 need a little help on my 95 riv sc
misternh
need a little help on my 95 riv sc Empty
PostSubject: need a little help on my 95 riv sc   need a little help on my 95 riv sc EmptyFri Aug 17, 2007 7:55 pm
i got a 95 riv sc,and it dies after warm up ,just dies instantley .
then if i wait 5 or 10 min it will start again but die again as well,ive replaced the fuel pump ,fuel filter ,3 coils ,crankshaft sensor ,harmonic balancer .what should i be looking for to be the culprit of it dying ,i ve had this car for 6 years and would never consider giving it up .and thank god i can do all the work myself.but this one got me quite baffled .do i have to reset the computer after doing all that work ? thanks
PostSubject: Re: need a little help on my 95 riv sc   need a little help on my 95 riv sc EmptyFri Aug 17, 2007 7:59 pm
Interesting... sounds like a fueling issue, but you've replaced the pump and filter. Might want to get a scan done to check for DTCs (codes). Did this problem start all at once, or gradually get worse over time?
misternh
PostSubject: Re: need a little help on my 95 riv sc   need a little help on my 95 riv sc EmptyFri Aug 17, 2007 8:12 pm
just started ,comming home the car died .first thought was dam fuel pum went .so i replaced it and the filter ,but started it and it died again after about 3 min.so i thought ok crankshaft sensor heating up and killing the motor ,so i replaced it ,and the harmonic at same time.so iam baffeled ,maybe the os sensor? will that kill the car after warm up
