 Write-Up: Spindle / Wheel Bearing / Hub Replacement
curious riv
curious riv
PostSubject: Write-up: Wheel Bearing / Hub Assembly   Fri Jan 30, 2009 12:54 pm
Ive been searching rivperformance for half hour now and Im doin something wrong cuz I can't find if this is the hub I need bonk
http://www.zzperformance.com/grand_prix/products1.php?id=837&catid=138
Help me out. I wanna get the right one.
Thanks,
curious
PostSubject: Re: Write-Up: Spindle / Wheel Bearing / Hub Replacement   Fri Jan 30, 2009 1:02 pm
You can't replace just the bearing, you must install a new hub assembly.
See parts list for part #: http://rivperformance.editboard.com/series-ii-engine-transmission-f4/part-number-listing-t45.htm
Are you sure you need a new one?
curious riv
curious riv
PostSubject: Re: Write-Up: Spindle / Wheel Bearing / Hub Replacement   Fri Jan 30, 2009 3:25 pm
Not 100% sure, no. my trac and abs lights r on. ill b replacing the struts real soon and i figure i'd go ahead and do that too while im already there. the shop fee is 80$/hr, 1 hr min. for diagnostics. i dont wanna pay that if i dont have too. w my miles i thought it a safe bet t go ahead and change them. Any thoughts how i should go about this???
PostSubject: Re: Write-Up: Spindle / Wheel Bearing / Hub Replacement   Fri Jan 30, 2009 3:39 pm
If they're original after 225k miles, might be a good idea. But the hubs are pricey at about $125 apiece. If you want to do the install yourself, no need to pay $80/hr. It's a medium level DIY repair.
curious riv
curious riv
PostSubject: Re: Write-Up: Spindle / Wheel Bearing / Hub Replacement   Sat Jan 31, 2009 3:00 am
no, i meant 80$ for a diagnostic t tell me why my trac and abs light r on. they probably charge more than that for changin them out. im certainly capable of doin it in the front yard. thanks for the help, man!!! appreciated! cheers
Merit : 128
PostSubject: Re: Write-Up: Spindle / Wheel Bearing / Hub Replacement   Sat Jan 31, 2009 11:18 am
I'll probably have some information to report in this area soon.
My ABS/TCS pump will cut on and off while the car is just sitting idling and on occasion while moving. After this occurs several times during a run cycle, the ABS/TCS is deactivated by the computer. Other than that, the ABS/TCS seem to work fine. (The only thing I can think of is a shorting somewhere or a wheel speed sensor failure) Additionally, there is extra cabin noise coming from the wheel(s) that sounds like a possible product of a failing hub bearing. The noise is a constant sound that is similar to the noise that you hear from the road to the tires but significantly louder and if I'm next to a wall or something that can reflect the sound more, I can hear kind of like a ticking sound that correlates to my speed and steering. Interestingly, there is no vibration problem to speak of. It still rides smoothly.
Side note, I'd been having a rather annoying issue of my brakes making some noise ever since I put them on and I'm hoping it is, in fact the hub(s)
I have two new hub assemblies for it and I hope to get them on by this weekend. I have a trip this weekend so I need to get it figured out by then or it's going to be an interesting trip.
curious riv
curious riv
PostSubject: Re: Write-Up: Spindle / Wheel Bearing / Hub Replacement   Sat Jan 31, 2009 5:56 pm
thanks for sharin... i was gunna ask if u checked the wss connectors, but that wont explain the noise. Good luck w the work!!!
Merit : 128
PostSubject: Re: Write-Up: Spindle / Wheel Bearing / Hub Replacement   Sun Feb 01, 2009 2:13 pm
