Name : Josh Joined : 2012-08-08Post Count : 14 Merit : 0
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Fri Nov 16, 2012 7:16 pm
there is almost no room i either need a lift or some c4 to blow this fucker up also autozone said there is a special battery that i need to get
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Fri Nov 16, 2012 7:36 pm
ok,the picture is a little broader now. if you dont have any work room and no leverage or space for tools,you have to get that battery.i mean,you cant drive the car without one! as for the special battery,well theyre big fuckers thats for sure.and az dont allways have em.you can also use a optima battery.you might have to splice in a longer negative cable.i had to. get the battery and bump the bolt. if you cant wrap your head around all the suggestions,consider a mobile mechanic to come to the house.
dartcars Rookie
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Fri Nov 16, 2012 7:42 pm
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Fri Nov 16, 2012 7:43 pm
rivparadise Fanatic
Name : Samuel Age : 51 Location : Niagara Co. Joined : 2007-06-11Post Count : 381 Merit : 11
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Fri Nov 16, 2012 8:55 pm
Impact fer sure! Never had a problem with good air tools.
Name : Location : Finger Lakes of New York State Joined : 2007-05-31Post Count : 8576 Merit : 180
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Sat Nov 17, 2012 1:39 am
Ummmm.... you need a "Group 79" battery. If you want a cheap way out call some junkyards in your area and find one. They were in many mid-90s and early oughties ('00) CBOP (Cadillac, Buick, Olds, Pontiac) cars. I imagine from a junkyard you are talking $25 to $50 depending on condition and the yard's avarice.
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Sat Nov 17, 2012 3:48 am
....i dont know aj,i think he C4'd the fucker and blew the block up!
dartcars Rookie
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Sat Nov 17, 2012 1:50 pm
i was about ready to blow it up robtennis61 but luckly i finally got the center bolt out i ve been researching online and it shows that there is a special puller for gm cars. the bolts are non standard does any one know the specs of the bolts? or if i could get them from a regular hardware store or do i need a specially hardware?
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Sat Nov 17, 2012 4:45 pm
ya might be ok after this. whatever you do get a good harmonic balancer or you will be doing this again real soon.
dartcars Rookie
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Sat Nov 17, 2012 5:30 pm
bitches are never happy lol
dartcars Rookie
Subject: removing harmonic balancer trying to get motor to stop spinning Thu Nov 22, 2012 3:24 am
i have a 97 buick riviera i am trying to remove the harmonic balancer to change the crank shaft sensor but i am currently having trouble getting the motor to stop spinning in order to remove the harmonic balancer any help is much appreciated
Name : Aaron Age : 46 Location : C-bus, Ohio Joined : 2007-01-14Post Count : 18448 Merit : 251
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Thu Nov 22, 2012 4:08 am
You can do one of three things: remove the plastic flexplate (flywheel) cover on the bottom of engine, near transaxle. Use a flat screw driver or locking pliers to hold the flexplate in place while loosening the crank screw.
Or, you can just use an impact gun. It will loosen without turning over the engine.
Last method is to mount a breaker bar to the crank pulley, rest it against the frame, then turn the key for a split second to crank the engine.
dartcars Rookie
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Thu Nov 22, 2012 4:09 am
yes they like to make it a pain in the ass
dartcars Rookie
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Thu Nov 22, 2012 4:12 am
i already have the center bolt out i just need to stop it from spinning in order to use the puller tool
Name : Derek Age : 52 Location : Reading, MA Joined : 2007-02-01Post Count : 7717 Merit : 109
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Sat Nov 24, 2012 1:28 pm
I always use the 'lock the flywheel' method. It's really not that hard to get the cover off (two 10mm head bolts) and sometimes you need an assistant if you can't find the right size screwdriver/angle but it guarantees you don't have things turning while you work.
Name : Larry Age : 67 Location : Oakland Gardens, NY Joined : 2007-01-23Post Count : 2179 Merit : 149
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Sat Nov 24, 2012 2:43 pm
There is a tool meant for turning a flexplate. It hooks on to the teeth in two places. You need two people, but that is the best way.
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Sat Aug 22, 2020 12:18 am
Also remember the Bolt is TTY. One use and throw it away. Buy a new one for re-installation of the Balancer.
Where does one get the HB bolt? I don't see it on Rock Auto.
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Sat Aug 22, 2020 7:56 pm
...do not pass Go, just call a NAPA store. Also, Advance Auto may have it as a Dorman OE Solutions item (especially if that store used to be a CarQuest), ask at the desk. That failing, a local mechanic will probably just tell you where they get them.
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Sat Aug 22, 2020 11:10 pm
Do any of these look right - Link
I'll have to mail order since my local NAPA went out of business.
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Sun Aug 23, 2020 1:43 am
Seriously, just phone a NAPA in a neighboring city. GM does not have much variation in this kind of hard mechanical part. They will likely sell you the BK 7355961 (Balkamp) or the NOE 6000186 (NAPA Solutions).
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Sun Aug 23, 2020 1:57 am
I guess I will - they wanted $21 to ship a $5 part!
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Sun Aug 23, 2020 8:14 pm
Oh, well. Again, the Advance Auto (former Carquest) places would be good for that as well.
Name : Rick Location : Lancaster, MA Joined : 2008-09-13Post Count : 6282 Merit : 119
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Sun Aug 23, 2020 11:27 pm
JR, I bought mine from a local GM (Cadillac) dealership. Called them and they had it in 1 to 2 days time IIRC. Easy peasy.
albertj likes this post
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Mon Sep 07, 2020 10:49 am
Let me be sure I have this set up right before I crank it.
BTW do we have the same problem with the engine turning when tightening the bolt as with loosening it?
Subject: Re: Write-Up: Removing the Crank Pulley/Harmonic Balancer Mon Sep 07, 2020 11:24 am
As long as that breaker bar doesn't move, yeah, that will work. The crank turns clockwise, so that will break the bolt loose. I would take the belt off, you'll need to anyway.
You will have to lock the crank if you want to tighten it back up with a torque wrench. Vice grip on the flex plate, or a screwdriver positioned in the flex plate to lock it. I've even seen guys feed some nylon rope into a plug hole to act as a piston stop. The VERY BEST way is to use an impact wrench. I bought this Dewalt impact gun last year. It is incredible.
I just finished replacing the gasket for my timing cover on the GS455. It sprung a coolant leak last week. The Dewalt zipped that bolt off in less than 5 seconds. That bolt needs to be torqued to 200 ft. lbs. MINIMUM. The Dewalt tightened it back up in the same amount of time. I marked the bolt and balancer before I loosened the bolt. The Dewalt made it even tighter. It zips off lug nuts with ease. 700 ft. lbs max torque. Used it to replace my flex plate on the same car. The crank bolts had red locktite. It didn't matter, off they came.
That bolt is supposed to be replaced according to the FSM. It's a torque to yield bolt I guess. Tighten the new bolt to 111 ft lbs. Then another 76*. That's what the FSM says. When I had my crank sensor done years ago, we just used the air impact wrench to tighten it back up. It's been fine, at least 7-8 years ago.
