 Series I (Supercharged) Write-Up Index
Series I (Supercharged) Write-Up Index Empty
PostSubject: Series I (Supercharged) Write-Up Index   Series I (Supercharged) Write-Up Index EmptyMon Aug 13, 2007 4:40 pm
RIVIERICA
PostSubject: Re: Series I (Supercharged) Write-Up Index   Series I (Supercharged) Write-Up Index EmptyFri Mar 06, 2009 3:36 pm
Might I suggest one for changing the super charger coupling ? My searches suggest that bearing failure is not common but it could also be included. I also noted that a new coupler runs about $30.00. ZZP brand was recommended but I have found no contact info.
Merit : 122
PostSubject: Re: Series I (Supercharged) Write-Up Index   Series I (Supercharged) Write-Up Index EmptyFri Mar 06, 2009 4:24 pm
like this one?
http://rivperformance.editboard.com/series-i-engine-transmission-f13/write-up-95sc-changing-the-coupler-in-an-eaton-m62-t4421.htm
PostSubject: Re: Series I (Supercharged) Write-Up Index   Series I (Supercharged) Write-Up Index EmptyFri Mar 06, 2009 5:11 pm
Thanks, Andrew. Added to the list!
perbe
PostSubject: Re: Series I (Supercharged) Write-Up Index   Series I (Supercharged) Write-Up Index EmptyFri Aug 14, 2009 10:03 am
I am looking for a write up on replacing the Tensioner Pulley on a 95 Series 1 SC 3800.
I have chirping at an idle, the car has 101,500 miles. I am the 3rd owner and both previous owners maintained the car very well. I figure with this many miles I will replace the SC Coupler as well.
I see a lot of mentions of replacing the tensioner pulley just cant find a write up. It has been years since I have done my own wrench turning and I would rather not fudge it up.
PostSubject: Re: Series I (Supercharged) Write-Up Index   Series I (Supercharged) Write-Up Index EmptyFri Aug 14, 2009 10:28 am
There is not yet a specific write-up for Series I tensioner pulley install, but I would encourage you to create one!
Here is a SC pulley write-up that give some helpful info:
http://rivperformance.editboard.com/series-i-engine-transmission-f13/write-up-how-to-install-an-aftermarket-sc-pulley-series-i-t112.htm
Good luck!
» Lucas Oil Off Road Racing Series Short Course---USTREAM TV Live
» Melton 400m Series - 22nd & 29th July
» hmf swamp series exhaust
