 Quad driver code
TURBO87
Apprentice
Merit: 0
PostSubject: Quad driver code   Wed Oct 10, 2007 12:09 am
Anyone ever get a quad driver code on 95 Riv? If so what fixed it? I changed EVERY eletrical part on the car save for the wire harnes. Even changed some parts more than once. smile
Dave
jhodges
Apprentice
Merit: 1
PostSubject: Re: Quad driver code   Wed Oct 10, 2007 5:53 pm
I had a Quad driver 1 code and changed out the boost control solenoid and it fixed the problem. which quad driver code are you getting. quad driver one controls the boost solenoid evap purge solenoid and I believe the tc solenoid
TURBO87
Apprentice
Merit: 0
PostSubject: Re: Quad driver code   Wed Oct 10, 2007 7:27 pm
Id have to rescan it i dont recall for sure but i think it was like 1680 or something. It's a OBD 2 code
Dave
SC95Riv
Merit: 0
PostSubject: Re: Quad driver code   Thu Nov 29, 2007 10:08 am
I was just gonna make a thread about this...Last night I my service engine light came out, so I pulled into a parking lot and plugged in my scanner...and it pulled a code for the "Quad Driver Module QDM 2 Fault" Now This code has popped up before and I had the boost solenoid changed at Buick back in the summer of '06....can it be that it went again after a year and a couple months? WHat would cause it to keep failing?
Also using Seafoam in my Riv the night before this happened wouldnt cause this code would it? I only added it to my gas tank as per the directions on the back of the can.
BillBoost37
Merit: 23
PostSubject: Re: Quad driver code   Thu Nov 29, 2007 10:21 am
BCS's do seem to go more frequently than we'd like to admit. I think the QDM 2 is the BCS/Evap/TCC.
SC95Riv
Merit: 0
PostSubject: Re: Quad driver code   Thu Nov 29, 2007 4:18 pm
Is this something that can be easily changed in the driveway, or does the blower have to come off and various other things to access it?
BillBoost37
Merit: 23
PostSubject: Re: Quad driver code   Thu Nov 29, 2007 6:45 pm
Bad news .. DTC 1650 QDM2 is Shit and TCC soleniods only.
KillaKeninaRiv
Merit: 6
PostSubject: Re: Quad driver code   Mon May 11, 2009 10:33 pm
Hey I'm having the same problem but I'm having a quad module 3 error along with cam/crank error (99 total) so I changed the cam sensor and it went down to 3. What causes the quad 3 on a series one?
Quad driver code
» Congratulations to Quad Racer Kris Sindorf
» Knights Code of Chivalry
» DIVX player Registration Code
» honda accord error code
» So, what's your daily driver?
