 FAQ: Tuning a 1996 Riv SC?
Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Are you interested in purchasing tuning software for a '96 Riviera?
Yes
76%
 76% [ 26 ]
No
24%
 24% [ 8 ]
Total Votes : 34
Merit : 171
PostSubject: Re: FAQ: Tuning a 1996 Riv SC?   Sat Oct 09, 2010 2:05 pm
epic612 wrote:
From what I was told, the 1996 model in particular is tough to mod due to the PCM (?), some computer, and the way the transmission connects. If the 96 is easy, point me to the info! haha
The transmission on a '96 is vacuum controlled, whereas the '97-'99 is completely electronic. That's really the main difference. The engines themselves are almost 100% identical.
Merit : 100
PostSubject: Re: FAQ: Tuning a 1996 Riv SC?   Sat Oct 09, 2010 3:21 pm
Scott is right - Besides the mechanicals, '96 is the year that OBD II arrived, so the computers are MUCH easier to deal with/diagnose...
PostSubject: Re: FAQ: Tuning a 1996 Riv SC?   Mon Oct 11, 2010 9:53 am
The other issue is that HP Tuners doesn't allow tuning of '96 Riv PCMs (yet). If you can find a used DHP PowerTuner you should be able to tune a '96 with it.
epic612
Name : Collin "C Note" Abram
PostSubject: temp   Mon Oct 11, 2010 2:20 pm
So much I don't know! Thanks for all the heads up, folks. I appreciate it.
http://www.facebook.com/7point62mm
Merit : 100
PostSubject: Re: FAQ: Tuning a 1996 Riv SC?   Tue Oct 12, 2010 1:42 am
Not to mention, even without a tuner, I should have mentioned that you can bolt on all the modest mechanical mods in my signature and feel a definite "boost"... lol
whit2285
PostSubject: 96 dhp questions   Sun Nov 21, 2010 10:30 pm
ok so i recently purchased a dhp tuner , im running ver 1.2.4 , i have the 1.5 bin for the 96 riv. . i am able to scan , log, and even read my pcm and save the file. when i try to open the file using the pt i cant. i can open the 1.5 bin though. so my question is do you think i can do a full write to my pcm w/ the 1.5 bin. . or should i try to figure out why i cant open my read file from my pcm.
i also posted on the dhp forum , but i figured i would ask here just because..
thanks
mike
PostSubject: Re: FAQ: Tuning a 1996 Riv SC?   Sun Nov 21, 2010 11:42 pm
Which file can't you open? The one from your full read or the "1.5"? Where'd you get the 1.5 file for a '96 Riv?
whit2285
PostSubject: Re: FAQ: Tuning a 1996 Riv SC?   Mon Nov 22, 2010 12:11 am
my full read file is the one i cant read.. i got the 1.5 from this site , if you search "96 tuning", a thread comes up billboost posted it awhile ago in the bonni forum . i downloaded it last year and found it again just a few days ago ...i can open that and read it no problem and even make changes if i want to..i did the vin search to make sure osid match and they do . so i dont know lol, i dont want to eff up a pcm, trying to be safe and not sorry
bin thread
http://rivperformance.editboard.com/series-ii-scans-tuning-pcm-f5/1996-riv-bin-file-t5072.htm?highlight=96+tuning
PostSubject: Re: FAQ: Tuning a 1996 Riv SC?   Mon Nov 22, 2010 6:16 am
Is the PCM in the car now modified at all?
whit2285
PostSubject: Re: FAQ: Tuning a 1996 Riv SC?   Mon Nov 22, 2010 11:56 am
No its completly stock, never been touched as far as I know...
whit2285
PostSubject: Re: FAQ: Tuning a 1996 Riv SC?   Fri Nov 26, 2010 12:29 pm
So 96ers with dhp, how did you do it ? Some guidance please ..! ?
Merit : 171
PostSubject: Re: FAQ: Tuning a 1996 Riv SC?   Fri Nov 26, 2010 12:32 pm
We couldn't read my .bin from the PCM either. It kept saying it wasn't valid or some shit. We ended up loading somebody elses tune and making changes from there.
rk0ehn
Name : Christian Rolf Köhn
PostSubject: Temp   Thu Sep 01, 2011 8:42 pm
i wish i had one! wana split a 96 pcm bin? smile
i have a scanner and a bunch of friends with tunners but none of them will work with the riv frown
SO, are there any tuners for the 1996 Riviera?
I see a lot of them but for the 1997 model year going forward frown
whit2285
PostSubject: Re: FAQ: Tuning a 1996 Riv SC?   Sun Sep 04, 2011 3:02 pm
so i bought the dhp about a year ago and pretty much didn't do anything with it but read, read and read more about how to use it. well i finally ordered some goodies for the riv., and decided to take the leap of re writing the pcm with the 1.5 bin for the 96 that has been flying around here.. well . It worked Hooray.. let the modding / tuning begin . joy
whit2285
PostSubject: Re: FAQ: Tuning a 1996 Riv SC?   Wed Sep 28, 2011 10:46 pm
O.K. i give up, where in PT can i change Injector Flow Rate... I Go to Fuel / Fuel injector / injector flow rate and i only get 1 value ( mSec/gram ----207.17). when going through guides i have seen for gtp's and othe 3800 it shows a totally different chart..
just a reminder its a 96 1.5 bin that i have, maybe some one can point me in the right direction..
i guess no matter how prepared i think i am something always comes up .. help
Merit : 100
PostSubject: Re: FAQ: Tuning a 1996 Riv SC?   Wed Sep 28, 2011 10:47 pm
you cant change IPW or flow rates for individual cylinders on a 96 pcm. The single value is for the motor as a whole.
whit2285
PostSubject: Re: FAQ: Tuning a 1996 Riv SC?   Wed Sep 28, 2011 10:51 pm
ok thanks , i thought i was loosing it and just couldn't find it. at least i can sleep now..
thanks again
Now i have to research how to do that bonk
PostSubject: Re: FAQ: Tuning a 1996 Riv SC?   Wed Sep 28, 2011 11:08 pm
I have a DHP PowrTuner for sale if anyone is interested btw...
whit2285
PostSubject: Re: FAQ: Tuning a 1996 Riv SC?   Sat Oct 01, 2011 12:21 pm
Another question, everything I read says reset fuel trims when you change anything fuel related, . So if I check the box in the programmer to reset is that good enough, or should I disconnect battery still
Merit : 100
PostSubject: Re: FAQ: Tuning a 1996 Riv SC?   Sat Oct 01, 2011 12:23 pm
You can just do it through the power tuner. no need to unplug the battery, that would take forever when you start actually tuning the car and making frequent fuel changes.
whit2285
PostSubject: Re: FAQ: Tuning a 1996 Riv SC?   Sat Oct 01, 2011 1:07 pm
Thanks again..
birdogmike
PostSubject: Re: FAQ: Tuning a 1996 Riv SC?   Thu Mar 28, 2013 7:38 am
I have a 97 Riviera with a Supercharge, 3800 in it. My question is how much of a problem is it to replace the sparkplugs & plugwires? I was told that to get the plugs out of the back of the engine, I would have to jack the engine up to gain access to the back plugs!! Is there any truth in this? Thanks for any help. Birdogmike
http://mdinc01@aol.com
PostSubject: Re: FAQ: Tuning a 1996 Riv SC?   Thu Mar 28, 2013 8:25 am
It can be done from up top. It's tight, but doable. some guys like to go from underneath the car. The plug wires can weld themselves to the spark plugs making removal of the wires nearly impossible without damaging them. If you are replacing the wires, and you should, it doesn't matter. Use the stock parts, they are very good, and not expensive. Buy them from www.rockauto.com
crstump
PostSubject: Re: FAQ: Tuning a 1996 Riv SC?   Sun Apr 21, 2013 11:51 pm
Does any one have or know of anyone in the Kentucky area that has a tuner for the 96? and knowledge lol i recently did a few mods and want to check for KR and get rid of that 108 limiter, if so i will make healthy donation to anyone who can help.
PostSubject: Re: FAQ: Tuning a 1996 Riv SC?   Mon Apr 22, 2013 12:17 am
i am also in need of someone who can tune my 97 and am in ky also. can drive a few states away to get it done if needed
Page 5 of 9Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
