 what is stock cam specs for 95 riv
scoopy03
what is stock cam specs for 95 riv Empty
PostSubject: what is stock cam specs for 95 riv   what is stock cam specs for 95 riv EmptyTue Aug 21, 2007 2:55 pm
i was wondering what is the stock cam spec for a 95 rivi. i was looking up some cam and wanted to be able to tell how much of a difference it is over the stock cam. also if you have some places to recommend that would be appreciated
scoopy03
PostSubject: Re: what is stock cam specs for 95 riv   what is stock cam specs for 95 riv EmptyMon Sep 03, 2007 1:58 pm
anybody?
PostSubject: Re: what is stock cam specs for 95 riv   what is stock cam specs for 95 riv EmptyMon Sep 03, 2007 2:38 pm
Don't know those specs, but here is some cam info from seriesoneperformance.com:
C.C. Street Grind
Part #61:
Doing a rebuild and want a little more power without having to spend money on supporting mods? This cam is perfect for you!
what is stock cam specs for 95 riv E_punct_b Valve Timing:
Intake: 23*/59*
Exhaust: 68*/16*
what is stock cam specs for 95 riv E_punct_b Duration (seat to seat):
Intake: 262*
Exhaust: 264*
what is stock cam specs for 95 riv E_punct_b Duration (0.075"):
Intake: 193*
Exhaust: 202*
what is stock cam specs for 95 riv E_punct_b Valve Lift:
Intake: .440"
Exhaust: .440"
what is stock cam specs for 95 riv E_punct_b Power Range: 1500-5500rpm
PostSubject: Re: what is stock cam specs for 95 riv   what is stock cam specs for 95 riv EmptyMon Sep 03, 2007 2:39 pm
And one for street/strip use:
C.C. Street/Strip Grind
Part #62:
Designed for engines with an aftermarket exhaust system, our Street/Strip grind is perfect for the mid-level performance enthusiast.
Intake: 22*/64*
Exhaust: 70*/20*
Intake: 265*
Exhaust: 270*
Intake: 201*
Exhaust: 206*
Intake: .440"
Exhaust: .440"
what is stock cam specs for 95 riv E_punct_b Power Range: 1800-6000rpm
scoopy03
PostSubject: Re: what is stock cam specs for 95 riv   what is stock cam specs for 95 riv EmptyWed Sep 05, 2007 12:41 am
that was about all i could find too frown
PostSubject: Re: what is stock cam specs for 95 riv   what is stock cam specs for 95 riv EmptyWed Sep 05, 2007 1:12 am
go to www.3800pro.com and on the lower left side of the pages, there's a link to cam specs, including stock I believe.
» 450 Stock Muffler
» WTB STOCK RZR SEATS
» stock rhino bumper
» Intrusion bars for your stock cages
» Wanted - (2) Stock Rhino seats.
