heyzelchi Amateur
| Subject: In need of your advice Wed Oct 03, 2007 10:00 am | |
| -------------------------------------------------------------------------------- Hi I have an 95 riv sc today I was going to work and I heard a loud pop from under the car, the car was runing fine but I could not steer the car at all I'm thinking my steering or the tire rod went up any advice before I take the car to the shop | |
| Subject: Re: In need of your advice Wed Oct 03, 2007 10:39 am | |
| Is it hard to steer, or impossible to steer? Don't drive the car until you've checked the serpentine belts and pulleys for damage. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
heyzelchi Amateur
| Subject: Re: In need of your advice Wed Oct 03, 2007 12:45 pm | |
| it is impossible to steer I'm getting the car towed friday I just want to know what wrong with it or have an ideal before some tries to get extra money out of me. | |
| Subject: Re: In need of your advice Wed Oct 03, 2007 4:12 pm | |
| Need more info. Have you looked at the steering components yet? | |
'96reese Fanatic
| Subject: Re: In need of your advice Thu Oct 04, 2007 12:33 am | |
| i had a '96 riv that pulled into my shop that just suddenly lost control of their steering. their belt got shredded. i would definitely look at the serp belt. if that is fine then i would look at the power steering fluid and pump itself. if your tie rod snapped then you still be able to turn the wheel freely, but only one wheel would turn. let me know what they say. reese | |
heyzelchi Amateur
| Subject: Re: In need of your advice Fri Oct 05, 2007 7:37 pm | |
| it was the power steering belt & pulley | |
| Subject: Re: In need of your advice | |
