am | |
| not cheap but will last the life of your car! | |
| Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Thu Mar 13, 2008 12:30 am | |
| when you say " life of car" does that mean you can resuse it in case you need to drain for repairs? | |
steve1173 Amateur
Name : stephen rabinowitz Location : punta gorda, fl Joined : 2008-05-25 Post Count : 40 Merit : 0
| Subject: Changing the Coolant Sat May 31, 2008 10:05 pm | |
| On my 98 with 78000 miles my mechanic is flushing out the coolant and replacing it with the green stuff. He says after a complete flush it is better then the original, hope he is right as I heard horror stories from others about a possible mix. | |
| Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types | |
