| FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On | |
Name : Aaron Age : 42 Location : C-bus, Ohio Joined : 2007-01-13 Post Count : 18366 Merit : 241
 | Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Fri Mar 14, 2008 2:49 am | |
| _________________ '98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '05 GTO • 85k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26 Because fun'70 Olds Ninety-Eight Holiday Coupe • 116k miles • 455 Rocket V8 Because cool'95 Celica • 152k miles • 0-60: yes Because free |
Name : Derek Age : 47 Location : Reading, MA Joined : 2007-01-31 Post Count : 7717 Merit : 109
 | Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Fri Mar 14, 2008 10:01 am | |
| usually it's the sign of a dying wheel speed sensor. Eventually it will stay on all the time.
Mine started coming on after going through a puddle, and eventually graduated to on all the time. Time for new wheel bearings... 143K is a good amount of miles on the stockers. Usually people start reporting WSS issues around 120K |
Natesriv Addict
Name : Nate Age : 49 Location : KCMO Joined : 2007-01-18 Post Count : 509 Merit : 16
 | Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Sat Mar 22, 2008 10:29 am | |
| Now I took mine to the freakin shop and they charged me a $100 to tell me I need a new EBTCM.
How do you tell if a wheel speed sensor is bad? Because a new EBTCM is over a grand and not worth having. But a new wheel speed sensor from e-bay is $90..
albertj Guru
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 7474 Merit : 152
 | Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Sat Mar 22, 2008 1:46 pm | |
| ought to be $175 - $300 used on ebay or via Ed Morad - use Search on this Bboard to find address for Ed.
Last edited by albertj on Sat Mar 22, 2008 1:47 pm; edited 1 time in total (Reason for editing : schpellingh) |
 | Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Sun Mar 23, 2008 7:49 am | |
| I got new, GM bearings/hubs/wss for $143 from monsterpartsonline.
Nate what year is your Riv? |
99Rivman Aficionado
Name : Randall Location : North Carolina Joined : 2007-01-16 Post Count : 2009 Merit : 87
 | Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Sun Mar 23, 2008 9:21 am | |
- Might try cleaning the connectors on the hubs/sensor wires. It's a long shot, but pretty easy to do.
I had a problem on my '95 and it turned out being a corroded connection, but I would take a look at all of the connections. |
Natesriv Addict
 | Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Sun Mar 23, 2008 10:33 am | |
| Mine's a 96. I've taken each hub plug and greased it a couple of years ago.
My light always goes on about 15 seconds after running. However, sometimes I can go miles without stopping and it stays off. But when I start again, 15 seconds or so later, the light goes back on.
I know it doesn't work even with the light off, in the snow I would purposely try to spin the wheels...no traction control at all.... |
 | Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Sun Mar 23, 2008 6:54 pm | |
| You are losing a Wheel Speed Sensor. You'll be replacing the entire hub to fix it. I recommend doing both, because if you don't you'll be doing the other side next year, plus you don't have to pay somebody to hook up an ABS capable computer to find out which side is gone. |
willy#1 Newbie
Name : Bill Age : 72 Location : OKC Joined : 2008-06-18 Post Count : 2 Merit : 0
 | Subject: 95 Riviera ABS & Traction control stay on Sat Jul 12, 2008 8:28 pm | |
| Hi I am new to this site, I have a few problems with my 95 riv, My abs and traction amber lites stay on all the time. I changed the hubs thinking this would solve problem, well it didnt, I use the 95 riv shop manual, and have gone step by step in trouble shooting, cant find problem?? Does anybody out there know if the new Actron ABS reader will work on the 95 rive? I know its OBD 1 with a 16 pin OBD 11 connector, need a little imput thanks willy |
Chicken Aficionado
Name : Mark Age : 53 Location : Montana Joined : 2008-06-13 Post Count : 1296 Merit : 8
 | Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Sat Jul 12, 2008 9:05 pm | |
| My light stays on too...
When I first start the car in the morning, the light is off.....then a few minutes later the light comes on.
If I go on a long road trip, 300 miles or so.....it turns off and I can turn it on and off via switch...then when I return to my normal routine the light turns on again....
I think when I get my PCM I'm just gonna have them turn off the traction control.... |
baynes72 Amateur
Name : chris Age : 47 Location : michigan city indiana Joined : 2008-04-23 Post Count : 31 Merit : 0
 | Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Sun Jul 13, 2008 4:25 am | |
| my friend has a snap on "brick" scanner and he was able to pin point the problem with that on mine , pass wheel bearing |
'96reese Fanatic
Name : Reese Age : 37 Location : StL Joined : 2007-09-20 Post Count : 259 Merit : 4
 | Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Mon Jul 14, 2008 1:00 am | |
| yah i have a "snap-on brick scanner" too, that will definitely pin point the problem. if you're close to the st. louis area i'll scan it for you. if not, then you might wanna check your abs wires to the wheel sensors themselves and also check the abs/traction control pump. then there is also a an abs module and traction control module. take it to the dealer and pay the $100 to have them find out the problem. |
jrockstangs Amateur
Name : Jason Location : chicago Joined : 2008-06-22 Post Count : 31 Merit : 0
 | Subject: abs and traction control light on???? Sat Jul 19, 2008 9:15 pm | |
| the other day my tc and abs light popped on...car still has brakes, and all that shit i was wondering if anyone got any insight on this subject...thanks |
 | Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Sun Jul 20, 2008 7:40 am | |
| would help to know what year and stuff your car is. Please add that info to your signature.
Usually it's a wheel speed sensor, which means a wheel bearing needs to be replaced. Unfortunately you need someone with an ABS scan tool to pull the code. |
SuperRiv07 Addict
Name : Nick Age : 35 Location : Brookfield, And If everything goes right A Nice big house in Bolingbrook with a big GARAGE Joined : 2008-07-20 Post Count : 706 Merit : 0
 | Subject: TractionControl Question???? Sun Jul 20, 2008 2:31 pm | |
| I got A 97 Riv SC and when I bought it my traction control light was on indicating that it was off, is this a bad thing? I mean i dont have to push the button to turn it of, it dont bother me except for the light being on all the time. But is it a problem ?? |
 | Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Sun Jul 20, 2008 5:39 pm | |
| Usually it means a wheel speed sensor is shot, which is a preindicator of wheel bearing failure. If you find out which wheel it is, then replace the bearing (sensor is included in the bearing). Need the code read by an ABS specific scan tool. |
SuperRiv07 Addict
 | Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Sun Jul 20, 2008 6:17 pm | |
| so I need a scan to find out what side or should I just replace both sides |
 | Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Sun Jul 20, 2008 6:19 pm | |
| I paid a shop $30 to tell me which bearing wasn't reading... |
SuperRiv07 Addict
 | Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Sun Jul 20, 2008 6:22 pm | |
| ok kool but would it be better to just replace both so i dont have the problem of fixing one and then the other goes out? and how much are wheel bearings? |
54_nailhead Enthusiast
Name : Luke Age : 43 Location : Waconia, MN Joined : 2007-06-15 Post Count : 126 Merit : 3
 | Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Sun Jul 20, 2008 7:01 pm | |
| There should be a sensor for each wheel. I bougt one for the rear of my '96 a couple years ago and it was $180 so you'll probably want to get it scanned first to see which one is bad. |
SuperRiv07 Addict
 | Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Sun Jul 20, 2008 10:30 pm | |
| ok kool thanks for the advice |
SuperRiv07 Addict
 | Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Sun Jul 20, 2008 10:36 pm | |
| i got the same the same prob on my 97 riv sc |
'96reese Fanatic
 | Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Sun Jul 20, 2008 11:36 pm | |
| yah i agree with Derek. the problem is normally found where the wheel sensor hooks up. if you can jack up all four wheels with the tires off so that you can look at each sensor. you could also have a busted up outer cv boot thats leaking grease all over the sensor. if thats the case, then you will have to clean off all the grease with a good degreaser, and replace the half shaft. you will have to find sumone with a scanner that is capable of testing the abs system. NOT ALL SCANNERS CAN!
the tract light is tc light is on because the abs light is on. once you fix the abs light then the tc light will go off. |
SuperRiv07 Addict
 | Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Mon Jul 21, 2008 3:23 am | |
| any mechanic should have one correct? |
jrockstangs Amateur
 | Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Mon Jul 21, 2008 9:40 pm | |
| shit sorry guys its 96 SC RIV.....THANKS FOR THE HELP LET YA KNOW HOW IT GOES |
 | Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On  | |
