GothicVash Enthusiast
Name : tyler Age : 38 Location : fairfield CT Joined : 2007-10-15 Post Count : 123 Merit : 0
| Subject: starting problem Wed Oct 17, 2007 9:20 am | |
| ok i got a problem sometimes when i try to start my car all it dose is buzz and a red brake light comes on in the dash so i put it in drive then back in park sometimes works the first time sometimes takes a while and whenever i turn my ac on after i get this really loud whineish noise | |
| Subject: Re: starting problem Wed Oct 17, 2007 9:50 am | |
| Check battery voltage when you go to start up. Should be 12v or better. If lower than 11.8, you need a new battery. If volts are good, could be the solenoid on the starter going out (replace starter unit).
The AC blower squealing is a separate problem. Replacing the blower should fix. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: starting problem Wed Oct 17, 2007 9:52 am | |
| k thanks will check the battery out dose it say in the car or do i need a multimeter thing to do that and those are the only 2 problems with the car other then a dent and scratch down the side (just got it a week ago or so) | |
| Subject: Re: starting problem Wed Oct 17, 2007 9:53 am | |
| Need a scanner or multimeter. How old is the battery? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: starting problem Wed Oct 17, 2007 9:55 am | |
| i have no idea like i said i just got the car like a week ago i got a spare one in my dead regal though so ill go check that if thats the prollem there would be really easy to get rid of that n you think the ac problem is the ac blower? (srry i dont know much about cars but i want to learn) | |
| Subject: Re: starting problem Wed Oct 17, 2007 10:18 am | |
| If the squeal is coming from inside the dash, it's the blower motor. If it's coming from under the hood, you could need new belts/pulleys. How many miles on the car? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: starting problem Wed Oct 17, 2007 10:20 am | |
| 92k it sounds like its from the hood but i cant be shure it is loud ill get the belts checked out and the blower motor checked out i thought it stoped blowing cold air but then i looked at the outside temp witch was 55 and it only goes to 60 lol so that wasnt it | |
| Subject: Re: starting problem | |
