| FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On | |
+75JR3800 makemann1 designer1962 th3fr4nchi5e al_roethlisberger jbeganny chitown_riv98 bmcd9179 joshuadalegrimes taongisurvivor matt270avian bigdave back in BLACK crstump sniperdude ZEP RidzRiv portiz966 adri rk0ehn atteboy1 Jack the R SCbuick010 jonly Eldo 1998 Riv robotennis61 Abaddon BrianEsser moldymac GMFreak8 duckstu nigelf jamie Mikel RivGuy jrocha BKRIV Snowdog ibmoses curious riv Rickw 97rivsc ewolfe0050 manofmany 1wickedninja Pudgee SuperRiv07 jrockstangs '96reese baynes72 Chicken willy#1 Natesriv TypetoHarry Shintsu 96RIVMANN albertj BillBoost37 330racing 54_nailhead ChiTownRiv Jason etosino2009 L67 steel2040 turtleman racinfan lionfish deekster_caddy AA 98riv 99Rivman Mr.Riviera NO 4 EVR 79 posters |
Natesriv Addict
Name : Nate Age : 54 Location : KCMO Joined : 2007-01-18 Post Count : 509 Merit : 16
| Subject: ABS Light Tue Jul 22, 2008 6:21 pm | |
| Came on on way home,
manual says to take key out and reset, I did. Light is still on..
Guess I should have the code pulled and see if it's a wheel speed sensor... and I guess I'll ebay the part....
Really thinking it's time for a new car.... | |
SuperRiv07 Addict
Name : Nick Age : 39 Location : Brookfield, And If everything goes right A Nice big house in Bolingbrook with a big GARAGE Joined : 2008-07-20 Post Count : 706 Merit : 0
| Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Tue Jul 22, 2008 7:21 pm | |
| how do you reset it just pull the key out or do you have to do something else? | |
Natesriv Addict
| Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Wed Jul 23, 2008 10:17 am | |
| I think take key out, car off and it resets.... i turned car back on, and moment I pushed brake pedal...light went on.... car not moving...
ideas??? | |
Natesriv Addict
| Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Thu Jul 24, 2008 8:51 am | |
| Well, the light has gone out...then today came back on. When i got to work I turned car off, pumped brakes a few times and turned back on...light off.
Talked to a buddy at work and it could be a valve or something in the ABS system... dirt and debris probably in the brake fluid...a flush could really help. | |
Pudgee Special
| Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Sat Jul 26, 2008 2:15 am | |
| ....I've read that it can be a bad ABS sensor or even a dirty pick up gear? ....the toothed ring that the sensor picks up from. FYI. | |
willy#1 Special
Name : Bill Age : 77 Location : OKC Joined : 2008-06-18 Post Count : 2 Merit : 0
| Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Wed Jul 30, 2008 5:33 pm | |
| Hi from willy#1, In reply to abs and traction control problem, I changed my hubs,still had abs trac prob, troubleshot complete system after getting mt2500 found the abs modulator bad, the best way to find these abs problems is to spend the money for a good scanner or take it to a shop that will scan it for you, that is if you trust the people doing it,anyway now I know whats up, and it will be verry costly, hope this info helps others | |
| Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Wed Jul 30, 2008 9:25 pm | |
| Sorry to hear it willy... at least you have new wheel bearings! | |
1wickedninja Addict
Name : Josh Age : 35 Location : port saint lucie, Fl Joined : 2008-07-30 Post Count : 647 Merit : 5
| Subject: abs and traction off light? Tue Aug 19, 2008 1:21 am | |
| Hey i have a quick question today at work i moved my car around the building to a closer parking spot. While i was doing that both the traction off and the abs light came on. Well as you guys probably know its been raining pretty bad do to the tropical storm of the coast of Florida. Any ways guys at work told me that it could of just got wet and in a couple of days it should go off. what do you guys think? | |
manofmany Addict
| Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Tue Aug 19, 2008 7:35 am | |
| From what I've read it's generally an indicator of a bad hub. My ABS/Traction lights are on as well. | |
Natesriv Addict
| Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Tue Aug 19, 2008 11:00 am | |
| lights been off for weeks now. buddy and i thought it may have been a piston or some moving part internal to the abs (i really don't know the terminology)... pumping the brakes a few times circulated the fluid and cleared up any gunk or what not which was clogging.
I've also recently had the brakes flushed and the light is still off... ABS does work too, as I slammed the brakes a few times and it engaged.
traction control is not working. I removed the bulb which says Traction Off, don't really need it in a 3k + lb FWD car.. | |
| Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Tue Aug 19, 2008 11:44 am | |
| Hmmm.... you might want that traction control if you ever hit patches of black ice or wet leaves.
manofmany Addict
| Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Tue Aug 19, 2008 8:49 pm | |
| Well it all depends on the person I suppose. I HATE TC and ABS so I have no intentions on fixing it until/if something breaks. | |
Natesriv Addict
| Subject: ABS and Traction Control?? Mon Sep 22, 2008 2:49 pm | |
| Quick question,
Is the ABS system below the traction control motor? Are they a combined unit? My ABS light is on, and my traction control doesn't work (hasn't in awhile) so I wonder if they are combined.. | |
ewolfe0050 Aficionado
| Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Mon Sep 22, 2008 4:49 pm | |
| ABS, traction control, and the magnasteer are all incorperated with one another. Mine went out with a faulty hub. It could be the hub, hub sensor, wiring (not usually) or the main box. | |
L67 Aficionado
| Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Mon Sep 22, 2008 5:04 pm | |
| i had the same problem and i replaced the wire harness and it was fixed. | |
Natesriv Addict
| Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Tue Sep 23, 2008 11:07 am | |
| what do you mean "wire harness" where, at the hub, on the EBTCM???
Is there any "CHEAP" way to read an ABS code?? | |
| Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Tue Sep 23, 2008 12:55 pm | |
| - Natesriv wrote:
- what do you mean "wire harness" where, at the hub, on the EBTCM???
Is there any "CHEAP" way to read an ABS code?? Not free, but I went into a garage that had one of those big-ass BEAR computer diagnostic systems, explained to the mech. that I was a DIY'er and just needed to know which wheel sensor was out. He put my car on his lift, hooked up the machine and gave all 4 wheels a spin. I left minus $30 and only had to replace one wheel bearing, problem solved. | |
L67 Aficionado
| Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Tue Sep 23, 2008 2:51 pm | |
Is there any "CHEAP" way to read an ABS code?? The harness giving me trouble was the one in between the 2 rear wheels that was clipped on by the axle. The coating on the wires had worn out and it was shorting out. I just grabbed one off of a junkyard riv and it was all fixed. | |
97rivsc Fanatic
Name : mike Age : 34 Location : appleton wisconsin Joined : 2008-09-28 Post Count : 437 Merit : 0
| Subject: abs and traction control Wed Oct 01, 2008 1:53 am | |
| I just purchased my riv a little while ago and i found out that along with the upgraded pcm came a disabled abs, and disabled traction control. this bugs me a lot. anyone know what i should do to fix this? I want to keep the performance shift points, but i want all my features back. please help!!! | |
| Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Wed Oct 01, 2008 9:24 am | |
| Most likely it's a wheel speed sensor. Start by cleaning the connectors just inside the front wheels. | |
97rivsc Fanatic
| Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Wed Oct 01, 2008 9:40 am | |
| what does it look like. im not familiar with it. | |
| Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Wed Oct 01, 2008 10:29 am | |
| I think the upgraded PCM has the TC and ABS disabled so that the torque management doesn't interfere with some of the tuning. I know when we tuned my car getting around the TM was difficult. I still have TC and ABS though but it took a while... | |
| Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Wed Oct 01, 2008 10:45 am | |
| mike, Do yourself a favor and buy the Factory Service Manual. I did shortly after buying my Riv. and it's been very helpful and worth every penny i spent. | |
97rivsc Fanatic
| Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Wed Oct 01, 2008 3:07 pm | |
| how did you do that eric and what do i need to do in order to restore them because the sensor is clean and it works it is just disabled because of what you mentioned. and also is there any other way than with a tuner for my car? looking to do it quickly before winter. winter in wisconsin is an S.O.B.!!!!!!!!! | |
| Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On Wed Oct 01, 2008 3:27 pm | |
| If TC and ABS is disabled by Intense Std. PCM, then I'll need this info also. Just received PCM yesterday, have yet to install though. Going with Derek on Friday to Dyno tune shop. He and brother have scheduled a couple of hours. I'm just going to meet and observe. Turns out shop is less than 8 Miles from my house and i didn't even know it. If my PCM needs additional tuning to enable TC and ABS I'd like to be able to speak to these guys about it somewhat intelligently, if thats possible.! | |
| Subject: Re: FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On | |
