Power seat problem 5 5 2
 Power seat problem
Goto page : 1, 2, 3, 4, 5  Next
SupersportSteve
Trainee
Merit: 2
PostSubject: Power seat problem   Mon Sep 10, 2007 12:08 pm
Shortly after I purchased the Riv, the driver's side power seat stopped going forward. When I checked it out, I found a jumper wire coming from the switch, with an alligator clip on the other end, just laying there. After investigating, I found out it's a ground. When I hook the jumper to the little grounding tab under the seat, it will go forward, but gets pretty hot. How are the switches supposed to be grounded, and is the bad ground my only problem?
http://www.csb25.com
blackbart95
Merit: 3
PostSubject: Re: Power seat problem   Wed Oct 10, 2007 11:33 am
It sounds like the bad ground is your only problem. Its very likely that the wire gage used in the jumper cable is too small and that is why it is getting so hot. Do not use it long term as it could cause a fire. flame I would do a little digging and see why you have a bad ground (rust or loose connection???). If you can't find the root cause the next best thing is to run a jumper wire, of the proper size, similar to what you found before. My guess is that 12 gauge wire should work. It should safely handle 20 amps.
BrokenDownInTheYard
Merit: 0
PostSubject: Re: Power seat problem   Wed May 21, 2008 4:34 pm
That happened to my seat too all the other switches work fine, except backwards ... I've unbolted the seat and investigated also...
Except I found about 15 wires going nowhere, coming from nowhere.... I need a diagram of where they're posta go...
My seat goes forward not back, and over the years I've kicked the button a few times and my seats all the way pushed up....
Anyway I manually shoved the seat back by unscrewing an buncha crap
R1V13RA
Trainee
Merit: 0
PostSubject: no signature   Wed Jun 10, 2009 1:09 pm
my driver side power seat doesn't recline!! i changed the pump out, and it does the exact same thing....it sounds like its tryin to recline, but it dont move....but the seat goes in all the other directions....just that one pump, so i wuz thinkin that maybe its the seat that's jammed....idk any suggestions?
rivman96
Merit: 1
PostSubject: Re: Power seat problem   Thu Sep 10, 2009 5:09 pm
I have a similar problem. All the switches work, except the one that reclines forward or backward, it simply has no response at all. Not sure what to do about it it just started doing it yesterday.
Name:
Merit: 100
PostSubject: Re: Power seat problem   Thu Sep 10, 2009 5:31 pm
Steve: do you have seat memory and does it still work?
Autumn: what year is your Riv?
Dino: what pump?
Cameron: please check the bundle of wires coming out of the seat switches. If you follow them you will see where they run kinda close to the seat frame. Check for scraped/chafed wires. Also it might be you lost the recliner motor - after many years the magnets can come unglued and the motor will quit running. If there is not a wiring problem you can get replacement motors off RockAuto.Com.
Merit: 96
PostSubject: Re: Power seat problem   Thu Sep 10, 2009 6:04 pm
I didn't even know our seats reclined until recently, DUH.
R1V13RA
Trainee
Merit: 0
PostSubject: Re: Power seat problem   Sun Oct 11, 2009 6:41 pm
Dino: what pump?
the motor...my bad...the motor for the power seat is wut i changed out, but it still didnt work, so i permanently have to sit straight up! frown been lookin to buy sum leather ones, or at least a driver on that will go work correctly, u kno
Merit: 96
PostSubject: Re: Power seat problem   Sun Oct 11, 2009 7:20 pm
Not tryin' to be a smartass, but are you sure you replaced the right motor?
There are 4 of them under there, and the diagrams I'm looking at don't make it too clear...
Failing that, I'd say that the gears or drive cables are stripped at the hinge-point in the bottom of the seatback.
Merit: 96
PostSubject: Re: Power seat problem   Sun Oct 11, 2009 7:23 pm
Replacing a "Pump", that would indicate to me that you replaced the lumbar pump.
Has nothing to do with the recline motor. And as Eldo said there are 4 motors that you need to isolate the one that isn't working.
Merit: 96
PostSubject: Re: Power seat problem   Sun Oct 11, 2009 7:51 pm
Actually, he corrected himself in the post prior to mine, he meant motor. Also (just because I have soooo much trivia stuck in my head) our cars don't use air pumps for the lumbar.
The Aurora used an air bladder, but our seats use a padded, flat strap, probably seatbelt webbing, that is anchored on one side of the seatback, and tied onto an electric retractor on the other side.
The other thing we got 'cheated' out of was memory control for the recliner. The LeSabre/Park Ave had it, but noooooo, not Rivieras...
Name:
Merit: 100
PostSubject: Re: Power seat problem   Sun Oct 11, 2009 9:44 pm
There seem to be a number of power seat problems that people have decided to 'live with.' Here are some insights you may find helpful.
1) you may want to get a couple small cables with alligator clips on each end from RAdio Shack so you can try to move the seat on its stracks enough to expose the mounting bolts in the rear. THat is, move it forward far enough so you can remove those 2 bolts, tilt it forward and take it out. While you have it out, clean up the area under the deat.
2) If you are ever going to fix these things, do it sooner rather than later because with the 2009 model year ending, GM does not have to keep parts around for the 1999 Rivieras anymore. Many of the parts you will want to get will change from plastic and metal to Unobtanium in a couple-three months.
3) The more parts in an assembly that are subject to wear and tear, the harder it is to troubleshoot remotely. The seats have internal moving parts, actuator motors, cams and shafts... lots of parts. It's just not easy 'cause there are multiple causes of failures and multiple points to fail.
4) There are visual clues that help troubleshooting that are not communicated in your postings. Such as whether you're the original owner, when the problem started - even looking at how worn the switches are can give useful clues. Point is that for some of you the quickest fix will be to get a factory service manual.
5) Most of you seem unfamiliar with basic electrical troubleshooting, and probably were not necessarily looking for this opportunity to learn. Notwithstanding, here are some resources to get a troubleshooting 'mindset' that you might find useful:
http://firechief.com/apparatus/electrical-trouble061307/
http://www.autoshop101.com/forms/h2.pdf (basic troubleshooting tutorial from Toyota)
http://www.autoshop101.com/ (a family of tutorials from Kevin Sullivan, San Bruno College - these are pretty quick reads and explain a lot. Recommended for newbies and as a refresher for those wanting to 'brush up' skills)
http://www.aa1car.com/library/tselec.htm (very basic)
Happy reading - and hopefully the advice you get will make a lot more sense after you complete the Kevin Sullivan tutorials.
Merit: 30
PostSubject: Re: Power seat problem   Sun Oct 11, 2009 10:23 pm
If the heating element for the driver side mirror is shorted out would that cause the heated seat to not work?
Thanks for any info.
Bert tavis
Merit: 96
PostSubject: Re: Power seat problem   Mon Oct 12, 2009 10:55 am
I don't know Bert, the 98 wiring diagram doesn't even have the heated mirror's on it.
There is no way to troubleshoot this problem with the wiring diagram because of the lapse of GM technical writing dept.
The heated seats are clearly spelled out, but if there is any inter-relationship between the two is hard to know.
I suspect they do share some of the circuitry, but that is just my guess at this point.
Maybe someone with AllData could look it up there and see what they have on the heated mirrors.
Merit: 96
PostSubject: Re: Power seat problem   Mon Oct 12, 2009 4:07 pm
Well, as you know Rick, I got completely frustrated by those mysterious missing heated mirrors... However, if they operate like every Cadillac with the same climate control guts, and little 'heated' icons on the glass, they turn on along with the rear defogger and would have nothing to do with the seat heaters, except maybe a common fuse or circuit breaker somewhere.
My best guess...
Power seat problem
Page 1 of 5Goto page : 1, 2, 3, 4, 5  Next
» WR250R can I lower my seat ?
» mazda dpf problem
» Stuck....and loosing will power!!
» FtwRyan power abuse
» Message for Andy Booth : RE PD170 Seat Altea XL : DPF light come back on after DPF delete
