 Where did the Anti-Freeze go????
Straighteight
PostSubject: Where did the Anti-Freeze go????   Sat Jan 27, 2007 10:03 am
dunno At 34,000 miles my antifreeze is down about a half a quart. Do these engines have the same coolant leak problem as the earlier models? This is for a 2004 Park Avenue without the supercharger.
I've a couple a Rivies, but right now they hold anti-freeze.
PostSubject: Re: Where did the Anti-Freeze go????   Sat Jan 27, 2007 1:20 pm
overflow? half a quart really isnt that bad if you've never touched it since new. hoses feel ok? i would just add some water (or water wetter) to it and keep an eye on it. if it loses more then be worried, if not then dunno
Matthew
duffy
PostSubject: Re: Where did the Anti-Freeze go????   Tue Feb 13, 2007 8:14 am
Well, Straighteight... as the owner of a brand new intake manifold that had been "causing a mystery" I'll tell ya. The antifreeze gets worn out, and attacks the plastic of the intake manifold, causing a very slow drop in coolant level. My car was "losing" about a quart a month, that is, until a catastrophic break in the plastic sent a huge amount of coolant into the intake... (LARGE cloud of steam out of the exhaust). Have the cooling system "pressure tested" and if it isn't holding pressure, I would suspect the intake. There are replacements that are better than OEM that are cheaper.
